    YAPi0 Installer Stretch Lite
    118 Posts 4 Posters 115.6k Views 3 Watching
      sdetweil @bdream
      @bdream
      you MUST install the graphical UI desktop on the pi, right? MM uses graphics to display the screen.
        bdream
        hmm, I guess I have to investigate about this in a few weeks.
        So far many thanks for your help here. Will have a look later today and see what can I handle. Otherwise later. I have to run for a meeting now.
        cheers, bdream
          bdream
          @sdetweil said in YAPi0 Installer Stretch Lite:
          I wonder. I understood Pi0 don’t need to have UI installed. therefor I installed the light raspbian image - maybe I’m wrong :confounded_face:
          Do I have to install lightdm or other?
          And then I assume use raspi-config to boot to desktop?
          cheers, bdream
            sdetweil @bdream
            @bdream you can do node serveronly , instead of npm start…
            for pm2, edit installers/mm.sh and change npm start to node serveronly
            then pm2 restart 0
            others have had success at running UI on p0 as well…
            make sure u change config/config.js to allow other machines to connect
            to allow all
            address: “”,
            and
            ipWhitelist: [],
              bdream
              Í’m back now and started to work further on my Pi0 with MM installation.
              I tried to get UI desktop running by installing lightdm.
              Then reconfigured Boot option to start Desktopn and Auotologin.
              After reboot, wich looks good, PI starts an give Debian logon screen.
              How to autologon?
              After I put in my credentials pi and raspberry I stuck in login-loop.
              cheers, bdream
                bdream
                Any idea what to do?
                Maybe Pi0 is not the Hardware MM will run good. Especialy in regards to upcoming updates :dizzy_face:
                But this small device will give more oportunities for nice looking projects based on MM :grinning_face_with_smiling_eyes:
                cheers, bdream
                  sdetweil @bdream
                  @bdream others have made it work… you may have to reinstall the base raspian image to get the graphical desktop running properly…
                  I don’t have one of these pi0 devices to test with
                    bdream
                    @sdetweil many thanks for your guidance.
                    I thaught Pi0 must get installed without GUI :worried_face: my fault.
                    I will start again and see what happen.
                    I’ll let you know if success yur script!
                    cheers, bdream
                      sdetweil @bdream
                      @bdream U can run it in serveronly mode
                      Have to edit the installers/mm.sh
                      Or run_start.sh to do
                      node serveronly
                      The use browser from some other system
                        bdream
                        @sdetweil Raspbian Buster with desktop image already written to the sc-card.
                        will see the time I have to work on it next time.
                        Stuff arount serveronly and using other browser is to far from me at the moment :unamused_face:
                        cheers, bdream
                          sdetweil @bdream
                          @bdream ok… there is only one MM install… but two ways to run it… so, no problem
                            bdream
                            @sdetweil many thanks!!
                            cheers, bdream
                              bdream
                              @sdetweil may I come back to you :smiling_face_with_halo:
                              I run new installation from scratch on my Rpi0.
                              Raspian Buster with desktop
                              updated and upgraded and so on
                              run your script
                               bash -c "$(curl -sL https://www.dropbox.com/s/rlh710ng0zwv3vp/raspberry.sh?dl=0)"
                              Node.js installation Done! version=v10.15.2
                              npm WARN npm npm does not support Node.js v10.15.2
                              npm WARN npm You should probably upgrade to a newer version of node as we
                              npm WARN npm can't make any promises that npm will work with this version.
                              npm WARN npm Supported releases of Node.js are the latest release of 4, 6, 7, 8, 9.
                              npm WARN npm You can find the latest version at https://nodejs.org/
                              /usr/local/bin/npm -> /usr/local/lib/node_modules/npm/bin/npm-cli.js
                              /usr/local/bin/npx -> /usr/local/lib/node_modules/npm/bin/npx-cli.js
                              + npm@6.12.0
                              added 430 packages from 839 contributors in 328.327s
                              npm installation Done! version=V6.12.0
                              Cloning MagicMirror Done!
                              Installing dependencies ...
