    MMM-Compliments doesn't load
    16 Posts 5 Posters 6.9k Views 5 Watching
      sdetweil @Anthony
      @anthony can u mark your problem resolved please
        Anthony Project Sponsor @sdetweil
        Whatever module you use (default compliments or MMM-Compliments for not crowding your config.js with a big array you can create a json file containing the array with the compliments you want and save it in your compliments folder. After that you must edit your config.js for the compliments module to target that json you created by adding the line remoteFile: "your_file's_name.json", under the config: {. If you don’t have a programm to create the .json file you can do it on line.
          sdetweil
          I understand… but this shows as not solved…
          click the 3 dots to the right of one of your posts, select ‘mark this post as the correct answer’.
          I cannot, as you are the topic owner
            My mistake. Sorry. I will Mark the topic as solved right now! Thank you.
              stuartiannaylor @lavolp3
              @lavolp3
              classes: ‘small’,
              remoteFile: ‘xxxxx.json’,
              updateInterval: 126060*1000,
              Is that all you need to do to partition config.js?
              As that is a top tip and ‘small’ ? remoteFile: can that be a local folder such as the corresponding modules folder?
              • lavolp3L Offline
                lavolp3 Module Developer @stuartiannaylor
                @stuartiannaylor yes that’s all you need in the config part.
                The module entry looks like this for me:
                        //disabled: true,
                        module: "compliments",
                        position: "lower_third",
                            classes: 'small',
                            remoteFile: 'xxxxxxx.json',
                            updateInterval: 12*60*60*1000,
                Dont know what you mean with that. I think you don’t need to give it a class but with this class you can determine the size of the text.
                remoteFile is a file, not a folder. But it can be anywhere, however if it’s not in the module directory you ned to give the absolute path “/home/pi/…”
                How to troubleshoot modules
                MMM-soccer v2, MMM-AVStock
