    YAPi0 Installer Stretch Lite
    118 Posts 4 Posters 118.1k Views 3 Watching
      bdream
      @sdetweil Raspbian Buster with desktop image already written to the sc-card.
      will see the time I have to work on it next time.
      Stuff arount serveronly and using other browser is to far from me at the moment :unamused_face:
      cheers, bdream
        sdetweil @bdream
        @bdream ok… there is only one MM install… but two ways to run it… so, no problem
          bdream
          @sdetweil many thanks!!
          cheers, bdream
            bdream
            @sdetweil may I come back to you :smiling_face_with_halo:
            I run new installation from scratch on my Rpi0.
            Raspian Buster with desktop
            updated and upgraded and so on
            run your script
             bash -c "$(curl -sL https://www.dropbox.com/s/rlh710ng0zwv3vp/raspberry.sh?dl=0)"
            Node.js installation Done! version=v10.15.2
            npm WARN npm npm does not support Node.js v10.15.2
            npm WARN npm You should probably upgrade to a newer version of node as we
            npm WARN npm can't make any promises that npm will work with this version.
            npm WARN npm Supported releases of Node.js are the latest release of 4, 6, 7, 8, 9.
            npm WARN npm You can find the latest version at https://nodejs.org/
            /usr/local/bin/npm -> /usr/local/lib/node_modules/npm/bin/npm-cli.js
            /usr/local/bin/npx -> /usr/local/lib/node_modules/npm/bin/npx-cli.js
            + npm@6.12.0
            added 430 packages from 839 contributors in 328.327s
            npm installation Done! version=V6.12.0
            Cloning MagicMirror Done!
            Installing dependencies ...
            npm WARN deprecated time-grunt@2.0.0: Deprecated because Grunt is practically unmaintained. Move on to something better. This package will continue to work with Grunt v1, but it will not receive any updates.
            > electron-chromedriver@1.8.0 install /home/pi/MagicMirror/node_modules/electron-chromedriver
            > node ./download-chromedriver.js
            successfully dowloaded and extracted!
            > electron@3.0.13 postinstall /home/pi/MagicMirror/node_modules/electron
            > node install.js
            Downloading tmp-3996-1-SHASUMS256.txt-3.0.13
            [============================================>] 100.0% of 4.79 kB (4.79 kB/s)
            > magicmirror@2.9.0 install /home/pi/MagicMirror
            > cd vendor && npm install
            npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@1.2.4 (node_modules/fsevents):
            npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@1.2.4: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
            added 82 packages from 57 contributors and audited 220 packages in 139.709s
            found 5 vulnerabilities (4 low, 1 high)
              run `npm audit fix` to fix them, or `npm audit` for details
            > magicmirror@2.9.0 postinstall /home/pi/MagicMirror
            > sh untrack-css.sh && sh installers/postinstall/postinstall.sh && npm run install-fonts
            We'll remove from the repository the css/custom.css
            This script apply git update-index --skip-worktree css/custom.css
            rm 'css/custom.css'
            MagicMirror installation successful!
            > magicmirror@2.9.0 install-fonts /home/pi/MagicMirror
            > cd fonts && npm install
            added 1 package from 1 contributor and audited 1 package in 29.697s
            found 0 vulnerabilities
            npm WARN grunt-stylelint@0.11.1 requires a peer of stylelint@^10.0.0 but none is installed. You must install peer dependencies yourself.
            npm WARN acorn-jsx@5.1.0 requires a peer of acorn@^6.0.0 || ^7.0.0 but none is installed. You must install peer dependencies yourself.
            added 1051 packages from 1314 contributors and audited 3475 packages in 1848.766s
            found 28 vulnerabilities (1 low, 1 moderate, 26 high)
            Dependencies installation Done!
            setting up initial config.js
            Check plymouth installation ...
            Splashscreen: Checking themes directory.
            Splashscreen: Create theme directory if not exists.
            Splashscreen: Theme copied successfully.
            Splashscreen: Changed theme to MagicMirror successfully.