                              npm WARN deprecated time-grunt@2.0.0: Deprecated because Grunt is practically unmaintained. Move on to something better. This package will continue to work with Grunt v1, but it will not receive any updates.
                              > electron-chromedriver@1.8.0 install /home/pi/MagicMirror/node_modules/electron-chromedriver
                              > node ./download-chromedriver.js
                              successfully dowloaded and extracted!
                              > electron@3.0.13 postinstall /home/pi/MagicMirror/node_modules/electron
                              > node install.js
                              Downloading tmp-3996-1-SHASUMS256.txt-3.0.13
                              [============================================>] 100.0% of 4.79 kB (4.79 kB/s)
                              > magicmirror@2.9.0 install /home/pi/MagicMirror
                              > cd vendor && npm install
                              npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@1.2.4 (node_modules/fsevents):
                              npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@1.2.4: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
                              added 82 packages from 57 contributors and audited 220 packages in 139.709s
                              found 5 vulnerabilities (4 low, 1 high)
                                run `npm audit fix` to fix them, or `npm audit` for details
                              > magicmirror@2.9.0 postinstall /home/pi/MagicMirror
                              > sh untrack-css.sh && sh installers/postinstall/postinstall.sh && npm run install-fonts
                              We'll remove from the repository the css/custom.css
                              This script apply git update-index --skip-worktree css/custom.css
                              rm 'css/custom.css'
                              MagicMirror installation successful!
                              > magicmirror@2.9.0 install-fonts /home/pi/MagicMirror
                              > cd fonts && npm install
                              added 1 package from 1 contributor and audited 1 package in 29.697s
                              found 0 vulnerabilities
                              npm WARN grunt-stylelint@0.11.1 requires a peer of stylelint@^10.0.0 but none is installed. You must install peer dependencies yourself.
                              npm WARN acorn-jsx@5.1.0 requires a peer of acorn@^6.0.0 || ^7.0.0 but none is installed. You must install peer dependencies yourself.
                              added 1051 packages from 1314 contributors and audited 3475 packages in 1848.766s
                              found 28 vulnerabilities (1 low, 1 moderate, 26 high)
                              Dependencies installation Done!
                              setting up initial config.js
                              Check plymouth installation ...
                              Splashscreen: Checking themes directory.
                              Splashscreen: Create theme directory if not exists.
                              Splashscreen: Theme copied successfully.
                              Splashscreen: Changed theme to MagicMirror successfully.
                              Do you want use pm2 for auto starting of your MagicMirror (y/N)?y
                              install and setup pm2
                              npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.1.1 (node_modules/pm2/node_modules/fsevents):
                              npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.1.1: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
                              Created symlink /etc/systemd/system/multi-user.target.wants/pm2-pi.service → /etc/systemd/system/pm2-pi.service.
                              [PM2] Spawning PM2 daemon with pm2_home=/home/pi/.pm2
                              [PM2] PM2 Successfully daemonized
                              [PM2][WARN] Applications MagicMirror not running, starting...
                              [PM2] App [MagicMirror] launched (1 instances)
                              │ id │ name                    │ version │ mode    │ pid      │ uptime │ ↺    │ status   │ cpu      │ mem      │ user     │ watching │
                              │ 0  │ MagicMirror             │ 2.9.0   │ fork    │ 4228     │ 3s     │ 0    │ online   │ 0%       │ 2.4mb    │ pi       │ enabled  │
                              [PM2] Saving current process list...
                              [PM2] Successfully saved in /home/pi/.pm2/dump.pm2
                              Do you want to disable the screen saver? (y/N)?y
                              We're ready! Run DISPLAY=:0 npm start from the ~/MagicMirror directory to start your MagicMirror.
