    YAPi0 Installer Stretch Lite
    118 Posts 4 Posters 100.2k Views 3 Watching
    • garblefluxG Offline
      garbleflux Project Sponsor
      @stuartiannaylor said in YAPi0 Installer Stretch Lite:
      pm2 save
      Great job! I ve got it to work - it runs fine on my Pi0!
      Thank you for your great efforts.
      Michael
        stuartiannaylor
        What you can do is add a script line to run-start-sh
        Call it xdotool.sh
        so you would have sh xdotool.sh
        after
        if [ -z "$DISPLAY" ]; then #If not set DISPLAY is SSH remote or tty
        	export DISPLAY=:0 # Set by default display
        fi
        sh xdotool.sh &
        node serveronly $1
        xdotool.sh
        xdotool.sh contains
        export DISPLAY=:0
        sleep 25
        xdotool search --onlyvisible --class "chromium" key ctrl+F5
        The above will make Chromium refresh on any config.js changes or any restart of the server.
        If have been banging my head against a brick xorg / plymouth combination for no reason than to get a smooth splash screen all the way till the browser displays.
        This seems far more trouble than its worth.
        I included lightdm as thought that might make things easier but might drop it as it seems to make no difference and just adds bloat.
        https://www.semicomplete.com/projects/xdotool/ is excellent for external control just haven’t spent much time with it yet with my plymouth waste of time.
          bdream
          @ stuartiannaylor
          That sounds like exacly what I’m looking for :thumbs_up:
          I finished my first MagicMirror and looking for tuning options.
          As exp. I would like to small the case a bit and would be happy to use Rpi0 instead of Rpi3.
          I followed your instruction “MagicMirror-Install-Guide-Raspberry-0-to-3”
          I installed a new raspbian “Raspbian Buster with desktop”
          may this cause my issues not using “Raspbian Buster Lite”?
          I run in problem with command
          cd ~/MagicMirror/ && npm install
          as I got many WARN and ERR messages. I’m not alowed to attach because the file type is .log so I will paste only the WARN and ERR instead of the whole log-file.
          11359 timing action:extract Completed in 111604ms
          11360 silly extract lodash@^4.17.13 extracted to /home/pi/MagicMirror/node_modules/.staging/lodash-dee8f977 (111572ms)
          11361 warn tar ENOENT: no such file or directory, open '/home/pi/MagicMirror/node_modules/.staging/moment-fbf25dd9/min/moment-with-locales.js'
          11362 warn tar ENOENT: no such file or directory, open '/home/pi/MagicMirror/node_modules/.staging/lodash-20df1054/core.min.js'
          11363 warn tar ENOENT: no such file or directory, open '/home/pi/MagicMirror/node_modules/.staging/lodash-24d00653/core.min.js'
          // many similar WARN messages
          12301 warn tar ENOENT: no such file or directory, open '/home/pi/MagicMirror/node_modules/.staging/rrule-21671673/dist/es5/rrule-tz.js.map'
          12302 timing stage:rollbackFailedOptional Completed in 170ms
          12303 timing stage:runTopLevelLifecycles Completed in 545603ms
          12304 silly saveTree magicmirror@2.8.0
          12304 silly saveTree ├─┬ chai-as-promised@7.1.1
          12304 silly saveTree │ └── check-error@1.0.2
          12304 silly saveTree ├─┬ chai@4.2.0
          12304 silly saveTree │ ├── assertion-error@1.1.0
          12304 silly saveTree │   ├── parse-ms@1.0.1
          12304 silly saveTree │   └── plur@1.0.0
          12304 silly saveTree └── valid-url@1.0.9
          12305 warn grunt-stylelint@0.11.1 requires a peer of stylelint@^10.0.0 but none is installed. You must install peer dependencies yourself.
          12306 verbose type system
          12307 verbose stack FetchError: request to https://registry.npmjs.org/valid-url/-/valid-url-1.0.9.tgz failed, reason: getaddrinfo EAI_AGAIN registry.npmjs.org registry.npmjs.org:443
          12307 verbose stack     at ClientRequest.req.on.err (/home/pi/.config/versions/node/v10.16.3/lib/node_modules/npm/node_modules/node-fetch-npm/src/index.js:68:14)
          12307 verbose stack     at ClientRequest.emit (events.js:198:13)
          12307 verbose stack     at TLSSocket.socketErrorListener (_http_client.js:392:9)
          12307 verbose stack     at TLSSocket.emit (events.js:198:13)
          12307 verbose stack     at emitErrorNT (internal/streams/destroy.js:91:8)
          12307 verbose stack     at emitErrorAndCloseNT (internal/streams/destroy.js:59:3)
          12307 verbose stack     at process._tickCallback (internal/process/next_tick.js:63:19)
          12308 verbose cwd /home/pi/MagicMirror
          12309 verbose Linux 4.19.66+
          12310 verbose argv "/home/pi/.config/versions/node/v10.16.3/bin/node" "/home/pi/.config/versions/node/v10.16.3/bin/npm" "install"
          12311 verbose node v10.16.3
          12312 verbose npm  v6.9.0
          12313 error code EAI_AGAIN
          12314 error errno EAI_AGAIN
          12315 error request to https://registry.npmjs.org/valid-url/-/valid-url-1.0.9.tgz failed, reason: getaddrinfo EAI_AGAIN registry.npmjs.org registry.npmjs.org:443
          12316 verbose exit [ 1, true ]
          Any idea :nerd_face: what to do getting the RasPi0 run?