            Do you want use pm2 for auto starting of your MagicMirror (y/N)?y
            install and setup pm2
            npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.1.1 (node_modules/pm2/node_modules/fsevents):
            npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.1.1: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
            Created symlink /etc/systemd/system/multi-user.target.wants/pm2-pi.service → /etc/systemd/system/pm2-pi.service.
            [PM2] Spawning PM2 daemon with pm2_home=/home/pi/.pm2
            [PM2] PM2 Successfully daemonized
            [PM2][WARN] Applications MagicMirror not running, starting...
            [PM2] App [MagicMirror] launched (1 instances)
            │ id │ name                    │ version │ mode    │ pid      │ uptime │ ↺    │ status   │ cpu      │ mem      │ user     │ watching │
            │ 0  │ MagicMirror             │ 2.9.0   │ fork    │ 4228     │ 3s     │ 0    │ online   │ 0%       │ 2.4mb    │ pi       │ enabled  │
            [PM2] Saving current process list...
            [PM2] Successfully saved in /home/pi/.pm2/dump.pm2
            Do you want to disable the screen saver? (y/N)?y
            We're ready! Run DISPLAY=:0 npm start from the ~/MagicMirror directory to start your MagicMirror.
            pi@RasPiZeroW:~ $ cd MagicMirror/
            pi@RasPiZeroW:~/MagicMirror $ DISPLAY=:0 npm start
            > magicmirror@2.9.0 start /home/pi/MagicMirror
            > sh run-start.sh
            additional
            pi@RasPiZeroW:~/MagicMirror $ npm audit fix
            + helmet@3.21.1
            + lodash@4.17.15
            added 8 packages from 7 contributors, removed 5 packages and updated 22 packages in 808.897s
            fixed 28 of 28 vulnerabilities in 3475 scanned packages
            MM is not coming on the screen
            I did:
            pi@RasPiZeroW:~/MagicMirror $  pm2 ls
            │ 0  │ MagicMirror             │ 2.9.0   │ fork    │ 20451    │ 64s    │ 520  │ online   │ 0%       │ 2.5mb    │ pi       │ enabled  │
            pi@RasPiZeroW:~/MagicMirror $  pm2 restart mm
            [PM2][ERROR] Process mm not found
            pi@RasPiZeroW:~/MagicMirror $  cd installers/
            pi@RasPiZeroW:~/MagicMirror/installers $  nano mm.sh
            pi@RasPiZeroW:~/MagicMirror/installers $ cd ..
            pi@RasPiZeroW:~/MagicMirror $ pm2 restart 0
            [PM2] Applying action restartProcessId on app [0](ids: 0)
            [PM2][ERROR] Process 0 not found
            pi@RasPiZeroW:~/MagicMirror/installers $ pm2 start mm.sh
            [PM2] Starting /home/pi/MagicMirror/installers/mm.sh in fork_mode (1 instance)
            [PM2] Done.
            │ 0  │ MagicMirror             │ 2.9.0   │ fork    │ 16261    │ 61s    │ 4340 │ online   │ 0%       │ 2.5mb    │ pi       │ enabled  │
            │ 1  │ mm                      │ 2.9.0   │ fork    │ 16293    │ 1s     │ 0    │ online   │ 0%       │ 2.5mb    │ pi       │ disabled │
            [PM2][ERROR] Script already launched, add -f option to force re-execution
            Can you please give me a hint what my failer in thinking is?
            What is missing and what wxactly do I need to do?
