    YAPi0 Installer Stretch Lite
    118 Posts 4 Posters 118.1k Views 3 Watching
      sdetweil @bdream
      @bdream correct, reply yes or y
        bdream
        [PM2][WARN] Application MagicMirror not running, starting...
        [PM2] App [MagicMirror] launched (1 instances)
        App name | id | version | node | pid | status | restart | uptime | cpu | mem | user | watching
        MagicMirror | 0 | 2.8.0 | fork | 4835 | online | 0 | 3s | 0% | 2.5 MB | pi | enabled
        use 'pm2 show <id|name>' to get more details about an app
        I used pm2 show mm and got [PM2][WARN] mm doesn’t exist
        cheers, bdream
          sdetweil @bdream
          @bdream said in YAPi0 Installer Stretch Lite:
          pm2 show mm
          correct,
          its called MagicMirror
          says its running…
          show me pm2 logs
          you can also use the id, instead of the name
          pm2 start 0,
          pm2 stop 0,
          pm2 show 0…
          etc
            bdream
            here you are
            last 3 rows coming multiple times
            cheers, bdream
              sdetweil @bdream
              @bdream ok, there are two logs… error and out…
              maybe best to do
              pm2 stop 0
              npm start
                bdream
                pi@RasPiZeroW:~ $ cd ~/MagicMirror/
                pi@RasPiZeroW:~/MagicMirror $ pm2 stop 0
                [PM2] Applying action stopProcessId on app [0](ids: 0)
                [PM2] [MagicMirror](0) ✓
                │ App name    │ id │ version │ mode │ pid │ status  │ restart │ uptime │ cpu │ mem    │ user │ watching │
                │ MagicMirror │ 0  │ 2.8.0   │ fork │ 0   │ stopped │ 31      │ 0      │ 0%  │ 0 B    │ pi   │ disabled │
                 Use `pm2 show <id|name>` to get more details about an app
                pi@RasPiZeroW:~/MagicMirror $ npm start
                > magicmirror@2.8.0 start /home/pi/MagicMirror
                > sh run-start.sh
                /home/pi/MagicMirror/node_modules/electron/dist/electron: error while loading shared libraries: libgtk-3.so.0: cannot open shared object file: No such file or directory
                npm ERR! code ELIFECYCLE
                npm ERR! syscall spawn
                npm ERR! file sh
                npm ERR! errno ENOENT
                npm ERR! magicmirror@2.8.0 start: `sh run-start.sh`
                npm ERR! spawn ENOENT
                npm ERR!
                npm ERR! Failed at the magicmirror@2.8.0 start script.
                npm ERR!     /home/pi/.npm/_logs/2019-09-25T17_26_03_649Z-debug.log
                cheers, bdream
                  sdetweil @bdream
                  @bdream
                  you MUST install the graphical UI desktop on the pi, right? MM uses graphics to display the screen.
                    bdream
                    hmm, I guess I have to investigate about this in a few weeks.
                    So far many thanks for your help here. Will have a look later today and see what can I handle. Otherwise later. I have to run for a meeting now.
                    cheers, bdream
                      bdream
                      @sdetweil said in YAPi0 Installer Stretch Lite:
                      I wonder. I understood Pi0 don’t need to have UI installed. therefor I installed the light raspbian image - maybe I’m wrong :confounded_face:
                      Do I have to install lightdm or other?
                      And then I assume use raspi-config to boot to desktop?
                      cheers, bdream
                        sdetweil @bdream
                        @bdream you can do node serveronly , instead of npm start…
                        for pm2, edit installers/mm.sh and change npm start to node serveronly
                        then pm2 restart 0
                        others have had success at running UI on p0 as well…
                        make sure u change config/config.js to allow other machines to connect
                        to allow all
                        address: “”,
                        and
                        ipWhitelist: [],
                          bdream
                          Í’m back now and started to work further on my Pi0 with MM installation.
                          I tried to get UI desktop running by installing lightdm.
                          Then reconfigured Boot option to start Desktopn and Auotologin.
                          After reboot, wich looks good, PI starts an give Debian logon screen.
                          How to autologon?
                          After I put in my credentials pi and raspberry I stuck in login-loop.
                          cheers, bdream
                            bdream
                            Any idea what to do?
                            Maybe Pi0 is not the Hardware MM will run good. Especialy in regards to upcoming updates :dizzy_face:
                            But this small device will give more oportunities for nice looking projects based on MM :grinning_face_with_smiling_eyes:
                            cheers, bdream
                              sdetweil @bdream
                              @bdream others have made it work… you may have to reinstall the base raspian image to get the graphical desktop running properly…
                              I don’t have one of these pi0 devices to test with
                                bdream
                                @sdetweil many thanks for your guidance.
