    YAPi0 Installer Stretch Lite
    118 Posts 4 Posters 120.4k Views 3 Watching
      bdream
      Any idea what to do?
      Maybe Pi0 is not the Hardware MM will run good. Especialy in regards to upcoming updates :dizzy_face:
      But this small device will give more oportunities for nice looking projects based on MM :grinning_face_with_smiling_eyes:
      cheers, bdream
        sdetweil @bdream
        @bdream others have made it work… you may have to reinstall the base raspian image to get the graphical desktop running properly…
        I don’t have one of these pi0 devices to test with
          bdream
          @sdetweil many thanks for your guidance.
          I thaught Pi0 must get installed without GUI :worried_face: my fault.
          I will start again and see what happen.
          I’ll let you know if success yur script!
          cheers, bdream
            sdetweil @bdream
            @bdream U can run it in serveronly mode
            Have to edit the installers/mm.sh
            Or run_start.sh to do
            node serveronly
            The use browser from some other system
              bdream
              @sdetweil Raspbian Buster with desktop image already written to the sc-card.
              will see the time I have to work on it next time.
              Stuff arount serveronly and using other browser is to far from me at the moment :unamused_face:
              cheers, bdream
                sdetweil @bdream
                @bdream ok… there is only one MM install… but two ways to run it… so, no problem
                  bdream
                  @sdetweil many thanks!!
                  cheers, bdream
                    bdream
                    @sdetweil may I come back to you :smiling_face_with_halo:
                    I run new installation from scratch on my Rpi0.
                    Raspian Buster with desktop
                    updated and upgraded and so on
                    run your script
                     bash -c "$(curl -sL https://www.dropbox.com/s/rlh710ng0zwv3vp/raspberry.sh?dl=0)"
                    Node.js installation Done! version=v10.15.2
                    npm WARN npm npm does not support Node.js v10.15.2
                    npm WARN npm You should probably upgrade to a newer version of node as we
                    npm WARN npm can't make any promises that npm will work with this version.
                    npm WARN npm Supported releases of Node.js are the latest release of 4, 6, 7, 8, 9.
                    npm WARN npm You can find the latest version at https://nodejs.org/
                    /usr/local/bin/npm -> /usr/local/lib/node_modules/npm/bin/npm-cli.js
                    /usr/local/bin/npx -> /usr/local/lib/node_modules/npm/bin/npx-cli.js
                    + npm@6.12.0
                    added 430 packages from 839 contributors in 328.327s
                    npm installation Done! version=V6.12.0
                    Cloning MagicMirror Done!
                    Installing dependencies ...
                    npm WARN deprecated time-grunt@2.0.0: Deprecated because Grunt is practically unmaintained. Move on to something better. This package will continue to work with Grunt v1, but it will not receive any updates.
                    > electron-chromedriver@1.8.0 install /home/pi/MagicMirror/node_modules/electron-chromedriver
                    > node ./download-chromedriver.js
                    successfully dowloaded and extracted!
                    > electron@3.0.13 postinstall /home/pi/MagicMirror/node_modules/electron
                    > node install.js
                    Downloading tmp-3996-1-SHASUMS256.txt-3.0.13
                    [============================================>] 100.0% of 4.79 kB (4.79 kB/s)
                    > magicmirror@2.9.0 install /home/pi/MagicMirror
                    > cd vendor && npm install
                    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@1.2.4 (node_modules/fsevents):
                    npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@1.2.4: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
                    added 82 packages from 57 contributors and audited 220 packages in 139.709s
                    found 5 vulnerabilities (4 low, 1 high)
                      run `npm audit fix` to fix them, or `npm audit` for details
                    > magicmirror@2.9.0 postinstall /home/pi/MagicMirror
                    > sh untrack-css.sh && sh installers/postinstall/postinstall.sh && npm run install-fonts
                    We'll remove from the repository the css/custom.css
                    This script apply git update-index --skip-worktree css/custom.css
                    rm 'css/custom.css'
                    MagicMirror installation successful!