            Many thanks! :grinning_face:
            cheers, bdream
              sdetweil @bdream
              @bdream ok, a few things…
              1. i need to fix the words at the end of install, cause if you said yes to pm2, then don’t do npm start
              2. then u went and did a manual add of another thing for pm2…
              so,
               pm2 stop mm
               pm2 delete mm
              then
              pm2  stop MagicMirror
              then lets try manually
              npm start
              you should see the messages from the mirror running
              please advise
                bdream
                Thias is you have to work on:
                @sdetweil said in YAPi0 Installer Stretch Lite:
                I do
                pi@RasPiZeroW:~ $  pm2 stop mm
                not necasarry
                pm2 delete mm
                pi@RasPiZeroW:~ $ pm2  stop MagicMirror
                [PM2] Applying action stopProcessId on app [MagicMirror](ids: 0)
                [PM2] [MagicMirror](0) ✓
                │ id │ name               │ mode     │ ↺    │ status   │ cpu      │ memory   │
                │ 0  │ MagicMirror        │ fork     │ 223  │ stopped  │ 0%       │ 0b       │
                pi@RasPiZeroW:~/MagicMirror $ npm start
                > sh run-start.sh
                nothing happen
                cheers, bdream
                  sdetweil @bdream
                  @bdream weird… now have same problem on two systems…
                  try this
                  node serveronly
                  the connection url will be shown
                  then connect to that url from a browser on another system
                    another thing to try is
                    export DISPLAY=:0
                    node node_modules/.bin/electron
                    electron should come up on the screen
                      bdream
                      no, it dosn’t
                      cheers, bdream
                        sdetweil @bdream
                        @bdream did serveronly mode work?
                          sdetweil @bdream
                          @bdream ok, one more thing to try
                          cd ~/MagicMirror/node_modules
                          mv electron electron.save
                          cd ..
                          npm install electron@latest
                          I am running 6.0.12 on one of my systems
                          then try npm start
                            bdream
                            pi@RasPiZeroW:~/MagicMirror $ npm install electron@latest
                            > electron@6.0.12 postinstall /home/pi/MagicMirror/node_modules/electron
                            > node install.js
                            Downloading tmp-1548-0-electron-v6.0.12-linux-armv6l.zip
                            Error: GET https://github.com/electron/electron/releases/download/v6.0.12/electr                   on-v6.0.12-linux-armv6l.zip returned 404
                            /home/pi/MagicMirror/node_modules/electron/install.js:53
                              throw err
                            Error: Failed to find Electron v6.0.12 for linux-armv6l at https://github.com/el                   ectron/electron/releases/download/v6.0.12/electron-v6.0.12-linux-armv6l.zip
                                at Request.<anonymous> (/home/pi/MagicMirror/node_modules/nugget/index.js:16                   9:61)
                                at Request.emit (events.js:189:13)
                                at Request.onRequestResponse (/home/pi/MagicMirror/node_modules/request/requ                   est.js:1066:10)
                                at ClientRequest.emit (events.js:189:13)
                                at HTTPParser.parserOnIncomingClient [as onIncoming] (_http_client.js:556:21                   )
                                at HTTPParser.parserOnHeadersComplete (_http_common.js:109:17)
                                at TLSSocket.socketOnData (_http_client.js:442:20)
                                at TLSSocket.emit (events.js:189:13)
                                at addChunk (_stream_readable.js:284:12)
                                at readableAddChunk (_stream_readable.js:265:11)
                            npm WARN acorn-jsx@5.1.0 requires a peer of acorn@^6.0.0 || ^7.0.0 but none is i                   nstalled. You must install peer dependencies yourself.
                            npm ERR! code ELIFECYCLE
                            npm ERR! errno 1
                            npm ERR! electron@6.0.12 postinstall: `node install.js`
                            npm ERR! Exit status 1
                            npm ERR!
                            npm ERR! Failed at the electron@6.0.12 postinstall script.
                            npm ERR! This is probably not a problem with npm. There is likely additional log                   ging output above.
                            npm ERR!     /home/pi/.npm/_logs/2019-10-18T13_30_31_697Z-debug.log
                            I would like to attach the log, but it’s missing :pouting_face:
                            > sh run-start.sh
                            run-start.sh: 7: run-start.sh: electron: not found
                            npm ERR! syscall spawn
                            npm ERR! file sh
                            npm ERR! errno ENOENT
                            npm ERR! magicmirror@2.9.0 start: `sh run-start.sh`
                            npm ERR! spawn ENOENT
                            npm ERR!
