    MMM-DWD-WarnWeather - Wetterwarnungen
    62 Posts 27 Posters 76.8k Views 28 Watching
    • L Offline
      LukeCodewalker Module Developer @lolobyte
      @lolobyte
      for increasing the text size you have to edit MMM-DWD-Warnweather.css (description class).
      to format the date you have to edit lines 84 and 85:
      var start = moment(this.warnings[i]['start']).format("dd. HH") + ' Uhr';
      var end = moment(this.warnings[i]['end']).format("dd. HH") + ' Uhr';
      • L Offline
        lolobyte @LukeCodewalker
        @LukeCodewalker
        Hi, thank you for your answer.
        this is a part of my custom.css
        .MMM-DWD-WarnWeather .description {
        font-family: Roboto;
        margin-left: 10px;
        color: white; //white
        padding-left: 50px;
        padding-top: 3px;
        color: #fff; //fff
        width: auto;
        font-size: 25px;
        line-height: 30px;
        text-align: left;
        i can make some changes, but not wit all commands.
        for example.
        if i use
        color: red;
        nothing changes
        when i use
        color: #f00; //fff
        the color change.
        if is try to use
            font-size: 10px;
            line-height: 10px;
        nothing happens.
        What’s wrong?
          pugsly
          Can this be modified to work in the US?
          • L Offline
            LukeCodewalker Module Developer @pugsly
            @pugsly
            Sure. You have to find an API that gives you the data and you have to modify the module that it works with this data.
              schmo90
              Hy
              is there a way to show the warnings for regions in austria?
              • L Offline
                lolobyte @schmo90
                @schmo90
                the answer is above your message…
                  schmo90
                  Yeah i see. But maybe there is someone from austria who did already that changes ;-)
                    pjkoeleman
                    Same question here.
                    Is threre already someone who has made this for the Dutch weather forecast (KNMI waarschuwingen).
                    I could not find the weather data on the site of the KNMI, so now i start looking how to get that data!
                    I’am not a programmer but wil give it a try !!!
                      birdy
                      so this module is showing only warnings. Can it show also the weather from DWD?
                      Cheers
                      birdy
                        m0bed
                        Hello I updated this modul with git pull and npm install.
                        It workes quit well but now it always say “Ort nicht gefunden”.
                        I checked the map an changed the name to the “DWD-NAME” for my home town.
                        What I’m doing wrong?
                        Thanks Daniel
                        MrCoffeeM 1 Reply Last reply Reply Quote 0
                        • MrCoffeeM Offline
                          MrCoffee @m0bed
                          @m0bed
                          I had the same issue.
                          However, before the update “Region Hannover” worked well.
                          Now after the update I had to change to “Hannover” without region which shows the weather for the city of Hannover instead of the region.
                          So I guess you DWD-Name must be wrong.
                          Maybe you might give another city a try, just to check the modul.
                          Greetings.
                          Mr.Coffee
                            m0bed @MrCoffee
                            @MrCoffee Hello,
                            thank you for your advise.
                            I dont know what has happed but let it run for over 24 hours and now it works.
                            Still after 12h it was showing “ORT NICHT GEFUNDEN”.
                            But today at the morning it worked as it was supposed.
                            Thank you for support.
                            Thanks Daniel
                              Matthes0815
                              Could you maybe remove the modules header or make it fully configurable or include an option to deactivate it?
                              Right now I can choose between “Wetterwarnungen” or “Wetterwarnungen: LineBreak Regionname”. The line break is annoying and I want to be able to set my own text.
                              Modules shouldn’t force a header…
                                anf
                                since a short time the DW Warn Weather modul does not load anymore here my config:
                                	module: 'MMM-DWD-WarnWeather',
                                			position: 'bottom_right',
                                			header: '',
                                				lat: 51.15667,
                                				lng: 7.192478,
                                				changeColor: true,
                                				minutes: false,
                                				displayRegionName: false,
                                				interval: 10 * 60 * 1000, // every 10 minutes
                                				loadingText: 'Lade DWD ...',
                                				noWarningText: 'Keine Warnungen'
                                Always the Message ist “Ort nicht gefunden” und “Lade DWD …”
                                Any Ideas ?
                                Thx for feedback
                                AnF
                                • Sandy2503S Offline
                                  Sandy2503
                                  Hi Anf,
                                  after updating the MMM-DWD-WarnWeather Module i had the issues.
                                  I have no Lat & Lng Settings. My Location is --> region --> Stadt Wuppertal.
                                  After Update i change the Region to Wuppertal and it works again.
                                                          module: "MMM-DWD-WarnWeather",
                                                          position: "bottom_right",
                                                          header: "Deutscher Wetterdienst",
        region: "Wuppertal",
        longversion: true
                                  This is my setting. Maybe it will help you.
                                  Sandy2503
                                    anf
                                    Hi Sandy,
                                    yes region: “Wuppertal” works now i struggle beause i have a “ö” in the region and all maskings e.g. oe or o or ö or \oe does not work.
                                    Any ideas ?
                                    Thx for feedback
                                    AnF
                                      snoopy78 @anf
                                      @anf did you got a solution?
                                      i’ve got the same issue about an “ö” in my cities name
                                      • W Offline
                                        wilbur245
                                        Hallo ich bekomme immer die Meldung das ein Update für das Modul vorliegt…wie kann ich das Modul updaten?
                                        Ich habe es neu Installiert aber das Brachte nichts.
                                        Google Translate
                                        Hello I always get the message that there is an update for the module … how can I update the module?
                                        I reinstalled it but it didn’t work.
                                          sdetweil @wilbur245
                                          @wilbur245
                                          to update a module
                                          cd ~/MagicMirror/modules/??? (modulename)
                                          git pull
                                          if the module has a package.json, it is recommended to also do
                                          npm install   in the module folder
                                          • W Offline
                                            wilbur245 @sdetweil
                                            @sdetweil Thank you very much
                                            It worked
                                            • 3 / 4