                    > magicmirror@2.9.0 install-fonts /home/pi/MagicMirror
                    > cd fonts && npm install
                    added 1 package from 1 contributor and audited 1 package in 29.697s
                    found 0 vulnerabilities
                    npm WARN grunt-stylelint@0.11.1 requires a peer of stylelint@^10.0.0 but none is installed. You must install peer dependencies yourself.
                    npm WARN acorn-jsx@5.1.0 requires a peer of acorn@^6.0.0 || ^7.0.0 but none is installed. You must install peer dependencies yourself.
                    added 1051 packages from 1314 contributors and audited 3475 packages in 1848.766s
                    found 28 vulnerabilities (1 low, 1 moderate, 26 high)
                    Dependencies installation Done!
                    setting up initial config.js
                    Check plymouth installation ...
                    Splashscreen: Checking themes directory.
                    Splashscreen: Create theme directory if not exists.
                    Splashscreen: Theme copied successfully.
                    Splashscreen: Changed theme to MagicMirror successfully.
                    Do you want use pm2 for auto starting of your MagicMirror (y/N)?y
                    install and setup pm2
                    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.1.1 (node_modules/pm2/node_modules/fsevents):
                    npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.1.1: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
                    Created symlink /etc/systemd/system/multi-user.target.wants/pm2-pi.service → /etc/systemd/system/pm2-pi.service.
                    [PM2] Spawning PM2 daemon with pm2_home=/home/pi/.pm2
                    [PM2] PM2 Successfully daemonized
                    [PM2][WARN] Applications MagicMirror not running, starting...
                    [PM2] App [MagicMirror] launched (1 instances)
                    │ id │ name                    │ version │ mode    │ pid      │ uptime │ ↺    │ status   │ cpu      │ mem      │ user     │ watching │
                    │ 0  │ MagicMirror             │ 2.9.0   │ fork    │ 4228     │ 3s     │ 0    │ online   │ 0%       │ 2.4mb    │ pi       │ enabled  │
                    [PM2] Saving current process list...
                    [PM2] Successfully saved in /home/pi/.pm2/dump.pm2
                    Do you want to disable the screen saver? (y/N)?y
                    We're ready! Run DISPLAY=:0 npm start from the ~/MagicMirror directory to start your MagicMirror.
                    pi@RasPiZeroW:~ $ cd MagicMirror/
                    pi@RasPiZeroW:~/MagicMirror $ DISPLAY=:0 npm start
                    > magicmirror@2.9.0 start /home/pi/MagicMirror
                    > sh run-start.sh
                    additional
                    pi@RasPiZeroW:~/MagicMirror $ npm audit fix
                    + helmet@3.21.1
                    + lodash@4.17.15
                    added 8 packages from 7 contributors, removed 5 packages and updated 22 packages in 808.897s
                    fixed 28 of 28 vulnerabilities in 3475 scanned packages
                    MM is not coming on the screen
                    I did:
                    pi@RasPiZeroW:~/MagicMirror $  pm2 ls
                    │ 0  │ MagicMirror             │ 2.9.0   │ fork    │ 20451    │ 64s    │ 520  │ online   │ 0%       │ 2.5mb    │ pi       │ enabled  │
                    pi@RasPiZeroW:~/MagicMirror $  pm2 restart mm
                    [PM2][ERROR] Process mm not found
                    pi@RasPiZeroW:~/MagicMirror $  cd installers/
                    pi@RasPiZeroW:~/MagicMirror/installers $  nano mm.sh
                    pi@RasPiZeroW:~/MagicMirror/installers $ cd ..
                    pi@RasPiZeroW:~/MagicMirror $ pm2 restart 0
                    [PM2] Applying action restartProcessId on app [0](ids: 0)
                    [PM2][ERROR] Process 0 not found
                    pi@RasPiZeroW:~/MagicMirror/installers $ pm2 start mm.sh
                    [PM2] Starting /home/pi/MagicMirror/installers/mm.sh in fork_mode (1 instance)
                    [PM2] Done.
