    YAPi0 Installer Stretch Lite
    118 Posts 4 Posters 100.2k Views 3 Watching
      sdetweil @bdream
      @bdream ok, a few things…
      1. i need to fix the words at the end of install, cause if you said yes to pm2, then don’t do npm start
      2. then u went and did a manual add of another thing for pm2…
      so,
       pm2 stop mm
       pm2 delete mm
      then
      pm2  stop MagicMirror
      then lets try manually
      cd ~/MagicMirror
      npm start
      you should see the messages from the mirror running
      please advise
        bdream
        Thias is you have to work on:
        @sdetweil said in YAPi0 Installer Stretch Lite:
        I do
        pi@RasPiZeroW:~ $  pm2 stop mm
        [PM2][ERROR] Process mm not found
        not necasarry
        pm2 delete mm
        pi@RasPiZeroW:~ $ pm2  stop MagicMirror
        [PM2] Applying action stopProcessId on app [MagicMirror](ids: 0)
        [PM2] [MagicMirror](0) ✓
        │ id │ name               │ mode     │ ↺    │ status   │ cpu      │ memory   │
        │ 0  │ MagicMirror        │ fork     │ 223  │ stopped  │ 0%       │ 0b       │
        pi@RasPiZeroW:~/MagicMirror $ npm start
        > magicmirror@2.9.0 start /home/pi/MagicMirror
        > sh run-start.sh
        nothing happen
        cheers, bdream
          sdetweil @bdream
          @bdream weird… now have same problem on two systems…
          try this
          cd ~/MagicMirror
          node serveronly
          the connection url will be shown
          then connect to that url from a browser on another system
            sdetweil
            another thing to try is
            cd ~/MagicMirror
            export DISPLAY=:0
            node node_modules/.bin/electron
            electron should come up on the screen
              bdream
              no, it dosn’t
              cheers, bdream
                sdetweil @bdream
                @bdream did serveronly mode work?
                  sdetweil @bdream
                  @bdream ok, one more thing to try
                  cd ~/MagicMirror/node_modules
                  mv electron electron.save
                  cd ..
                  npm install electron@latest
                  I am running 6.0.12 on one of my systems
                  then try npm start
                    bdream
                    pi@RasPiZeroW:~/MagicMirror $ npm install electron@latest
                    > electron@6.0.12 postinstall /home/pi/MagicMirror/node_modules/electron
                    > node install.js
                    Downloading tmp-1548-0-electron-v6.0.12-linux-armv6l.zip
                    Error: GET https://github.com/electron/electron/releases/download/v6.0.12/electr                   on-v6.0.12-linux-armv6l.zip returned 404
                    /home/pi/MagicMirror/node_modules/electron/install.js:53
                      throw err
                    Error: Failed to find Electron v6.0.12 for linux-armv6l at https://github.com/el                   ectron/electron/releases/download/v6.0.12/electron-v6.0.12-linux-armv6l.zip
                        at Request.<anonymous> (/home/pi/MagicMirror/node_modules/nugget/index.js:16                   9:61)
                        at Request.emit (events.js:189:13)
                        at Request.onRequestResponse (/home/pi/MagicMirror/node_modules/request/requ                   est.js:1066:10)
                        at ClientRequest.emit (events.js:189:13)
                        at HTTPParser.parserOnIncomingClient [as onIncoming] (_http_client.js:556:21                   )
                        at HTTPParser.parserOnHeadersComplete (_http_common.js:109:17)
                        at TLSSocket.socketOnData (_http_client.js:442:20)
                        at TLSSocket.emit (events.js:189:13)
                        at addChunk (_stream_readable.js:284:12)
                        at readableAddChunk (_stream_readable.js:265:11)
                    npm WARN acorn-jsx@5.1.0 requires a peer of acorn@^6.0.0 || ^7.0.0 but none is i                   nstalled. You must install peer dependencies yourself.
                    npm WARN grunt-stylelint@0.11.1 requires a peer of stylelint@^10.0.0 but none is                    installed. You must install peer dependencies yourself.
                    npm ERR! code ELIFECYCLE
                    npm ERR! errno 1
                    npm ERR! electron@6.0.12 postinstall: `node install.js`
                    npm ERR! Exit status 1
                    npm ERR!
                    npm ERR! Failed at the electron@6.0.12 postinstall script.
                    npm ERR! This is probably not a problem with npm. There is likely additional log                   ging output above.
                    npm ERR!     /home/pi/.npm/_logs/2019-10-18T13_30_31_697Z-debug.log
                    I would like to attach the log, but it’s missing :pouting_face:
                    > sh run-start.sh
                    run-start.sh: 7: run-start.sh: electron: not found
                    npm ERR! syscall spawn
                    npm ERR! file sh
                    npm ERR! errno ENOENT
                    npm ERR! magicmirror@2.9.0 start: `sh run-start.sh`
                    npm ERR! spawn ENOENT
                    npm ERR!
                    npm ERR! Failed at the magicmirror@2.9.0 start script.
                    npm ERR!     /home/pi/.npm/_logs/2019-10-18T14_07_43_211Z-debug.log
                    cheers, bdream
                      bdream
                      @sdetweil how interesting.
                      If I reboot the RPi0 I see MagicMirror booting too. After a while of black screen I get usal Pi Desktop.
                      cheers, bdream
                        sdetweil @bdream
                        @bdream sorry, forgot about arm6l
                        Do
                        npm install --arch=arm7l electron@latest
                        • 6
                        • 7
                        • 8
                        • 9
                        • 10
                        • 11
                        • 12
                        • 8 / 12