                              pi@RasPiZeroW:~ $ cd MagicMirror/
                              pi@RasPiZeroW:~/MagicMirror $ DISPLAY=:0 npm start
                              > magicmirror@2.9.0 start /home/pi/MagicMirror
                              > sh run-start.sh
                              additional
                              pi@RasPiZeroW:~/MagicMirror $ npm audit fix
                              + helmet@3.21.1
                              + lodash@4.17.15
                              added 8 packages from 7 contributors, removed 5 packages and updated 22 packages in 808.897s
                              fixed 28 of 28 vulnerabilities in 3475 scanned packages
                              MM is not coming on the screen
                              I did:
                              pi@RasPiZeroW:~/MagicMirror $  pm2 ls
                              │ 0  │ MagicMirror             │ 2.9.0   │ fork    │ 20451    │ 64s    │ 520  │ online   │ 0%       │ 2.5mb    │ pi       │ enabled  │
                              pi@RasPiZeroW:~/MagicMirror $  pm2 restart mm
                              [PM2][ERROR] Process mm not found
                              pi@RasPiZeroW:~/MagicMirror $  cd installers/
                              pi@RasPiZeroW:~/MagicMirror/installers $  nano mm.sh
                              pi@RasPiZeroW:~/MagicMirror/installers $ cd ..
                              pi@RasPiZeroW:~/MagicMirror $ pm2 restart 0
                              [PM2] Applying action restartProcessId on app [0](ids: 0)
                              [PM2][ERROR] Process 0 not found
                              pi@RasPiZeroW:~/MagicMirror/installers $ pm2 start mm.sh
                              [PM2] Starting /home/pi/MagicMirror/installers/mm.sh in fork_mode (1 instance)
                              [PM2] Done.
                              │ 0  │ MagicMirror             │ 2.9.0   │ fork    │ 16261    │ 61s    │ 4340 │ online   │ 0%       │ 2.5mb    │ pi       │ enabled  │
                              │ 1  │ mm                      │ 2.9.0   │ fork    │ 16293    │ 1s     │ 0    │ online   │ 0%       │ 2.5mb    │ pi       │ disabled │
                              [PM2][ERROR] Script already launched, add -f option to force re-execution
                              Can you please give me a hint what my failer in thinking is?
                              What is missing and what wxactly do I need to do?
                              Many thanks! :grinning_face:
                              cheers, bdream
                                sdetweil @bdream
                                @bdream ok, a few things…
                                1. i need to fix the words at the end of install, cause if you said yes to pm2, then don’t do npm start
                                2. then u went and did a manual add of another thing for pm2…
                                so,
                                 pm2 stop mm
                                 pm2 delete mm
                                then
                                pm2  stop MagicMirror
                                then lets try manually
                                npm start
                                you should see the messages from the mirror running
                                please advise
                                  bdream
                                  Thias is you have to work on:
                                  I do
                                  pi@RasPiZeroW:~ $  pm2 stop mm
                                  not necasarry
                                  pm2 delete mm
                                  pi@RasPiZeroW:~ $ pm2  stop MagicMirror
                                  [PM2] Applying action stopProcessId on app [MagicMirror](ids: 0)
                                  [PM2] [MagicMirror](0) ✓
                                  │ id │ name               │ mode     │ ↺    │ status   │ cpu      │ memory   │
                                  │ 0  │ MagicMirror        │ fork     │ 223  │ stopped  │ 0%       │ 0b       │
                                  pi@RasPiZeroW:~/MagicMirror $ npm start
                                  > sh run-start.sh
                                  nothing happen
                                  cheers, bdream
                                    sdetweil @bdream
                                    @bdream weird… now have same problem on two systems…
                                    try this
                                    node serveronly
                                    the connection url will be shown
                                    then connect to that url from a browser on another system
                                      another thing to try is
                                      export DISPLAY=:0
                                      node node_modules/.bin/electron
                                      electron should come up on the screen
                                        bdream
                                        no, it dosn’t
                                        cheers, bdream
                                          sdetweil @bdream
                                          @bdream did serveronly mode work?
                                            sdetweil @bdream
                                            @bdream ok, one more thing to try
                                            cd ~/MagicMirror/node_modules
                                            mv electron electron.save
                                            cd ..
                                            npm install electron@latest
                                            I am running 6.0.12 on one of my systems
                                            then try npm start
                                            • 4 / 6