                            npm ERR! Failed at the magicmirror@2.9.0 start script.
                            npm ERR!     /home/pi/.npm/_logs/2019-10-18T14_07_43_211Z-debug.log
                            cheers, bdream
                              bdream
                              @sdetweil how interesting.
                              If I reboot the RPi0 I see MagicMirror booting too. After a while of black screen I get usal Pi Desktop.
                              cheers, bdream
                                sdetweil @bdream
                                @bdream sorry, forgot about arm6l
                                Do
                                npm install --arch=arm7l electron@latest
                                  bdream
                                  pi@RasPiZeroW:~ $ npm install --arch=arm7l electron@latest
                                  > electron@6.0.12 postinstall /home/pi/node_modules/electron
                                  > node install.js
                                  Downloading tmp-2171-0-electron-v6.0.12-linux-arm7l.zip
                                  Error: GET https://github.com/electron/electron/releases/download/v6.0.12/electron-v6.0.12-linux-arm7l.zip returned 404
                                  /home/pi/node_modules/electron/install.js:53
                                    throw err
                                  Error: Failed to find Electron v6.0.12 for linux-arm7l at https://github.com/electron/electron/releases/download/v6.0.12/electron-v6.0.12-linux-arm7l.zip
                                      at Request.<anonymous> (/home/pi/node_modules/nugget/index.js:169:61)
                                      at Request.onRequestResponse (/home/pi/node_modules/request/request.js:1066:10)
                                      at HTTPParser.parserOnIncomingClient [as onIncoming] (_http_client.js:556:21)
                                  npm WARN enoent ENOENT: no such file or directory, open '/home/pi/package.json'
                                  npm WARN pi No description
                                  npm WARN pi No repository field.
                                  npm WARN pi No README data
                                  npm WARN pi No license field.
                                  npm ERR! errno 1
                                  npm ERR!
                                  npm ERR!     /home/pi/.npm/_logs/2019-10-18T15_04_49_780Z-debug.log
                                  cheers, bdream
                                    sdetweil @bdream
                                    @bdream sorry,. please in the MagicMirror folder
                                    all things MagicMirror should be done from the MagicMirror folder
                                    npm install --arch=armv7l electron@latest
                                    notice the added lowercase V --arch=armV7L (all lowercase)
                                    I get a file download for
                                    https://github.com/electron/electron/releases/download/v6.0.12/electron-v6.0.12-linux-armv7l.zip
                                      @bdream did you have time to look at this?
                                      also, after loading do
                                      cd ~/MagicMirror/node_modules/electron
                                      ldd dist/electron  >>~/logfile.txt
                                      readelf -A  dist/electron >>~/logfile.txt
                                      also
                                      grep electron /var/log/syslog >>~/logfile
                                      and send me ~/logfile.txt
                                      thanks
                                        bdream
                                        Sorry for delay!