                    │ 0  │ MagicMirror             │ 2.9.0   │ fork    │ 16261    │ 61s    │ 4340 │ online   │ 0%       │ 2.5mb    │ pi       │ enabled  │
                    │ 1  │ mm                      │ 2.9.0   │ fork    │ 16293    │ 1s     │ 0    │ online   │ 0%       │ 2.5mb    │ pi       │ disabled │
                    [PM2][ERROR] Script already launched, add -f option to force re-execution
                    Can you please give me a hint what my failer in thinking is?
                    What is missing and what wxactly do I need to do?
                    Many thanks! :grinning_face:
                    cheers, bdream
                      sdetweil @bdream
                      @bdream ok, a few things…
                      1. i need to fix the words at the end of install, cause if you said yes to pm2, then don’t do npm start
                      2. then u went and did a manual add of another thing for pm2…
                      so,
                       pm2 stop mm
                       pm2 delete mm
                      then
                      pm2  stop MagicMirror
                      then lets try manually
                      npm start
                      you should see the messages from the mirror running
                      please advise
                        bdream
                        Thias is you have to work on:
                        @sdetweil said in YAPi0 Installer Stretch Lite:
                        I do
                        pi@RasPiZeroW:~ $  pm2 stop mm
                        not necasarry
                        pm2 delete mm
                        pi@RasPiZeroW:~ $ pm2  stop MagicMirror
                        [PM2] Applying action stopProcessId on app [MagicMirror](ids: 0)
                        [PM2] [MagicMirror](0) ✓
                        │ id │ name               │ mode     │ ↺    │ status   │ cpu      │ memory   │
                        │ 0  │ MagicMirror        │ fork     │ 223  │ stopped  │ 0%       │ 0b       │
                        pi@RasPiZeroW:~/MagicMirror $ npm start
                        > sh run-start.sh
                        nothing happen
                        cheers, bdream
                          sdetweil @bdream
                          @bdream weird… now have same problem on two systems…
                          try this
                          node serveronly
                          the connection url will be shown
                          then connect to that url from a browser on another system
                            another thing to try is
                            export DISPLAY=:0
                            node node_modules/.bin/electron
                            electron should come up on the screen
                              bdream
                              no, it dosn’t
                              cheers, bdream
                              S 2 Replies Last reply
                                sdetweil @bdream
                                @bdream did serveronly mode work?
                                  sdetweil @bdream
                                  @bdream ok, one more thing to try
                                  cd ~/MagicMirror/node_modules
                                  mv electron electron.save
                                  cd ..
                                  npm install electron@latest
                                  I am running 6.0.12 on one of my systems
                                  then try npm start
                                    bdream
                                    pi@RasPiZeroW:~/MagicMirror $ npm install electron@latest
                                    > electron@6.0.12 postinstall /home/pi/MagicMirror/node_modules/electron
                                    > node install.js
                                    Downloading tmp-1548-0-electron-v6.0.12-linux-armv6l.zip
                                    Error: GET https://github.com/electron/electron/releases/download/v6.0.12/electr                   on-v6.0.12-linux-armv6l.zip returned 404
                                    /home/pi/MagicMirror/node_modules/electron/install.js:53
                                      throw err
                                    Error: Failed to find Electron v6.0.12 for linux-armv6l at https://github.com/el                   ectron/electron/releases/download/v6.0.12/electron-v6.0.12-linux-armv6l.zip
                                        at Request.<anonymous> (/home/pi/MagicMirror/node_modules/nugget/index.js:16                   9:61)
                                        at Request.emit (events.js:189:13)
                                        at Request.onRequestResponse (/home/pi/MagicMirror/node_modules/request/requ                   est.js:1066:10)
                                        at ClientRequest.emit (events.js:189:13)
                                        at HTTPParser.parserOnIncomingClient [as onIncoming] (_http_client.js:556:21                   )
                                        at HTTPParser.parserOnHeadersComplete (_http_common.js:109:17)
                                        at TLSSocket.socketOnData (_http_client.js:442:20)
                                        at TLSSocket.emit (events.js:189:13)
                                        at addChunk (_stream_readable.js:284:12)
                                        at readableAddChunk (_stream_readable.js:265:11)
                                    npm WARN acorn-jsx@5.1.0 requires a peer of acorn@^6.0.0 || ^7.0.0 but none is i                   nstalled. You must install peer dependencies yourself.