          Hold in mind what happen in case of newer MagicMirror software or other updates need to run automaticly.
          Many thanks, bdream
          cheers, bdream
            sdetweil @bdream
            @bdream try my updated installer, I am working to get this to replace the current version…
            see https://forum.magicmirror.builders/topic/10171/anyone-want-to-try-updated-installer
            others have reported it works ok on Pi zero
            rename the MagicMirror folder or remove it before running the installer
              bdream
              ok, many thanks! :grinning_face: I will try it now.
              Just deleted the MagicMirror folder…
              If I understand you correctly the new script will replace the old one as:
              ~~curl -o- https://raw.githubusercontent.com/creationix/nvm/v0.34.0/install.sh | bash~~
              bash -c "$(curl -sL https://www.dropbox.com/s/rlh710ng0zwv3vp/raspberry.sh?dl=0)"
              but all other in your manual will stay. Right?
              CU, bdream
              cheers, bdream
                sdetweil @bdream
                @bdream the installer also fixes pm2 and the screen saver
                and creates a log of the install process results
                i don’t think u will need the other steps in the pi0 manual anymore
                  bdream
                  thanks for this info, so I know what to do if my attempt to fix first installation only by deleting /MagicMirror and start your script fails :frowning_face: :winking_face:. And it failed :frowning_face:
                  I get a new “Raspbian Buster Lite” now and start again :nerd_face:
                  Will let you know about the outcome. It will take long time :sleeping_face:
                  Best gerads, bdream
                  cheers, bdream
                    sdetweil @bdream
                    @bdream said in YAPi0 Installer Stretch Lite:
                    start your script fails . And it failed
                    please post the contents of ~/install.log
                      bdream
                      Ohh sdetweil, my bad. I overwrote the SD-card already with the new image. I have to learn how to work with forum and being sensitive for upcoming questions/requests.
                      For now I started your script again an it seems it’s running :sleeping_face:
                      I wonder as I have on screen a warning
                      npm WARN npm npm does not support Node.js v10.15.2
                      npm WARN npm You should probably upgrade to a newer version of node as we
                      npm WARN npm can't make promises that npm will work with this version.
                      npm WARN npm Supported releases of Node.js are the latest releases of 4, 6, 7, 8, 9.
                      npm WARN npm You can find the latest version at https://nodejs.org/
                      /usr/local/bin/npm -> /usr/local/lib/node_modules/npm/bin/npm-cli.js
                      /usr/local/bin/npx -> /usr/local/lib/node_modules/npm/bin/npx-cli.js
                      + npm@6.11.3
                      added 430 packages from 833 contributors in 433.321s
                      npm installation Done!
                      Cloning MagicMirror ...
                      Klone nach 'MagicMirror' ...
                      remote: Enumerating objects: 315, done.
                      remote: Counting objects: 100% (315/315), done.
                      remote: Compressing objects: 100% (282/282), done.
                      remote: Total 315 (delta 39), reused 193 (delta 21), pack-reused 0
                      Empangene Obekte: 100% (315/315), 655.08 KiB | 867.00 KiB/s, Fertig.
                      Löse Unterschiede auf: 100% (39/39), Fertig.
                      Cloning MagicMirror Done!
                      Installing dependencies ...
                      > electron-chromedriver@1.8.0 install /home/pi/MagicMirror/node_modules/electron-chromedriver
                      > node ./download-chromedriver.js
                      That is the position cursor is blinking and nothing change since a long time.
                      Here you are the install.log from actual running? installation.
                      install starting  - So Sep 22 18:22:15 CEST 2019
                      installing on armv6l processor system
                      forcing armv71 architecture for pi 0
                      Updating packages ...
                      Installing helper tools ...
                      Check current Node installation ...
                      Node.js is not installed.
                      Installing Node.js ...
                      Node.js installation Done! version=v10.15.2
                      Check current NPM installation ...
                      npm is not installed.
                      Installing npm ...
                      upgrading npm to latest
                      Cheers, bdream
                      cheers, bdream
                        bdream
                        Oh boy, so bad.
                        Maybe I don’t understand what I’m doing here.
                        install.log has not changed but MM ist also not running.
                        After I stopped above stated blinking curser with Ctrl - C
                        I did install MM
                        cd ~/MagicMirror
                        npm install
                        after I did
                        npm install pm@latest -g
                        what failed.
                        I’m :pouting_face:
                        Do I go total wrong way here?
                        Where is my fault?
                        Maybe it’s that I’m not clear in what will your script do and what have I to do additional and in which sequence?
                        Have you any advise to me please?
                        Many thanks fpor your help! bdream
                        cheers, bdream
                        • 6
                        • 7
                        • 8
                        • 9
                        • 10
                        • 11
                        • 12
                        • 7 / 12