                                I thaught Pi0 must get installed without GUI :worried_face: my fault.
                                I will start again and see what happen.
                                I’ll let you know if success yur script!
                                cheers, bdream
                                  sdetweil @bdream
                                  @bdream U can run it in serveronly mode
                                  Have to edit the installers/mm.sh
                                  Or run_start.sh to do
                                  node serveronly
                                  The use browser from some other system
                                    bdream
                                    @sdetweil Raspbian Buster with desktop image already written to the sc-card.
                                    will see the time I have to work on it next time.
                                    Stuff arount serveronly and using other browser is to far from me at the moment :unamused_face:
                                    cheers, bdream
                                      sdetweil @bdream
                                      @bdream ok… there is only one MM install… but two ways to run it… so, no problem
                                        bdream
                                        @sdetweil many thanks!!
                                        cheers, bdream
                                          bdream
                                          @sdetweil may I come back to you :smiling_face_with_halo:
                                          I run new installation from scratch on my Rpi0.
                                          Raspian Buster with desktop
                                          updated and upgraded and so on
                                          run your script
                                           bash -c "$(curl -sL https://www.dropbox.com/s/rlh710ng0zwv3vp/raspberry.sh?dl=0)"
                                          Node.js installation Done! version=v10.15.2
                                          npm WARN npm npm does not support Node.js v10.15.2
                                          npm WARN npm You should probably upgrade to a newer version of node as we
                                          npm WARN npm can't make any promises that npm will work with this version.
                                          npm WARN npm Supported releases of Node.js are the latest release of 4, 6, 7, 8, 9.
                                          npm WARN npm You can find the latest version at https://nodejs.org/
                                          /usr/local/bin/npm -> /usr/local/lib/node_modules/npm/bin/npm-cli.js
                                          /usr/local/bin/npx -> /usr/local/lib/node_modules/npm/bin/npx-cli.js
                                          + npm@6.12.0
                                          added 430 packages from 839 contributors in 328.327s
                                          npm installation Done! version=V6.12.0
                                          Cloning MagicMirror Done!
                                          Installing dependencies ...
                                          npm WARN deprecated time-grunt@2.0.0: Deprecated because Grunt is practically unmaintained. Move on to something better. This package will continue to work with Grunt v1, but it will not receive any updates.
                                          > electron-chromedriver@1.8.0 install /home/pi/MagicMirror/node_modules/electron-chromedriver
                                          > node ./download-chromedriver.js
                                          successfully dowloaded and extracted!
                                          > electron@3.0.13 postinstall /home/pi/MagicMirror/node_modules/electron
                                          > node install.js
                                          Downloading tmp-3996-1-SHASUMS256.txt-3.0.13
                                          [============================================>] 100.0% of 4.79 kB (4.79 kB/s)
                                          > magicmirror@2.9.0 install /home/pi/MagicMirror
                                          > cd vendor && npm install
                                          npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@1.2.4 (node_modules/fsevents):
                                          npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@1.2.4: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
                                          added 82 packages from 57 contributors and audited 220 packages in 139.709s
                                          found 5 vulnerabilities (4 low, 1 high)
                                            run `npm audit fix` to fix them, or `npm audit` for details
                                          > magicmirror@2.9.0 postinstall /home/pi/MagicMirror
                                          > sh untrack-css.sh && sh installers/postinstall/postinstall.sh && npm run install-fonts
                                          We'll remove from the repository the css/custom.css
                                          This script apply git update-index --skip-worktree css/custom.css
                                          rm 'css/custom.css'
                                          MagicMirror installation successful!
                                          > magicmirror@2.9.0 install-fonts /home/pi/MagicMirror
                                          > cd fonts && npm install
                                          added 1 package from 1 contributor and audited 1 package in 29.697s
                                          found 0 vulnerabilities
                                          npm WARN grunt-stylelint@0.11.1 requires a peer of stylelint@^10.0.0 but none is installed. You must install peer dependencies yourself.
                                          npm WARN acorn-jsx@5.1.0 requires a peer of acorn@^6.0.0 || ^7.0.0 but none is installed. You must install peer dependencies yourself.
                                          added 1051 packages from 1314 contributors and audited 3475 packages in 1848.766s
                                          found 28 vulnerabilities (1 low, 1 moderate, 26 high)
                                          Dependencies installation Done!