                                        logfile is empty :angry_face:
                                        May you what ~/logfile.txt
                                        	/usr/lib/arm-linux-gnueabihf/libarmmem-${PLATFORM}.so => /usr/lib/arm-linux-gnueabihf/libarmmem-v6l.so (0xb2761000)
                                        	libffmpeg.so => /home/pi/MagicMirror/node_modules/electron/dist/libffmpeg.so (0xb2409000)
                                        	libdl.so.2 => /lib/arm-linux-gnueabihf/libdl.so.2 (0xb23e2000)
                                        	libpthread.so.0 => /lib/arm-linux-gnueabihf/libpthread.so.0 (0xb23b8000)
                                        	librt.so.1 => /lib/arm-linux-gnueabihf/librt.so.1 (0xb23a1000)
                                        	libgobject-2.0.so.0 => /usr/lib/arm-linux-gnueabihf/libgobject-2.0.so.0 (0xb2344000)
                                        	libglib-2.0.so.0 => /usr/lib/arm-linux-gnueabihf/libglib-2.0.so.0 (0xb2234000)
                                        	libgio-2.0.so.0 => /usr/lib/arm-linux-gnueabihf/libgio-2.0.so.0 (0xb20b9000)
                                        	libnss3.so => /usr/lib/arm-linux-gnueabihf/libnss3.so (0xb1f9d000)
                                        	libnssutil3.so => /usr/lib/arm-linux-gnueabihf/libnssutil3.so (0xb1f6a000)
                                        	libsmime3.so => /usr/lib/arm-linux-gnueabihf/libsmime3.so (0xb1f39000)
                                        	libnspr4.so => /usr/lib/arm-linux-gnueabihf/libnspr4.so (0xb1ef9000)
                                        	libgdk_pixbuf-2.0.so.0 => /usr/lib/arm-linux-gnueabihf/libgdk_pixbuf-2.0.so.0 (0xb1ec7000)
                                        	libgtk-3.so.0 => /usr/lib/arm-linux-gnueabihf/libgtk-3.so.0 (0xb18b1000)
                                        	libgdk-3.so.0 => /usr/lib/arm-linux-gnueabihf/libgdk-3.so.0 (0xb17d9000)
                                        	libpangocairo-1.0.so.0 => /usr/lib/arm-linux-gnueabihf/libpangocairo-1.0.so.0 (0xb17be000)
                                        	libpango-1.0.so.0 => /usr/lib/arm-linux-gnueabihf/libpango-1.0.so.0 (0xb1771000)
                                        	libatk-1.0.so.0 => /usr/lib/arm-linux-gnueabihf/libatk-1.0.so.0 (0xb1743000)
                                        	libcairo.so.2 => /usr/lib/arm-linux-gnueabihf/libcairo.so.2 (0xb164a000)
                                        	libdbus-1.so.3 => /lib/arm-linux-gnueabihf/libdbus-1.so.3 (0xb15f9000)
                                        	libXext.so.6 => /usr/lib/arm-linux-gnueabihf/libXext.so.6 (0xb15da000)
                                        	libX11.so.6 => /usr/lib/arm-linux-gnueabihf/libX11.so.6 (0xb14b8000)
                                        	libXcomposite.so.1 => /usr/lib/arm-linux-gnueabihf/libXcomposite.so.1 (0xb14a5000)
                                        	libXrender.so.1 => /usr/lib/arm-linux-gnueabihf/libXrender.so.1 (0xb148c000)
                                        	libexpat.so.1 => /lib/arm-linux-gnueabihf/libexpat.so.1 (0xb144b000)
                                        	libuuid.so.1 => /lib/arm-linux-gnueabihf/libuuid.so.1 (0xb1434000)
                                        	libX11-xcb.so.1 => /usr/lib/arm-linux-gnueabihf/libX11-xcb.so.1 (0xb1422000)
                                        	libxcb.so.1 => /usr/lib/arm-linux-gnueabihf/libxcb.so.1 (0xb13f3000)
                                        	libXcursor.so.1 => /usr/lib/arm-linux-gnueabihf/libXcursor.so.1 (0xb13da000)
                                        	libXdamage.so.1 => /usr/lib/arm-linux-gnueabihf/libXdamage.so.1 (0xb13c7000)
                                        	libXfixes.so.3 => /usr/lib/arm-linux-gnueabihf/libXfixes.so.3 (0xb13b2000)
                                        	libXi.so.6 => /usr/lib/arm-linux-gnueabihf/libXi.so.6 (0xb1394000)