                                    npm ERR! code ELIFECYCLE
                                    npm ERR! errno 1
                                    npm ERR! electron@6.0.12 postinstall: `node install.js`
                                    npm ERR! Exit status 1
                                    npm ERR!
                                    npm ERR! Failed at the electron@6.0.12 postinstall script.
                                    npm ERR! This is probably not a problem with npm. There is likely additional log                   ging output above.
                                    npm ERR!     /home/pi/.npm/_logs/2019-10-18T13_30_31_697Z-debug.log
                                    I would like to attach the log, but it’s missing :pouting_face:
                                    > sh run-start.sh
                                    run-start.sh: 7: run-start.sh: electron: not found
                                    npm ERR! syscall spawn
                                    npm ERR! file sh
                                    npm ERR! errno ENOENT
                                    npm ERR! magicmirror@2.9.0 start: `sh run-start.sh`
                                    npm ERR! spawn ENOENT
                                    npm ERR!
                                    npm ERR! Failed at the magicmirror@2.9.0 start script.
                                    npm ERR!     /home/pi/.npm/_logs/2019-10-18T14_07_43_211Z-debug.log
                                    cheers, bdream
                                      bdream
                                      @sdetweil how interesting.
                                      If I reboot the RPi0 I see MagicMirror booting too. After a while of black screen I get usal Pi Desktop.
                                      cheers, bdream
                                        sdetweil @bdream
                                        @bdream sorry, forgot about arm6l
                                        Do
                                        npm install --arch=arm7l electron@latest
                                          bdream
                                          pi@RasPiZeroW:~ $ npm install --arch=arm7l electron@latest
                                          > electron@6.0.12 postinstall /home/pi/node_modules/electron
                                          > node install.js
                                          Downloading tmp-2171-0-electron-v6.0.12-linux-arm7l.zip
                                          Error: GET https://github.com/electron/electron/releases/download/v6.0.12/electron-v6.0.12-linux-arm7l.zip returned 404
                                          /home/pi/node_modules/electron/install.js:53
                                            throw err
                                          Error: Failed to find Electron v6.0.12 for linux-arm7l at https://github.com/electron/electron/releases/download/v6.0.12/electron-v6.0.12-linux-arm7l.zip
                                              at Request.<anonymous> (/home/pi/node_modules/nugget/index.js:169:61)
                                              at Request.onRequestResponse (/home/pi/node_modules/request/request.js:1066:10)
                                              at HTTPParser.parserOnIncomingClient [as onIncoming] (_http_client.js:556:21)
                                          npm WARN enoent ENOENT: no such file or directory, open '/home/pi/package.json'
                                          npm WARN pi No description
                                          npm WARN pi No repository field.
                                          npm WARN pi No README data
                                          npm WARN pi No license field.
                                          npm ERR! errno 1
                                          npm ERR!
                                          npm ERR!     /home/pi/.npm/_logs/2019-10-18T15_04_49_780Z-debug.log
                                          cheers, bdream
                                            sdetweil @bdream
                                            @bdream sorry,. please in the MagicMirror folder
                                            all things MagicMirror should be done from the MagicMirror folder
                                            npm install --arch=armv7l electron@latest
                                            notice the added lowercase V --arch=armV7L (all lowercase)
                                            I get a file download for
                                            https://github.com/electron/electron/releases/download/v6.0.12/electron-v6.0.12-linux-armv7l.zip
                                            • 4 / 6
