    CANNOT ADD MODULES
    14 Posts 7 Posters 6.3k Views 6 Watching
      anhanyoung
      @mykle1
      Thank you. I have been using your tutorials all night. It has helped me get to where I am. I tried folllowing these steps for different modules and it didn’t seem to work for me
        anhanyoung
        What does Expected ‘]’ to match ‘[’ from line 45 and instead saw ‘:’.
        75 Expected ‘}’ to match ‘{’ from line 28 and instead saw 'MMM-lyft mean?
          sdetweil @anhanyoung
          @anhanyoung means u are missing comma, " or something… confused the parser…
          • evroomE Offline
            evroom
            For beginners, the catchphrase is “JSON syntax”.
            There are many articles to be found, both short and lengthy.
            A small article would be:
            https://restfulapi.net/json-syntax/
            The main things to look for in your config.js file are:
            • does every [ have a matching ]
            • are all arrays separated by a , (the last array does not need a ,)
            • does every { have a matching }
            • are all objects separated by a , (the last object does not need a ,)
            • is every name value pair separated by a ,
            The syntax checker will try to find out if this syntax is correct and tries to predict where the error could be.
            So, when it says it saw a [ and it cannot find a matching ] it tells you what was expected and what it saw.
            Try to format you config.js to make it more visible.
            For example this:
            is better written like this:
            Pairs of [ ]and { } are better visible like this.
            Good luck :-)
            MagicMirror version: 2.33.0
            Test environment:
            MagicMirror version: v2.33.0
