    YAPi0 Installer Stretch Lite
    118 Posts 4 Posters 118.1k Views 3 Watching
      sdetweil @bdream
      @bdream ok, there are two logs… error and out…
      maybe best to do
      pm2 stop 0
      npm start
        bdream
        pi@RasPiZeroW:~ $ cd ~/MagicMirror/
        pi@RasPiZeroW:~/MagicMirror $ pm2 stop 0
        [PM2] Applying action stopProcessId on app [0](ids: 0)
        [PM2] [MagicMirror](0) ✓
        │ App name    │ id │ version │ mode │ pid │ status  │ restart │ uptime │ cpu │ mem    │ user │ watching │
        │ MagicMirror │ 0  │ 2.8.0   │ fork │ 0   │ stopped │ 31      │ 0      │ 0%  │ 0 B    │ pi   │ disabled │
         Use `pm2 show <id|name>` to get more details about an app
        pi@RasPiZeroW:~/MagicMirror $ npm start
        > magicmirror@2.8.0 start /home/pi/MagicMirror
        > sh run-start.sh
        /home/pi/MagicMirror/node_modules/electron/dist/electron: error while loading shared libraries: libgtk-3.so.0: cannot open shared object file: No such file or directory
        npm ERR! code ELIFECYCLE
        npm ERR! syscall spawn
        npm ERR! file sh
        npm ERR! errno ENOENT
        npm ERR! magicmirror@2.8.0 start: `sh run-start.sh`
        npm ERR! spawn ENOENT
        npm ERR!
        npm ERR! Failed at the magicmirror@2.8.0 start script.
        npm ERR!     /home/pi/.npm/_logs/2019-09-25T17_26_03_649Z-debug.log
        cheers, bdream
          sdetweil @bdream
          @bdream
          you MUST install the graphical UI desktop on the pi, right? MM uses graphics to display the screen.
            bdream
            hmm, I guess I have to investigate about this in a few weeks.
            So far many thanks for your help here. Will have a look later today and see what can I handle. Otherwise later. I have to run for a meeting now.
            cheers, bdream
              bdream
              @sdetweil said in YAPi0 Installer Stretch Lite:
              I wonder. I understood Pi0 don’t need to have UI installed. therefor I installed the light raspbian image - maybe I’m wrong :confounded_face:
              Do I have to install lightdm or other?
              And then I assume use raspi-config to boot to desktop?
              cheers, bdream
                sdetweil @bdream
                @bdream you can do node serveronly , instead of npm start…
                for pm2, edit installers/mm.sh and change npm start to node serveronly
                then pm2 restart 0
                others have had success at running UI on p0 as well…
                make sure u change config/config.js to allow other machines to connect
                to allow all
                address: “”,
                and
                ipWhitelist: [],
                  bdream
                  Í’m back now and started to work further on my Pi0 with MM installation.
                  I tried to get UI desktop running by installing lightdm.
                  Then reconfigured Boot option to start Desktopn and Auotologin.
                  After reboot, wich looks good, PI starts an give Debian logon screen.
                  How to autologon?
                  After I put in my credentials pi and raspberry I stuck in login-loop.
                  cheers, bdream
                    bdream
                    Any idea what to do?
                    Maybe Pi0 is not the Hardware MM will run good. Especialy in regards to upcoming updates :dizzy_face:
                    But this small device will give more oportunities for nice looking projects based on MM :grinning_face_with_smiling_eyes:
                    cheers, bdream
                      sdetweil @bdream
                      @bdream others have made it work… you may have to reinstall the base raspian image to get the graphical desktop running properly…
                      I don’t have one of these pi0 devices to test with
                        bdream
                        @sdetweil many thanks for your guidance.
                        I thaught Pi0 must get installed without GUI :worried_face: my fault.
                        I will start again and see what happen.
                        I’ll let you know if success yur script!
                        cheers, bdream
                          sdetweil @bdream
                          @bdream U can run it in serveronly mode
                          Have to edit the installers/mm.sh
                          Or run_start.sh to do
                          node serveronly
                          The use browser from some other system
                            bdream
                            @sdetweil Raspbian Buster with desktop image already written to the sc-card.
                            will see the time I have to work on it next time.
                            Stuff arount serveronly and using other browser is to far from me at the moment :unamused_face:
                            cheers, bdream
                              sdetweil @bdream
                              @bdream ok… there is only one MM install… but two ways to run it… so, no problem
                                bdream
                                @sdetweil many thanks!!
