    YAPi0 Installer Stretch Lite
    118 Posts 4 Posters 112.6k Views 3 Watching
      sdetweil @bdream
      @bdream ok, one more thing to try
      cd ~/MagicMirror/node_modules
      mv electron electron.save
      cd ..
      npm install electron@latest
      I am running 6.0.12 on one of my systems
      then try npm start
        bdream
        pi@RasPiZeroW:~/MagicMirror $ npm install electron@latest
        > electron@6.0.12 postinstall /home/pi/MagicMirror/node_modules/electron
        > node install.js
        Downloading tmp-1548-0-electron-v6.0.12-linux-armv6l.zip
        Error: GET https://github.com/electron/electron/releases/download/v6.0.12/electr                   on-v6.0.12-linux-armv6l.zip returned 404
        /home/pi/MagicMirror/node_modules/electron/install.js:53
          throw err
        Error: Failed to find Electron v6.0.12 for linux-armv6l at https://github.com/el                   ectron/electron/releases/download/v6.0.12/electron-v6.0.12-linux-armv6l.zip
            at Request.<anonymous> (/home/pi/MagicMirror/node_modules/nugget/index.js:16                   9:61)
            at Request.emit (events.js:189:13)
            at Request.onRequestResponse (/home/pi/MagicMirror/node_modules/request/requ                   est.js:1066:10)
            at ClientRequest.emit (events.js:189:13)
            at HTTPParser.parserOnIncomingClient [as onIncoming] (_http_client.js:556:21                   )
            at HTTPParser.parserOnHeadersComplete (_http_common.js:109:17)
            at TLSSocket.socketOnData (_http_client.js:442:20)
            at TLSSocket.emit (events.js:189:13)
            at addChunk (_stream_readable.js:284:12)
            at readableAddChunk (_stream_readable.js:265:11)
        npm WARN acorn-jsx@5.1.0 requires a peer of acorn@^6.0.0 || ^7.0.0 but none is i                   nstalled. You must install peer dependencies yourself.
        npm WARN grunt-stylelint@0.11.1 requires a peer of stylelint@^10.0.0 but none is                    installed. You must install peer dependencies yourself.
        npm ERR! code ELIFECYCLE
        npm ERR! errno 1
        npm ERR! electron@6.0.12 postinstall: `node install.js`
        npm ERR! Exit status 1
        npm ERR!
        npm ERR! Failed at the electron@6.0.12 postinstall script.
        npm ERR! This is probably not a problem with npm. There is likely additional log                   ging output above.
        npm ERR!     /home/pi/.npm/_logs/2019-10-18T13_30_31_697Z-debug.log
        I would like to attach the log, but it’s missing :pouting_face:
        pi@RasPiZeroW:~/MagicMirror $ npm start
        > magicmirror@2.9.0 start /home/pi/MagicMirror
        > sh run-start.sh
        run-start.sh: 7: run-start.sh: electron: not found
        npm ERR! syscall spawn
        npm ERR! file sh
        npm ERR! errno ENOENT
        npm ERR! magicmirror@2.9.0 start: `sh run-start.sh`
        npm ERR! spawn ENOENT
        npm ERR!
        npm ERR! Failed at the magicmirror@2.9.0 start script.
        npm ERR!     /home/pi/.npm/_logs/2019-10-18T14_07_43_211Z-debug.log
        cheers, bdream
          bdream
          @sdetweil how interesting.
          If I reboot the RPi0 I see MagicMirror booting too. After a while of black screen I get usal Pi Desktop.
          cheers, bdream
            sdetweil @bdream
            @bdream sorry, forgot about arm6l
            Do
            npm install --arch=arm7l electron@latest
              bdream
              pi@RasPiZeroW:~ $ npm install --arch=arm7l electron@latest
              > electron@6.0.12 postinstall /home/pi/node_modules/electron
              > node install.js
              Downloading tmp-2171-0-electron-v6.0.12-linux-arm7l.zip
              Error: GET https://github.com/electron/electron/releases/download/v6.0.12/electron-v6.0.12-linux-arm7l.zip returned 404
              /home/pi/node_modules/electron/install.js:53
                throw err
              Error: Failed to find Electron v6.0.12 for linux-arm7l at https://github.com/electron/electron/releases/download/v6.0.12/electron-v6.0.12-linux-arm7l.zip
                  at Request.<anonymous> (/home/pi/node_modules/nugget/index.js:169:61)
                  at Request.onRequestResponse (/home/pi/node_modules/request/request.js:1066:10)
                  at HTTPParser.parserOnIncomingClient [as onIncoming] (_http_client.js:556:21)
              npm WARN enoent ENOENT: no such file or directory, open '/home/pi/package.json'
              npm WARN pi No description
              npm WARN pi No repository field.
              npm WARN pi No README data
              npm WARN pi No license field.
              npm ERR! errno 1
              npm ERR!
