    Change Compliments
    17 Posts 7 Posters 7.7k Views 7 Watching
      dgregory19
      Thanks everyone! Figured it out. Onto breaking something else…
        CheapDad
        My apologies for resurrecting a dead thread, but it seemed like keeping all similar questions to one thread might be useful to others.
        I was happy with the default compliments, but wanted to customize them to the user. I copied the compliments entries from compliments.js and inserted them into my config.js. I don’t get any errors when I run config:check, but the compliments no longer appear on the screen. Here’s my code:
        			module: "compliments",
        			position: "lower_third",
        			config:  {
        				compliments: {
        					anytime: ["Hey there Emma!"],
        					morning: ["Good morning, Emma!", "Enjoy your day!", "How was your sleep?"],
        					afternoon: ["Hello, Emma!", "You look beautiful!", "Looking good today!"],
        					evening: ["Wow, you look great!", "You look nice!", "Hi, Emma!"],
        					"....-01-01": ["Happy new year!"]
          sdetweil @CheapDad
          @cheapdad u should have gotten an error in the window where u start MM…
          I do copying your stuff
          SyntaxError: Unexpected token '}'
              at wrapSafe (internal/modules/cjs/loader.js:1060:16)
              at Module._compile (internal/modules/cjs/loader.js:1108:27)
              at Object.Module._extensions..js (internal/modules/cjs/loader.js:1173:10)
              at Module.load (internal/modules/cjs/loader.js:992:32)
              at Module._load (internal/modules/cjs/loader.js:885:14)
              at Function.f._load (electron/js2c/asar_bundle.js:5:12738)
              at loadApplicationPackage (/home/sam/MagicMirror/node_modules/electron/dist/resources/default_app.asar/main.js:110:16)
              at Object.<anonymous> (/home/sam/MagicMirror/node_modules/electron/dist/resources/default_app.asar/main.js:222:9)
              at Module._compile (internal/modules/cjs/loader.js:1152:30)
          and npm config:check says
          (base) sam@sams:~/MagicMirror$ npm run config:check
          > magicmirror@2.15.0 config:check /home/sam/MagicMirror
          > node js/check_config.js
          [24.04.2021 15:25.20.258] [INFO]  Checking file...  /home/sam/MagicMirror/config/config.js
          [24.04.2021 15:25.20.270] [ERROR] Your configuration file contains syntax errors :(
          [24.04.2021 15:25.20.270] [ERROR] Line 56 column 7: Parsing error: Unexpected token {
          shorter answer, u are missing a }
            CheapDad @sdetweil
            @sdetweil That’s the strange thing, I’m not getting any errors when I run npm run config:check.
            Unfortunately, I had to rebuild my config.js since I installed a module, edited config.js and ended up with a blank screen that no commenting the config.js entries didn’t fix.
            Here’s the new (old) compliments entries:
            			config:  {
            				compliments: {
            And my npm run config:check:
            pi@emmasmagicmirror:~/MagicMirror $ npm run config:check
            > magicmirror@2.15.0 config:check /home/pi/MagicMirror
            [24.04.2021 16:58.15.197] [INFO]  Checking file...  /home/pi/MagicMirror/config/config.js
            [24.04.2021 16:58.15.352] [INFO]  Your configuration file doesn't contain syntax errors :)
              sdetweil @CheapDad
              @cheapdad
              the thing is
                  module:"name",
                  position:"...",
                      compliments: {
                      }   //< ---- this brace is missing
              get bitvise ssh client, then u can have a file manager view from windows
              and use notepad++ to edit  and see the  brace, paren and bracket matching
                CheapDad
                Forgive me for pursuing this, but I see an opportunity to really learn here. When I look at my code, I have closed all of my braces:
                			config:  {  \\ open
                				compliments: {  \\open
                		}   \\close
                	}, \\close
                			module: "weather",
                If I add another closing brace, won’t I have an error because there is no opening brace?
                On the suggestion for bitvise ssh, I’m working directly off the pi itself. I would love to run the entire MM configuration in a vm until it is right and then simply copy that over to the pi, but that’s a bit beyond my knowledge level.
                  sdetweil @CheapDad
                  @cheapdad u are missing the open brace for the module block in this last picture (see my layout above)
                  if you use bitvise then u dont have to edit ON the pi keyboard…
                  also gives u an ssh window to execute commands, again NOT on the pi keyboard
                  u can run raspian x86 in a vm on pc…
                    CheapDad
                    I think I figured it out and see where I needed a third closing brace. The weird thing is that Compliments seems to be the only module that doesn’t start with an opening brace, where all the others appear to. If I add an opening brace to it, I get an error. If I leave it out, it runs.
                      sdetweil @CheapDad
                      @cheapdad EVERY module MUST start with an opening brace…
                      ignore any typos you find somewhere else…
                      see my module diagram above
                        CheapDad @sdetweil
                        @sdetweil Got it.
                          sdetweil @CheapDad
                          @cheapdad I sent u a chat message
