    MMM-DWD-WarnWeather - Wetterwarnungen
    62 Posts 27 Posters 77.3k Views 28 Watching
      anf
      Hi Sandy,
      yes region: “Wuppertal” works now i struggle beause i have a “ö” in the region and all maskings e.g. oe or o or ö or \oe does not work.
      Any ideas ?
      Thx for feedback
      AnF
        snoopy78 @anf
        @anf did you got a solution?
        i’ve got the same issue about an “ö” in my cities name
        • W Offline
          wilbur245
          Hallo ich bekomme immer die Meldung das ein Update für das Modul vorliegt…wie kann ich das Modul updaten?
          Ich habe es neu Installiert aber das Brachte nichts.
          Google Translate
          Hello I always get the message that there is an update for the module … how can I update the module?
          I reinstalled it but it didn’t work.
            sdetweil @wilbur245
            @wilbur245
            to update a module
            cd ~/MagicMirror/modules/??? (modulename)
            git pull
            if the module has a package.json, it is recommended to also do
            npm install   in the module folder
            • W Offline
              wilbur245 @sdetweil
              @sdetweil Thank you very much
              It worked
                MajorC Project Sponsor
                thank you for this wonderful MMM. Is there a way to hide the hole module if no warnings are present at the moment? That would give me some needed space on the mirror.
                Thank you.
                  MacG @MajorC
                  @majorc said in MMM-DWD-WarnWeather - Wetterwarnungen:
                  … Is there a way to hide the hole module if no warnings are present at the moment? …
                  I would want to have that as well. ;)
                    Sebi76
                    this is my Problem after i update MagicMirror.
                    [20.10.2021 11:13.03.190] [ERROR] WARNING! Could not load config file. Starting with default configuration. Error found: Error: Cannot find module ‘request’
                    Require stack:
                    • /home/pi/MagicMirror/modules/MMM-DWD-WarnWeather/node_helper.js
                    This “default_app.asar/” is only a file not a Folder!
                    • mumblebajM Offline
                      mumblebaj Module Developer @Sebi76
                      @sebi76 request is no longer a default module. You have to go into the MMM-DWD-WarnWeather module folder and perform the following steps
                      npm init -y
                      npm install request --save
                      This should solve the issue.
                      • H Offline
                        Harald-999
                        The module no longer runs since the last version of MagicMirror² v2.25.0. MM2 gets stuck at startup.
                          sdetweil @Harald-999
                          @Harald-999 update the module, they made a fix
                          go to the module folder
                          git pull
                          npm install
                            Chazzer @LukeCodewalker
                            @LukeCodewalker Great Work, Thank you for build it.
                            • good description
                            • it works fine for me
                            • now, I dont habe warn weathy entries :-)
                            • 3 / 4
