    Change Compliments
    17 Posts 7 Posters 7.5k Views 7 Watching
      Mykle1 Project Sponsor Module Developer @dgregory19
      @dgregory19
      Or, use a remote file (as per the compliments readme) so as not to encumber the config.js file with a lengthy entry.
      • cowboysdudeC Offline
        OR just use another module…
        https://github.com/cowboysdude/MMM-NiceThings
          dgregory19 @THeStigh
          @thestigh I’ll try this. It looks different then what is supplied by MM. I think i have the syntax wrong and haven’t learned yet how to do the coding. Thanks.
          • T Offline
            THeStigh @dgregory19
            @dgregory19 As @Mykle1 stated, there is another way.
            Personally, I prefer to have all custom configurations in one single file config.js and all custom css in the custom.css, by this I can add/remove/replicate configurations/modules installed from device to device. Makes it easy to backup :)
            Another tip;
            Above each module in config.js, you can add disabled: false / true, to temporarily make a module not load on MM. Like this:
            			disabled: false,
            			module: 'MMM-Remote-Control'
            If you need anymore help, please let me know.
              dgregory19
              Thanks everyone! Figured it out. Onto breaking something else…
                CheapDad
                My apologies for resurrecting a dead thread, but it seemed like keeping all similar questions to one thread might be useful to others.
                I was happy with the default compliments, but wanted to customize them to the user. I copied the compliments entries from compliments.js and inserted them into my config.js. I don’t get any errors when I run config:check, but the compliments no longer appear on the screen. Here’s my code:
                			module: "compliments",
                			position: "lower_third",
                			config:  {
                				compliments: {
                					anytime: ["Hey there Emma!"],
                					morning: ["Good morning, Emma!", "Enjoy your day!", "How was your sleep?"],
                					afternoon: ["Hello, Emma!", "You look beautiful!", "Looking good today!"],
                					evening: ["Wow, you look great!", "You look nice!", "Hi, Emma!"],
                					"....-01-01": ["Happy new year!"]
                  sdetweil @CheapDad
                  @cheapdad u should have gotten an error in the window where u start MM…
                  I do copying your stuff
                  SyntaxError: Unexpected token '}'
                      at wrapSafe (internal/modules/cjs/loader.js:1060:16)
                      at Module._compile (internal/modules/cjs/loader.js:1108:27)
                      at Object.Module._extensions..js (internal/modules/cjs/loader.js:1173:10)
                      at Module.load (internal/modules/cjs/loader.js:992:32)
                      at Module._load (internal/modules/cjs/loader.js:885:14)
                      at Function.f._load (electron/js2c/asar_bundle.js:5:12738)
                      at loadApplicationPackage (/home/sam/MagicMirror/node_modules/electron/dist/resources/default_app.asar/main.js:110:16)
                      at Object.<anonymous> (/home/sam/MagicMirror/node_modules/electron/dist/resources/default_app.asar/main.js:222:9)
                      at Module._compile (internal/modules/cjs/loader.js:1152:30)
                  and npm config:check says
                  (base) sam@sams:~/MagicMirror$ npm run config:check
                  > magicmirror@2.15.0 config:check /home/sam/MagicMirror
                  > node js/check_config.js
                  [24.04.2021 15:25.20.258] [INFO]  Checking file...  /home/sam/MagicMirror/config/config.js
                  [24.04.2021 15:25.20.270] [ERROR] Your configuration file contains syntax errors :(
                  [24.04.2021 15:25.20.270] [ERROR] Line 56 column 7: Parsing error: Unexpected token {
                  shorter answer, u are missing a }
                    CheapDad @sdetweil
                    @sdetweil That’s the strange thing, I’m not getting any errors when I run npm run config:check.
                    Unfortunately, I had to rebuild my config.js since I installed a module, edited config.js and ended up with a blank screen that no commenting the config.js entries didn’t fix.
                    Here’s the new (old) compliments entries:
                    			config:  {
                    				compliments: {
                    And my npm run config:check:
                    pi@emmasmagicmirror:~/MagicMirror $ npm run config:check
                    > magicmirror@2.15.0 config:check /home/pi/MagicMirror
                    [24.04.2021 16:58.15.197] [INFO]  Checking file...  /home/pi/MagicMirror/config/config.js
                    [24.04.2021 16:58.15.352] [INFO]  Your configuration file doesn't contain syntax errors :)
                      sdetweil @CheapDad
                      @cheapdad
                      the thing is
                          module:"name",
                          position:"...",
                              compliments: {
                              }   //< ---- this brace is missing
                      get bitvise ssh client, then u can have a file manager view from windows
                      and use notepad++ to edit  and see the  brace, paren and bracket matching
                        CheapDad
                        Forgive me for pursuing this, but I see an opportunity to really learn here. When I look at my code, I have closed all of my braces:
                        			config:  {  \\ open
                        				compliments: {  \\open
                        		}   \\close
                        	}, \\close
                        			module: "weather",
                        If I add another closing brace, won’t I have an error because there is no opening brace?
                        On the suggestion for bitvise ssh, I’m working directly off the pi itself. I would love to run the entire MM configuration in a vm until it is right and then simply copy that over to the pi, but that’s a bit beyond my knowledge level.
                          sdetweil @CheapDad
                          @cheapdad u are missing the open brace for the module block in this last picture (see my layout above)
                          if you use bitvise then u dont have to edit ON the pi keyboard…
                          also gives u an ssh window to execute commands, again NOT on the pi keyboard
                          u can run raspian x86 in a vm on pc…
                            CheapDad
                            I think I figured it out and see where I needed a third closing brace. The weird thing is that Compliments seems to be the only module that doesn’t start with an opening brace, where all the others appear to. If I add an opening brace to it, I get an error. If I leave it out, it runs.
                              sdetweil @CheapDad
                              @cheapdad EVERY module MUST start with an opening brace…
                              ignore any typos you find somewhere else…
                              see my module diagram above
                                CheapDad @sdetweil
                                @sdetweil Got it.
                                  sdetweil @CheapDad
                                  @cheapdad I sent u a chat message
