    MMM-DWD-WarnWeather - Wetterwarnungen
    62 Posts 27 Posters 69.0k Views 28 Watching
    • lolobyteL Offline
      lolobyte @schmo90
      @schmo90
      the answer is above your message…
        schmo90
        Yeah i see. But maybe there is someone from austria who did already that changes ;-)
        • pjkoelemanP Offline
          pjkoeleman
          Same question here.
          Is threre already someone who has made this for the Dutch weather forecast (KNMI waarschuwingen).
          I could not find the weather data on the site of the KNMI, so now i start looking how to get that data!
          I’am not a programmer but wil give it a try !!!
            birdy
            so this module is showing only warnings. Can it show also the weather from DWD?
            Cheers
            birdy
              m0bed
              Hello I updated this modul with git pull and npm install.
              It workes quit well but now it always say “Ort nicht gefunden”.
              I checked the map an changed the name to the “DWD-NAME” for my home town.
              What I’m doing wrong?
              Thanks Daniel
              MrCoffeeM 1 Reply Last reply Reply Quote 0
              • MrCoffeeM Offline
                MrCoffee @m0bed
                @m0bed
                I had the same issue.
                However, before the update “Region Hannover” worked well.
                Now after the update I had to change to “Hannover” without region which shows the weather for the city of Hannover instead of the region.
                So I guess you DWD-Name must be wrong.
                Maybe you might give another city a try, just to check the modul.
                Greetings.
                Mr.Coffee
                  m0bed @MrCoffee
                  @MrCoffee Hello,
                  thank you for your advise.
                  I dont know what has happed but let it run for over 24 hours and now it works.
                  Still after 12h it was showing “ORT NICHT GEFUNDEN”.
                  But today at the morning it worked as it was supposed.
                  Thank you for support.
                  Thanks Daniel
                    Matthes0815
                    Could you maybe remove the modules header or make it fully configurable or include an option to deactivate it?
                    Right now I can choose between “Wetterwarnungen” or “Wetterwarnungen: LineBreak Regionname”. The line break is annoying and I want to be able to set my own text.
                    Modules shouldn’t force a header…
                      anf
                      since a short time the DW Warn Weather modul does not load anymore here my config:
                      	module: 'MMM-DWD-WarnWeather',
                      			position: 'bottom_right',
                      			header: '',
                      				lat: 51.15667,
                      				lng: 7.192478,
                      				changeColor: true,
                      				minutes: false,
                      				displayRegionName: false,
                      				interval: 10 * 60 * 1000, // every 10 minutes
                      				loadingText: 'Lade DWD ...',
                      				noWarningText: 'Keine Warnungen'
                      Always the Message ist “Ort nicht gefunden” und “Lade DWD …”
                      Any Ideas ?
                      Thx for feedback
                      AnF
                      • Sandy2503S Offline
                        Sandy2503
                        Hi Anf,
                        after updating the MMM-DWD-WarnWeather Module i had the issues.
                        I have no Lat & Lng Settings. My Location is --> region --> Stadt Wuppertal.
                        After Update i change the Region to Wuppertal and it works again.
                                                module: "MMM-DWD-WarnWeather",
                                                position: "bottom_right",
                                                header: "Deutscher Wetterdienst",
                                                        region: "Wuppertal",
                                                        longversion: true
                        This is my setting. Maybe it will help you.
                        Sandy2503
                        • 6
                        • 7
                        • 5 / 7