                                cheers, bdream
                                  bdream
                                  @sdetweil may I come back to you :smiling_face_with_halo:
                                  I run new installation from scratch on my Rpi0.
                                  Raspian Buster with desktop
                                  updated and upgraded and so on
                                  run your script
                                   bash -c "$(curl -sL https://www.dropbox.com/s/rlh710ng0zwv3vp/raspberry.sh?dl=0)"
                                  Node.js installation Done! version=v10.15.2
                                  npm WARN npm npm does not support Node.js v10.15.2
                                  npm WARN npm You should probably upgrade to a newer version of node as we
                                  npm WARN npm can't make any promises that npm will work with this version.
                                  npm WARN npm Supported releases of Node.js are the latest release of 4, 6, 7, 8, 9.
                                  npm WARN npm You can find the latest version at https://nodejs.org/
                                  /usr/local/bin/npm -> /usr/local/lib/node_modules/npm/bin/npm-cli.js
                                  /usr/local/bin/npx -> /usr/local/lib/node_modules/npm/bin/npx-cli.js
                                  + npm@6.12.0
                                  added 430 packages from 839 contributors in 328.327s
                                  npm installation Done! version=V6.12.0
                                  Cloning MagicMirror Done!
                                  Installing dependencies ...
                                  npm WARN deprecated time-grunt@2.0.0: Deprecated because Grunt is practically unmaintained. Move on to something better. This package will continue to work with Grunt v1, but it will not receive any updates.
                                  > electron-chromedriver@1.8.0 install /home/pi/MagicMirror/node_modules/electron-chromedriver
                                  > node ./download-chromedriver.js
                                  successfully dowloaded and extracted!
                                  > electron@3.0.13 postinstall /home/pi/MagicMirror/node_modules/electron
                                  > node install.js
                                  Downloading tmp-3996-1-SHASUMS256.txt-3.0.13
                                  [============================================>] 100.0% of 4.79 kB (4.79 kB/s)
                                  > magicmirror@2.9.0 install /home/pi/MagicMirror
                                  > cd vendor && npm install
                                  npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@1.2.4 (node_modules/fsevents):
                                  npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@1.2.4: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
                                  added 82 packages from 57 contributors and audited 220 packages in 139.709s
                                  found 5 vulnerabilities (4 low, 1 high)
                                    run `npm audit fix` to fix them, or `npm audit` for details
                                  > magicmirror@2.9.0 postinstall /home/pi/MagicMirror
                                  > sh untrack-css.sh && sh installers/postinstall/postinstall.sh && npm run install-fonts
                                  We'll remove from the repository the css/custom.css
                                  This script apply git update-index --skip-worktree css/custom.css
                                  rm 'css/custom.css'
                                  MagicMirror installation successful!
                                  > magicmirror@2.9.0 install-fonts /home/pi/MagicMirror
                                  > cd fonts && npm install
                                  added 1 package from 1 contributor and audited 1 package in 29.697s
                                  found 0 vulnerabilities
                                  npm WARN grunt-stylelint@0.11.1 requires a peer of stylelint@^10.0.0 but none is installed. You must install peer dependencies yourself.
                                  npm WARN acorn-jsx@5.1.0 requires a peer of acorn@^6.0.0 || ^7.0.0 but none is installed. You must install peer dependencies yourself.
                                  added 1051 packages from 1314 contributors and audited 3475 packages in 1848.766s
                                  found 28 vulnerabilities (1 low, 1 moderate, 26 high)
                                  Dependencies installation Done!
                                  setting up initial config.js
                                  Check plymouth installation ...
                                  Splashscreen: Checking themes directory.
                                  Splashscreen: Create theme directory if not exists.
                                  Splashscreen: Theme copied successfully.
                                  Splashscreen: Changed theme to MagicMirror successfully.
                                  Do you want use pm2 for auto starting of your MagicMirror (y/N)?y
                                  install and setup pm2
                                  npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.1.1 (node_modules/pm2/node_modules/fsevents):
                                  npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.1.1: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
                                  Created symlink /etc/systemd/system/multi-user.target.wants/pm2-pi.service → /etc/systemd/system/pm2-pi.service.
                                  [PM2] Spawning PM2 daemon with pm2_home=/home/pi/.pm2
                                  [PM2] PM2 Successfully daemonized
                                  [PM2][WARN] Applications MagicMirror not running, starting...
