    MMM-DWD-WarnWeather - Wetterwarnungen
    62 Posts 27 Posters 78.8k Views 28 Watching
    • L
      lolobyte @schmo90
      @schmo90
      the answer is above your message…
        schmo90
        Yeah i see. But maybe there is someone from austria who did already that changes ;-)
        • P
          pjkoeleman
          Same question here.
          Is threre already someone who has made this for the Dutch weather forecast (KNMI waarschuwingen).
          I could not find the weather data on the site of the KNMI, so now i start looking how to get that data!
          I’am not a programmer but wil give it a try !!!
          • B
            birdy
            so this module is showing only warnings. Can it show also the weather from DWD?
            Cheers
            birdy
            • M
              m0bed
              Hello I updated this modul with git pull and npm install.
              It workes quit well but now it always say “Ort nicht gefunden”.
              I checked the map an changed the name to the “DWD-NAME” for my home town.
              What I’m doing wrong?
              Thanks Daniel
              MrCoffeeM 1 Reply Last reply
              • MrCoffeeM
                MrCoffee @m0bed
                @m0bed
                I had the same issue.
                However, before the update “Region Hannover” worked well.
                Now after the update I had to change to “Hannover” without region which shows the weather for the city of Hannover instead of the region.
                So I guess you DWD-Name must be wrong.
                Maybe you might give another city a try, just to check the modul.
                Greetings.
                Mr.Coffee
                • M
                  m0bed @MrCoffee
                  @MrCoffee Hello,
                  thank you for your advise.
                  I dont know what has happed but let it run for over 24 hours and now it works.
                  Still after 12h it was showing “ORT NICHT GEFUNDEN”.
                  But today at the morning it worked as it was supposed.
                  Thank you for support.
                  Thanks Daniel
                  • M
                    Matthes0815
                    Could you maybe remove the modules header or make it fully configurable or include an option to deactivate it?
                    Right now I can choose between “Wetterwarnungen” or “Wetterwarnungen: LineBreak Regionname”. The line break is annoying and I want to be able to set my own text.
                    Modules shouldn’t force a header…
                    • A
                      anf
                      since a short time the DW Warn Weather modul does not load anymore here my config:
                      	module: 'MMM-DWD-WarnWeather',
                      			position: 'bottom_right',
                      			header: '',
                      				lat: 51.15667,
                      				lng: 7.192478,
                      				changeColor: true,
                      				minutes: false,
                      				displayRegionName: false,
                      				interval: 10 * 60 * 1000, // every 10 minutes
                      				loadingText: 'Lade DWD ...',
                      				noWarningText: 'Keine Warnungen'
                      Always the Message ist “Ort nicht gefunden” und “Lade DWD …”
                      Any Ideas ?
                      Thx for feedback
                      AnF
                      • Sandy2503S
                        Sandy2503
                        Hi Anf,
                        after updating the MMM-DWD-WarnWeather Module i had the issues.
                        I have no Lat & Lng Settings. My Location is --> region --> Stadt Wuppertal.
                        After Update i change the Region to Wuppertal and it works again.
                                                module: "MMM-DWD-WarnWeather",
                                                position: "bottom_right",
                                                header: "Deutscher Wetterdienst",
                                                        region: "Wuppertal",
                                                        longversion: true
                        This is my setting. Maybe it will help you.
                        Sandy2503
                        • A
                          anf
                          Hi Sandy,
                          yes region: “Wuppertal” works now i struggle beause i have a “ö” in the region and all maskings e.g. oe or o or ö or \oe does not work.
                          Any ideas ?
                          Thx for feedback
                          AnF
                            snoopy78 @anf
                            @anf did you got a solution?
                            i’ve got the same issue about an “ö” in my cities name
                            • W
                              wilbur245
                              Hallo ich bekomme immer die Meldung das ein Update für das Modul vorliegt…wie kann ich das Modul updaten?
                              Ich habe es neu Installiert aber das Brachte nichts.
                              Google Translate
                              Hello I always get the message that there is an update for the module … how can I update the module?
                              I reinstalled it but it didn’t work.
                                sdetweil @wilbur245
                                @wilbur245
                                to update a module
                                cd ~/MagicMirror/modules/??? (modulename)
                                git pull
                                if the module has a package.json, it is recommended to also do
                                npm install   in the module folder
                                W 1 Reply Last reply
                                • W
                                  wilbur245 @sdetweil
                                  @sdetweil Thank you very much
                                  It worked
                                  • M
                                    MajorC Project Sponsor
                                    thank you for this wonderful MMM. Is there a way to hide the hole module if no warnings are present at the moment? That would give me some needed space on the mirror.
                                    Thank you.
                                    • M
                                      MacG @MajorC
                                      @majorc said in MMM-DWD-WarnWeather - Wetterwarnungen:
                                      … Is there a way to hide the hole module if no warnings are present at the moment? …
                                      I would want to have that as well. ;)
                                      Reply Quote 1
                                        Sebi76
                                        Hello,
                                        this is my Problem after i update MagicMirror.
                                        [20.10.2021 11:13.03.190] [ERROR] WARNING! Could not load config file. Starting with default configuration. Error found: Error: Cannot find module ‘request’
                                        Require stack:
                                        • /home/pi/MagicMirror/modules/MMM-DWD-WarnWeather/node_helper.js
                                        • /home/pi/MagicMirror/js/app.js
                                        • /home/pi/MagicMirror/js/electron.js
                                        • /home/pi/MagicMirror/node_modules/electron/dist/resources/default_app.asar/main.js
                                        This “default_app.asar/” is only a file not a Folder!
                                        mumblebajM 1 Reply Last reply
                                        • mumblebajM
                                          mumblebaj Module Developer @Sebi76
                                          @sebi76 request is no longer a default module. You have to go into the MMM-DWD-WarnWeather module folder and perform the following steps
                                          npm init -y
                                          npm install request --save
                                          This should solve the issue.
                                          • H
                                            Harald-999
                                            The module no longer runs since the last version of MagicMirror² v2.25.0. MM2 gets stuck at startup.
                                            • 3 / 4
