    MMM-Coinbase
    7 Posts 5 Posters 2.6k Views 6 Watching
    • ? Offline
      A Former User
      MMM-Coinbase
      A module for Michael Teeuw’s MagicMirror project that displays your Bitcoin Coinbase balance.
      How it works
      After installing the module and configuring the Coinbase API with your account, the module displays your Bitcoin balance in real time. It is updated every 5 seconds.
      Screenshot
      Prerequisites
      • MagicMirror2
      • Node.js
      • npm
      • Coinbase account
      Installing
      Installing the module is quite straight forward
      Step 1 - Install the module
      cd ~/MagicMirror/modules
      git clone https://github.com/XC2DN/MMM-Coinbase.git
      cd MMM-Coinbase
      npm install
      Step 2 - Create your coinbase API keys
      "Step-1" "Step-2" "Step-3"
      Go to API Access
      Click + New API Key
      Check BTC Wallet and wallet:accounts:read
      "Step-4" "Step-5"
      Click Create
      Copy API Key and API Secret Key
      Step 3 - Add module to ~MagicMirror/config/config.js
      Add this configuration into config.js file’s
          module: "MMM-Coinbase",
          position: "top_left", // put it where you want it
          header: "Coinbase", // optional
                  apiKey: "YOUR API KEY", // the key previously copied
                  apiSecret: "YOUR API SECRET KEY" // the secret key previously copied
      Updating
      Go to the module’s folder inside MagicMirror modules folder and pull the latest version from GitHub and install:
      git pull
      npm install
      Configuring
      Here is the configurable part of the module
      Option Description
      apiKey API Key from Coinbase.
      Type: string REQUIRED
      Example:1iO5VjY2bdC3HucJ
      Default value: none
      apiSecret API Secret Key from Coinbase.
      Example:OwABcDaA5fxK3QTV3gjwvOk358juuXti
      Default value: none
      Use
      Now you can fully use MagicMirror and the MMM-Coinbase module to display your wallet ! Enjoy it well !
      Contributing
      If you find any problems, bugs or have questions, please open a GitHub issue in this repository.
      • yawnsY Offline
        yawns Moderator
        Looks good. And many thanks for such a well structured module description
          Seann Module Developer @Guest
          @xc2dn Nice work, might be good to add live currency conversion on there too ;)
          • ? Offline
            A Former User @Seann
            @seann Thank you very much! I discovered MagicMirror yesterday, so this is my first module that will be used for my own mirror! I’ll try to add this feature! Thanks for the advice! :grinning_face:
            • ? Offline
              A Former User @yawns
              @yawns Thank you ! I love it when things are well detailed, so I had to make a nice description.
                Rollacosta82 @Guest
                I agree. It’s nice to see my crypto balance, but it would also be nice to see the balance in US currency; or multiple options. Other than that, great module!
                  adrianreichert
                  Hey, My Tokens and the right Amount are displayed, but somehow not how much it is actually worth. Any Ideas?