                                  [PM2] App [MagicMirror] launched (1 instances)
                                  │ id │ name                    │ version │ mode    │ pid      │ uptime │ ↺    │ status   │ cpu      │ mem      │ user     │ watching │
                                  │ 0  │ MagicMirror             │ 2.9.0   │ fork    │ 4228     │ 3s     │ 0    │ online   │ 0%       │ 2.4mb    │ pi       │ enabled  │
                                  [PM2] Saving current process list...
                                  [PM2] Successfully saved in /home/pi/.pm2/dump.pm2
                                  Do you want to disable the screen saver? (y/N)?y
                                  We're ready! Run DISPLAY=:0 npm start from the ~/MagicMirror directory to start your MagicMirror.
                                  pi@RasPiZeroW:~ $ cd MagicMirror/
                                  pi@RasPiZeroW:~/MagicMirror $ DISPLAY=:0 npm start
                                  > magicmirror@2.9.0 start /home/pi/MagicMirror
                                  > sh run-start.sh
                                  additional
                                  pi@RasPiZeroW:~/MagicMirror $ npm audit fix
                                  + helmet@3.21.1
                                  + lodash@4.17.15
                                  added 8 packages from 7 contributors, removed 5 packages and updated 22 packages in 808.897s
                                  fixed 28 of 28 vulnerabilities in 3475 scanned packages
                                  MM is not coming on the screen
                                  I did:
                                  pi@RasPiZeroW:~/MagicMirror $  pm2 ls
                                  │ 0  │ MagicMirror             │ 2.9.0   │ fork    │ 20451    │ 64s    │ 520  │ online   │ 0%       │ 2.5mb    │ pi       │ enabled  │
                                  pi@RasPiZeroW:~/MagicMirror $  pm2 restart mm
                                  [PM2][ERROR] Process mm not found
                                  pi@RasPiZeroW:~/MagicMirror $  cd installers/
                                  pi@RasPiZeroW:~/MagicMirror/installers $  nano mm.sh
                                  pi@RasPiZeroW:~/MagicMirror/installers $ cd ..
                                  pi@RasPiZeroW:~/MagicMirror $ pm2 restart 0
                                  [PM2] Applying action restartProcessId on app [0](ids: 0)
                                  [PM2][ERROR] Process 0 not found
                                  pi@RasPiZeroW:~/MagicMirror/installers $ pm2 start mm.sh
                                  [PM2] Starting /home/pi/MagicMirror/installers/mm.sh in fork_mode (1 instance)
                                  [PM2] Done.
                                  │ 0  │ MagicMirror             │ 2.9.0   │ fork    │ 16261    │ 61s    │ 4340 │ online   │ 0%       │ 2.5mb    │ pi       │ enabled  │
                                  │ 1  │ mm                      │ 2.9.0   │ fork    │ 16293    │ 1s     │ 0    │ online   │ 0%       │ 2.5mb    │ pi       │ disabled │
                                  [PM2][ERROR] Script already launched, add -f option to force re-execution
                                  Can you please give me a hint what my failer in thinking is?
                                  What is missing and what wxactly do I need to do?
                                  Many thanks! :grinning_face:
                                  cheers, bdream
                                    sdetweil @bdream
                                    @bdream ok, a few things…
                                    1. i need to fix the words at the end of install, cause if you said yes to pm2, then don’t do npm start
                                    2. then u went and did a manual add of another thing for pm2…
                                    so,
                                     pm2 stop mm
                                     pm2 delete mm
                                    then
                                    pm2  stop MagicMirror
                                    then lets try manually
                                    npm start
                                    you should see the messages from the mirror running
                                    please advise
                                      bdream
                                      Thias is you have to work on:
                                      I do
                                      pi@RasPiZeroW:~ $  pm2 stop mm
                                      not necasarry
                                      pm2 delete mm
                                      pi@RasPiZeroW:~ $ pm2  stop MagicMirror
                                      [PM2] Applying action stopProcessId on app [MagicMirror](ids: 0)
                                      │ id │ name               │ mode     │ ↺    │ status   │ cpu      │ memory   │
                                      │ 0  │ MagicMirror        │ fork     │ 223  │ stopped  │ 0%       │ 0b       │
                                      > sh run-start.sh
                                      nothing happen
                                      cheers, bdream
                                        sdetweil @bdream
                                        @bdream weird… now have same problem on two systems…
                                        try this
                                        node serveronly
                                        the connection url will be shown
                                        then connect to that url from a browser on another system
                                          another thing to try is
                                          export DISPLAY=:0
                                          node node_modules/.bin/electron
                                          electron should come up on the screen
                                            bdream
                                            no, it dosn’t
                                            cheers, bdream
                                            • 4 / 6