                                        	libXtst.so.6 => /usr/lib/arm-linux-gnueabihf/libXtst.so.6 (0xb137f000)
                                        	libXrandr.so.2 => /usr/lib/arm-linux-gnueabihf/libXrandr.so.2 (0xb1366000)
                                        	libXss.so.1 => /usr/lib/arm-linux-gnueabihf/libXss.so.1 (0xb1353000)
                                        	libasound.so.2 => /usr/lib/arm-linux-gnueabihf/libasound.so.2 (0xb1272000)
                                        	libatk-bridge-2.0.so.0 => /usr/lib/arm-linux-gnueabihf/libatk-bridge-2.0.so.0 (0xb1239000)
                                        	libatspi.so.0 => /usr/lib/arm-linux-gnueabihf/libatspi.so.0 (0xb1202000)
                                        	libcups.so.2 => /usr/lib/arm-linux-gnueabihf/libcups.so.2 (0xb1180000)
                                        	libm.so.6 => /lib/arm-linux-gnueabihf/libm.so.6 (0xb10fe000)
                                        	libgcc_s.so.1 => /lib/arm-linux-gnueabihf/libgcc_s.so.1 (0xb10d1000)
                                        	libc.so.6 => /lib/arm-linux-gnueabihf/libc.so.6 (0xb0f83000)
                                        	/lib/ld-linux-armhf.so.3 (0xb6f3e000)
                                        	libffi.so.6 => /usr/lib/arm-linux-gnueabihf/libffi.so.6 (0xb0f6b000)
                                        	libpcre.so.3 => /lib/arm-linux-gnueabihf/libpcre.so.3 (0xb0ef4000)
                                        	libgmodule-2.0.so.0 => /usr/lib/arm-linux-gnueabihf/libgmodule-2.0.so.0 (0xb0ee0000)
                                        	libz.so.1 => /lib/arm-linux-gnueabihf/libz.so.1 (0xb0eb5000)
                                        	libmount.so.1 => /lib/arm-linux-gnueabihf/libmount.so.1 (0xb0e54000)
                                        	libselinux.so.1 => /lib/arm-linux-gnueabihf/libselinux.so.1 (0xb0e22000)
                                        	libresolv.so.2 => /lib/arm-linux-gnueabihf/libresolv.so.2 (0xb0dfe000)
                                        	libplc4.so => /usr/lib/arm-linux-gnueabihf/libplc4.so (0xb0dea000)
                                        	libplds4.so => /usr/lib/arm-linux-gnueabihf/libplds4.so (0xb0dd7000)
                                        	libcairo-gobject.so.2 => /usr/lib/arm-linux-gnueabihf/libcairo-gobject.so.2 (0xb0dc0000)
                                        	libxkbcommon.so.0 => /usr/lib/arm-linux-gnueabihf/libxkbcommon.so.0 (0xb0d77000)
                                        	libwayland-cursor.so.0 => /usr/lib/arm-linux-gnueabihf/libwayland-cursor.so.0 (0xb0d60000)
                                        	libwayland-egl.so.1 => /usr/lib/arm-linux-gnueabihf/libwayland-egl.so.1 (0xb0d4e000)
                                        	libwayland-client.so.0 => /usr/lib/arm-linux-gnueabihf/libwayland-client.so.0 (0xb0d34000)
                                        	libepoxy.so.0 => /usr/lib/arm-linux-gnueabihf/libepoxy.so.0 (0xb0c3e000)
                                        	libharfbuzz.so.0 => /usr/lib/arm-linux-gnueabihf/libharfbuzz.so.0 (0xb0b40000)
                                        	libpangoft2-1.0.so.0 => /usr/lib/arm-linux-gnueabihf/libpangoft2-1.0.so.0 (0xb0b1e000)
                                        	libfontconfig.so.1 => /usr/lib/arm-linux-gnueabihf/libfontconfig.so.1 (0xb0ad6000)
                                        	libfreetype.so.6 => /usr/lib/arm-linux-gnueabihf/libfreetype.so.6 (0xb0a33000)
                                        	libXinerama.so.1 => /usr/lib/arm-linux-gnueabihf/libXinerama.so.1 (0xb0a20000)
                                        	libthai.so.0 => /usr/lib/arm-linux-gnueabihf/libthai.so.0 (0xb0a08000)
                                        	libfribidi.so.0 => /usr/lib/arm-linux-gnueabihf/libfribidi.so.0 (0xb09de000)
                                        	libpixman-1.so.0 => /usr/lib/arm-linux-gnueabihf/libpixman-1.so.0 (0xb0903000)
