    MMM-DWD-WarnWeather - Wetterwarnungen
    62 Posts 27 Posters 79.2k Views 28 Watching
    • LukeCodewalkerL
      LukeCodewalker Module Developer
      Hi guys !
      Here’s my first MagicMirror² module which shows you weather-warnings from Deutscher Wetterdienst for your location in germany.
      [card:LukeSkywalker92/MMM-DWD-WarnWeather]
      Hope you’ll enjoy it ! :)
      LukeCodewalkerL C 2 Replies Last reply
      Reply Quote 6
      • LukeCodewalkerL
        LukeCodewalker Module Developer @LukeCodewalker
        Here’s a small preview:
        Reply Quote 1
        • O
          ostfilinchen
          Hi @LukeCodewalker! Great Module and i like it. But something is wrong with the css. If I have more than 1 Module on one position, than it’s to width. That didn’t look good.
          Can u please check this?
          Daniel
          LukeCodewalkerL 1 Reply Last reply
          • LukeCodewalkerL
            Hey,
            i did no debugging yet.
            I will Check that soon and will inform you when its fixed.
            Maybe you can Start an issue.
            • LukeCodewalkerL
              LukeCodewalker Module Developer @ostfilinchen
              Hey @ostfilinchen,
              css should be fixed now.
              Can you please check it?
              O 1 Reply Last reply
              • O
                ostfilinchen @LukeCodewalker
                @LukeCodewalker: it’s better but always the width is to great.
                And now, no warnings would be loaded. It stops with “Warnungen werden geladen”. It must Display “keine Warnungen”, because there’re no warnings.
                • LukeCodewalkerL
                  @ostfilinchen : ok, now everything should be fine.
                  could you please check that?
                  Thanks for your help =)
                  • O
                    ostfilinchen
                    now it Looks good. One Correction please. Can u Change the Headline to the Standard like calender and so on? In the pic of my post i mean the Headline “1. Bundesliga 2016/2017”.
                    I have commented out line 56-60 in MMM-DWD-WarnWeather.js. And in my custom.css i add these lines:
                    .MMM-DWD-WarnWeather div.displaytitle {
                    text-transform: uppercase;
                    font-size: 15px;
                    font-family: “Roboto Condensed”;
                    border-bottom: 1px solid #666;
                    line-height: 15px;
                    padding-bottom: 5px;
                    margin-bottom: 10px;
                    color: white;
                    LukeCodewalkerL lolobyteL 2 Replies Last reply
                    • LukeCodewalkerL
                      @ostfilinchen : done =)
                      • LukeCodewalkerL
                        So that’s how it looks now.
                        Reply Quote 1
                        • O
                          ostfilinchen
                          Thanks! Great job
                          • LukeCodewalkerL
                            I made some small changes to the formatting of the date. It now looks like this:
                            • T
                              tajno
                              Nice work and thanks for shareing!
                              Does the german wheater forecast provide an API? Are those warnings for a special region or a general broadcast for your state (Bundesland)?
                              I think I have look if the Swiss guys does too, usually they provide alot of datas (ch opendata) - Need those warnings too, especially for snow/icy conditions :).
                              • LukeCodewalkerL
                                LukeCodewalker Module Developer @tajno
                                Hey @tajno,
                                they don’t really provide an API. I did a bit of reverse engineering on their website and found that you can get a JSON file with all the warnings for Germany for a specific time.
                                This JSON contains warnings for all regions (Landkreise) of Germany.
                                If you find an API for Switzerland I can help you to implement it.
                                J 1 Reply Last reply
                                Reply Quote 1
                                • J
                                  Jopyth Moderator @LukeCodewalker
                                  @LukeCodewalker Very interesting module, will you add this to the wiki as well?
                                  Also why did you make a custom header? Wouldn’t it be better to use the default header functionality?
                                  Helpful sticky: How to troubleshoot
                                  Reply Quote 1
                                  • LukeCodewalkerL
                                    LukeCodewalker Module Developer @Jopyth
                                    @Jopyth Thank you. Yes I will add it.
                                    Sure I will fix it soon.
                                    Reply Quote 1
                                    • LukeCodewalkerL
                                      @weedorbeat good idea. I’ll put that on my list.
                                      • LukeCodewalkerL
                                        @weedorbeat hey,
                                        do you have an idea, how the warnings should show for which region they are? Just making a header for each region would not be very nice in my opinion. My first idea was to put the region in brackets behind the warning. But i definitely want to keep the appearance of the module very simple/small. Another thing I want to implement is the starting altitude of the warning (like “Schneefall ab 400m”). But there i have the same problem: I don’t had an idea how to display it with keeping the module looking nice.
                                        strawberry 3.141S 1 Reply Last reply
                                        • strawberry 3.141S
                                          strawberry 3.141 Project Sponsor Module Developer @LukeCodewalker
                                          @LukeCodewalker to display different things in a module, i implemented kind of caroussels in a couple of my modules to show only one part per time interval e.g. 20 seconds. this will result in a small display but can handle a lot of informations. in the develop branch is a new feature to extend the header defined by the user with custom values. you could add there the region.
                                          • LukeCodewalkerL
                                            Ok now it looks like this:
                                            It’s using the default header functionality now.
                                            To have more than one region you have to put the module two times in your config like
                                            	module: 'MMM-DWD-WarnWeather',
                                            	position: 'bottom_left',
                                            	header: 'Oberbergischer Kreis',
                                            		region: 'Oberbergischer Kreis',
                                            		changeColor: true,
                                            		interval: 10*60*1000
                                            	header: 'Kreis Deggendorf',
                                            		region: 'Kreis Deggendorf',
                                            		changeColor: true,
                                            • 1 / 4