                                          setting up initial config.js
                                          Check plymouth installation ...
                                          Splashscreen: Checking themes directory.
                                          Splashscreen: Create theme directory if not exists.
                                          Splashscreen: Theme copied successfully.
                                          Splashscreen: Changed theme to MagicMirror successfully.
                                          Do you want use pm2 for auto starting of your MagicMirror (y/N)?y
                                          install and setup pm2
                                          npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.1.1 (node_modules/pm2/node_modules/fsevents):
                                          npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.1.1: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
                                          Created symlink /etc/systemd/system/multi-user.target.wants/pm2-pi.service → /etc/systemd/system/pm2-pi.service.
                                          [PM2] Spawning PM2 daemon with pm2_home=/home/pi/.pm2
                                          [PM2] PM2 Successfully daemonized
                                          [PM2][WARN] Applications MagicMirror not running, starting...
                                          │ id │ name                    │ version │ mode    │ pid      │ uptime │ ↺    │ status   │ cpu      │ mem      │ user     │ watching │
                                          │ 0  │ MagicMirror             │ 2.9.0   │ fork    │ 4228     │ 3s     │ 0    │ online   │ 0%       │ 2.4mb    │ pi       │ enabled  │
                                          [PM2] Saving current process list...
                                          [PM2] Successfully saved in /home/pi/.pm2/dump.pm2
                                          Do you want to disable the screen saver? (y/N)?y
                                          We're ready! Run DISPLAY=:0 npm start from the ~/MagicMirror directory to start your MagicMirror.
                                          pi@RasPiZeroW:~ $ cd MagicMirror/
                                          pi@RasPiZeroW:~/MagicMirror $ DISPLAY=:0 npm start
                                          > magicmirror@2.9.0 start /home/pi/MagicMirror
                                          > sh run-start.sh
                                          additional
                                          pi@RasPiZeroW:~/MagicMirror $ npm audit fix
                                          + helmet@3.21.1
                                          + lodash@4.17.15
                                          added 8 packages from 7 contributors, removed 5 packages and updated 22 packages in 808.897s
                                          fixed 28 of 28 vulnerabilities in 3475 scanned packages
                                          MM is not coming on the screen
                                          I did:
                                          pi@RasPiZeroW:~/MagicMirror $  pm2 ls
                                          │ 0  │ MagicMirror             │ 2.9.0   │ fork    │ 20451    │ 64s    │ 520  │ online   │ 0%       │ 2.5mb    │ pi       │ enabled  │
                                          pi@RasPiZeroW:~/MagicMirror $  pm2 restart mm
                                          [PM2][ERROR] Process mm not found
                                          pi@RasPiZeroW:~/MagicMirror $  cd installers/
                                          pi@RasPiZeroW:~/MagicMirror/installers $  nano mm.sh
                                          pi@RasPiZeroW:~/MagicMirror/installers $ cd ..
                                          pi@RasPiZeroW:~/MagicMirror $ pm2 restart 0
                                          [PM2] Applying action restartProcessId on app [0](ids: 0)
                                          [PM2][ERROR] Process 0 not found
                                          pi@RasPiZeroW:~/MagicMirror/installers $ pm2 start mm.sh
                                          [PM2] Starting /home/pi/MagicMirror/installers/mm.sh in fork_mode (1 instance)
                                          [PM2] Done.
                                          │ 0  │ MagicMirror             │ 2.9.0   │ fork    │ 16261    │ 61s    │ 4340 │ online   │ 0%       │ 2.5mb    │ pi       │ enabled  │
                                          │ 1  │ mm                      │ 2.9.0   │ fork    │ 16293    │ 1s     │ 0    │ online   │ 0%       │ 2.5mb    │ pi       │ disabled │
                                          [PM2][ERROR] Script already launched, add -f option to force re-execution
                                          Can you please give me a hint what my failer in thinking is?
                                          What is missing and what wxactly do I need to do?
                                          Many thanks! :grinning_face:
                                          cheers, bdream
                                            sdetweil @bdream
                                            @bdream ok, a few things…
                                            1. i need to fix the words at the end of install, cause if you said yes to pm2, then don’t do npm start
                                            2. then u went and did a manual add of another thing for pm2…
                                            so,
                                             pm2 stop mm
                                             pm2 delete mm
                                            then
                                            pm2  stop MagicMirror
                                            then lets try manually
                                            npm start
                                            you should see the messages from the mirror running
                                            please advise
                                            • 4 / 6