                                        	libpng16.so.16 => /usr/lib/arm-linux-gnueabihf/libpng16.so.16 (0xb08c7000)
                                        	libxcb-shm.so.0 => /usr/lib/arm-linux-gnueabihf/libxcb-shm.so.0 (0xb08b4000)
                                        	libxcb-render.so.0 => /usr/lib/arm-linux-gnueabihf/libxcb-render.so.0 (0xb0899000)
                                        	libsystemd.so.0 => /lib/arm-linux-gnueabihf/libsystemd.so.0 (0xb07fc000)
                                        	libXau.so.6 => /usr/lib/arm-linux-gnueabihf/libXau.so.6 (0xb07e9000)
                                        	libXdmcp.so.6 => /usr/lib/arm-linux-gnueabihf/libXdmcp.so.6 (0xb07d4000)
                                        	libgssapi_krb5.so.2 => /usr/lib/arm-linux-gnueabihf/libgssapi_krb5.so.2 (0xb078a000)
                                        	libgnutls.so.30 => /usr/lib/arm-linux-gnueabihf/libgnutls.so.30 (0xb05e6000)
                                        	libavahi-common.so.3 => /usr/lib/arm-linux-gnueabihf/libavahi-common.so.3 (0xb05cb000)
                                        	libavahi-client.so.3 => /usr/lib/arm-linux-gnueabihf/libavahi-client.so.3 (0xb05ac000)
                                        	libblkid.so.1 => /lib/arm-linux-gnueabihf/libblkid.so.1 (0xb0554000)
                                        	libgraphite2.so.3 => /usr/lib/arm-linux-gnueabihf/libgraphite2.so.3 (0xb0523000)
                                        	libdatrie.so.1 => /usr/lib/arm-linux-gnueabihf/libdatrie.so.1 (0xb050d000)
                                        	liblzma.so.5 => /lib/arm-linux-gnueabihf/liblzma.so.5 (0xb04dc000)
                                        	liblz4.so.1 => /usr/lib/arm-linux-gnueabihf/liblz4.so.1 (0xb04b0000)
                                        	libgcrypt.so.20 => /lib/arm-linux-gnueabihf/libgcrypt.so.20 (0xb03d6000)
                                        	libbsd.so.0 => /usr/lib/arm-linux-gnueabihf/libbsd.so.0 (0xb03ac000)
                                        	libkrb5.so.3 => /usr/lib/arm-linux-gnueabihf/libkrb5.so.3 (0xb02f1000)
                                        	libk5crypto.so.3 => /usr/lib/arm-linux-gnueabihf/libk5crypto.so.3 (0xb02b1000)
                                        	libcom_err.so.2 => /lib/arm-linux-gnueabihf/libcom_err.so.2 (0xb029e000)
                                        	libkrb5support.so.0 => /usr/lib/arm-linux-gnueabihf/libkrb5support.so.0 (0xb0284000)
                                        	libkeyutils.so.1 => /lib/arm-linux-gnueabihf/libkeyutils.so.1 (0xb0270000)
                                        	libp11-kit.so.0 => /usr/lib/arm-linux-gnueabihf/libp11-kit.so.0 (0xb016b000)
                                        	libidn2.so.0 => /usr/lib/arm-linux-gnueabihf/libidn2.so.0 (0xb013f000)
                                        	libunistring.so.2 => /usr/lib/arm-linux-gnueabihf/libunistring.so.2 (0xaffc3000)
                                        	libtasn1.so.6 => /usr/lib/arm-linux-gnueabihf/libtasn1.so.6 (0xaffa3000)
                                        	libnettle.so.6 => /usr/lib/arm-linux-gnueabihf/libnettle.so.6 (0xaff5d000)
                                        	libhogweed.so.4 => /usr/lib/arm-linux-gnueabihf/libhogweed.so.4 (0xaff1e000)
                                        	libgmp.so.10 => /usr/lib/arm-linux-gnueabihf/libgmp.so.10 (0xafea5000)
                                        	libgpg-error.so.0 => /lib/arm-linux-gnueabihf/libgpg-error.so.0 (0xafe7b000)
                                        Attribute Section: aeabi
                                        File Attributes
                                          Tag_CPU_name: "7-A"
                                          Tag_CPU_arch: v7
                                          Tag_CPU_arch_profile: Application
                                          Tag_ARM_ISA_use: Yes
