    MMM-DWD-WarnWeather - Wetterwarnungen
    62 Posts 27 Posters 78.6k Views 28 Watching
    • MrCoffeeM
      MrCoffee @m0bed
      @m0bed
      I had the same issue.
      However, before the update “Region Hannover” worked well.
      Now after the update I had to change to “Hannover” without region which shows the weather for the city of Hannover instead of the region.
      So I guess you DWD-Name must be wrong.
      Maybe you might give another city a try, just to check the modul.
      Greetings.
      Mr.Coffee
      M 1 Reply Last reply
        m0bed @MrCoffee
        @MrCoffee Hello,
        thank you for your advise.
        I dont know what has happed but let it run for over 24 hours and now it works.
        Still after 12h it was showing “ORT NICHT GEFUNDEN”.
        But today at the morning it worked as it was supposed.
        Thank you for support.
        Thanks Daniel
          Matthes0815
          Could you maybe remove the modules header or make it fully configurable or include an option to deactivate it?
          Right now I can choose between “Wetterwarnungen” or “Wetterwarnungen: LineBreak Regionname”. The line break is annoying and I want to be able to set my own text.
          Modules shouldn’t force a header…
          • A
            anf
            since a short time the DW Warn Weather modul does not load anymore here my config:
            	module: 'MMM-DWD-WarnWeather',
            			position: 'bottom_right',
            			header: '',
            				lat: 51.15667,
            				lng: 7.192478,
            				changeColor: true,
            				minutes: false,
            				displayRegionName: false,
            				interval: 10 * 60 * 1000, // every 10 minutes
            				loadingText: 'Lade DWD ...',
            				noWarningText: 'Keine Warnungen'
            Always the Message ist “Ort nicht gefunden” und “Lade DWD …”
            Any Ideas ?
            Thx for feedback
            AnF
            • Sandy2503S
              Sandy2503
              Hi Anf,
              after updating the MMM-DWD-WarnWeather Module i had the issues.
              I have no Lat & Lng Settings. My Location is --> region --> Stadt Wuppertal.
              After Update i change the Region to Wuppertal and it works again.
                                      module: "MMM-DWD-WarnWeather",
                                      position: "bottom_right",
                                      header: "Deutscher Wetterdienst",
                                              region: "Wuppertal",
                                              longversion: true
              This is my setting. Maybe it will help you.
              Sandy2503
              • A
                anf
                Hi Sandy,
                yes region: “Wuppertal” works now i struggle beause i have a “ö” in the region and all maskings e.g. oe or o or ö or \oe does not work.
                Any ideas ?
                Thx for feedback
                AnF
                  snoopy78 @anf
                  @anf did you got a solution?
                  i’ve got the same issue about an “ö” in my cities name
                  • W
                    wilbur245
                    Hallo ich bekomme immer die Meldung das ein Update für das Modul vorliegt…wie kann ich das Modul updaten?
                    Ich habe es neu Installiert aber das Brachte nichts.
                    Google Translate
                    Hello I always get the message that there is an update for the module … how can I update the module?
                    I reinstalled it but it didn’t work.
                      sdetweil @wilbur245
                      @wilbur245
                      to update a module
                      cd ~/MagicMirror/modules/??? (modulename)
                      git pull
                      if the module has a package.json, it is recommended to also do
                      npm install   in the module folder
                      W 1 Reply Last reply
                      • W
                        wilbur245 @sdetweil
                        @sdetweil Thank you very much
                        It worked
                          MajorC Project Sponsor
                          thank you for this wonderful MMM. Is there a way to hide the hole module if no warnings are present at the moment? That would give me some needed space on the mirror.
                          Thank you.
                            MacG @MajorC
                            @majorc said in MMM-DWD-WarnWeather - Wetterwarnungen:
                            … Is there a way to hide the hole module if no warnings are present at the moment? …
                            I would want to have that as well. ;)
                              Sebi76
                              this is my Problem after i update MagicMirror.
                              [20.10.2021 11:13.03.190] [ERROR] WARNING! Could not load config file. Starting with default configuration. Error found: Error: Cannot find module ‘request’
                              Require stack:
                              • /home/pi/MagicMirror/modules/MMM-DWD-WarnWeather/node_helper.js
                              This “default_app.asar/” is only a file not a Folder!
                              mumblebajM 1 Reply Last reply
                              • mumblebajM
                                mumblebaj Module Developer @Sebi76
                                @sebi76 request is no longer a default module. You have to go into the MMM-DWD-WarnWeather module folder and perform the following steps
                                npm init -y
                                npm install request --save
                                This should solve the issue.
                                • H
                                  Harald-999
                                  The module no longer runs since the last version of MagicMirror² v2.25.0. MM2 gets stuck at startup.
                                    sdetweil @Harald-999
                                    @Harald-999 update the module, they made a fix
                                    go to the module folder
                                    git pull
                                    npm install
                                      Chazzer @LukeCodewalker
                                      @LukeCodewalker Great Work, Thank you for build it.
                                      • good description
                                      • it works fine for me
                                      • now, I dont habe warn weathy entries :-)
                                      • 3 / 4