                                          Tag_THUMB_ISA_use: Thumb-2
                                          Tag_FP_arch: VFPv3-D16
                                          Tag_ABI_PCS_wchar_t: 4
                                          Tag_ABI_FP_rounding: Needed
                                          Tag_ABI_FP_denormal: Needed
                                          Tag_ABI_FP_exceptions: Needed
                                          Tag_ABI_FP_number_model: IEEE 754
                                          Tag_ABI_align_needed: 8-byte
                                          Tag_ABI_align_preserved: 8-byte, except leaf SP
                                          Tag_ABI_enum_size: int
                                          Tag_ABI_VFP_args: VFP registers
                                          Tag_CPU_unaligned_access: v6
                                        cheers, bdream
                                          sdetweil @bdream
                                          @bdream thx.
                                          And if you do
                                          ~/MagicMirror/node_modules/electron/dist/electron
                                          Does it open browser?
                                            bdream
                                            pi@RasPiZeroW:~ $ ~/MagicMirror/node_modules/electron/dist/electron
                                            Speicherzugriffsfehler
                                            pi@RasPiZeroW:~ $ cd ~/MagicMirror/node_modules/electron/dist/electron
                                            -bash: cd: /home/pi/MagicMirror/node_modules/electron/dist/electron: Ist kein Verzeichnis
                                            pi@RasPiZeroW:~/MagicMirror/node_modules/electron/dist $ ls -la
                                            insgesamt 107480
                                            drwxr-xr-x 4 pi pi     4096 Okt 19 10:56 .
                                            drwxr-xr-x 4 pi pi     4096 Okt 19 10:56 ..
                                            -rw-r--r-- 1 pi pi   145945 Okt 19 10:55 chrome_100_percent.pak
                                            -rw-r--r-- 1 pi pi   209147 Okt 19 10:55 chrome_200_percent.pak
                                            -rwxr-xr-x 1 pi pi  4202140 Okt 19 10:56 chrome-sandbox
                                            -rwxr-xr-x 1 pi pi 74648480 Okt 19 10:55 electron
                                            -rw-r--r-- 1 pi pi 10410272 Okt 19 10:55 icudtl.dat
                                            -rwxr-xr-x 1 pi pi   157372 Okt 19 10:55 libEGL.so
                                            -rwxr-xr-x 1 pi pi  1949660 Okt 19 10:55 libffmpeg.so
                                            -rwxr-xr-x 1 pi pi  4883208 Okt 19 10:55 libGLESv2.so
                                            -rw-r--r-- 1 pi pi     1060 Okt 19 10:54 LICENSE
                                            -rw-r--r-- 1 pi pi  3961766 Okt 19 10:54 LICENSES.chromium.html
                                            drwxr-xr-x 2 pi pi     4096 Okt 19 10:56 locales
                                            -rw-r--r-- 1 pi pi    83237 Okt 19 10:55 natives_blob.bin
                                            drwxr-xr-x 2 pi pi     4096 Okt 19 10:55 resources
                                            -rw-r--r-- 1 pi pi  8471329 Okt 19 10:54 resources.pak
                                            -rw-r--r-- 1 pi pi   275792 Okt 19 10:55 snapshot_blob.bin
                                            -rw-r--r-- 1 pi pi   608820 Okt 19 10:56 v8_context_snapshot.bin
                                            -rw-r--r-- 1 pi pi        6 Okt 19 10:55 version
                                            do I need to do eny else as ?
                                            cheers, bdream
                                            • 4 / 6