              npm ERR!     /home/pi/.npm/_logs/2019-10-18T15_04_49_780Z-debug.log
              cheers, bdream
                sdetweil @bdream
                @bdream sorry,. please in the MagicMirror folder
                all things MagicMirror should be done from the MagicMirror folder
                npm install --arch=armv7l electron@latest
                notice the added lowercase V --arch=armV7L (all lowercase)
                I get a file download for
                https://github.com/electron/electron/releases/download/v6.0.12/electron-v6.0.12-linux-armv7l.zip
                  @bdream did you have time to look at this?
                  also, after loading do
                  cd ~/MagicMirror/node_modules/electron
                  ldd dist/electron  >>~/logfile.txt
                  readelf -A  dist/electron >>~/logfile.txt
                  also
                  grep electron /var/log/syslog >>~/logfile
                  and send me ~/logfile.txt
                  thanks
                    bdream
                    @sdetweil said in YAPi0 Installer Stretch Lite:
                    Sorry for delay!
                    logfile is empty :angry_face:
                    May you what ~/logfile.txt
                    	/usr/lib/arm-linux-gnueabihf/libarmmem-${PLATFORM}.so => /usr/lib/arm-linux-gnueabihf/libarmmem-v6l.so (0xb2761000)
                    	libffmpeg.so => /home/pi/MagicMirror/node_modules/electron/dist/libffmpeg.so (0xb2409000)
                    	libdl.so.2 => /lib/arm-linux-gnueabihf/libdl.so.2 (0xb23e2000)
                    	libpthread.so.0 => /lib/arm-linux-gnueabihf/libpthread.so.0 (0xb23b8000)
                    	librt.so.1 => /lib/arm-linux-gnueabihf/librt.so.1 (0xb23a1000)
                    	libgobject-2.0.so.0 => /usr/lib/arm-linux-gnueabihf/libgobject-2.0.so.0 (0xb2344000)
                    	libglib-2.0.so.0 => /usr/lib/arm-linux-gnueabihf/libglib-2.0.so.0 (0xb2234000)
                    	libgio-2.0.so.0 => /usr/lib/arm-linux-gnueabihf/libgio-2.0.so.0 (0xb20b9000)
                    	libnss3.so => /usr/lib/arm-linux-gnueabihf/libnss3.so (0xb1f9d000)
                    	libnssutil3.so => /usr/lib/arm-linux-gnueabihf/libnssutil3.so (0xb1f6a000)
                    	libsmime3.so => /usr/lib/arm-linux-gnueabihf/libsmime3.so (0xb1f39000)
                    	libnspr4.so => /usr/lib/arm-linux-gnueabihf/libnspr4.so (0xb1ef9000)
                    	libgdk_pixbuf-2.0.so.0 => /usr/lib/arm-linux-gnueabihf/libgdk_pixbuf-2.0.so.0 (0xb1ec7000)
                    	libgtk-3.so.0 => /usr/lib/arm-linux-gnueabihf/libgtk-3.so.0 (0xb18b1000)
                    	libgdk-3.so.0 => /usr/lib/arm-linux-gnueabihf/libgdk-3.so.0 (0xb17d9000)
                    	libpangocairo-1.0.so.0 => /usr/lib/arm-linux-gnueabihf/libpangocairo-1.0.so.0 (0xb17be000)
                    	libpango-1.0.so.0 => /usr/lib/arm-linux-gnueabihf/libpango-1.0.so.0 (0xb1771000)
                    	libatk-1.0.so.0 => /usr/lib/arm-linux-gnueabihf/libatk-1.0.so.0 (0xb1743000)
                    	libcairo.so.2 => /usr/lib/arm-linux-gnueabihf/libcairo.so.2 (0xb164a000)
                    	libdbus-1.so.3 => /lib/arm-linux-gnueabihf/libdbus-1.so.3 (0xb15f9000)
                    	libXext.so.6 => /usr/lib/arm-linux-gnueabihf/libXext.so.6 (0xb15da000)
                    	libX11.so.6 => /usr/lib/arm-linux-gnueabihf/libX11.so.6 (0xb14b8000)
                    	libXcomposite.so.1 => /usr/lib/arm-linux-gnueabihf/libXcomposite.so.1 (0xb14a5000)
                    	libXrender.so.1 => /usr/lib/arm-linux-gnueabihf/libXrender.so.1 (0xb148c000)
                    	libexpat.so.1 => /lib/arm-linux-gnueabihf/libexpat.so.1 (0xb144b000)
                    	libuuid.so.1 => /lib/arm-linux-gnueabihf/libuuid.so.1 (0xb1434000)
                    	libX11-xcb.so.1 => /usr/lib/arm-linux-gnueabihf/libX11-xcb.so.1 (0xb1422000)
                    	libxcb.so.1 => /usr/lib/arm-linux-gnueabihf/libxcb.so.1 (0xb13f3000)
                    	libXcursor.so.1 => /usr/lib/arm-linux-gnueabihf/libXcursor.so.1 (0xb13da000)
                    	libXdamage.so.1 => /usr/lib/arm-linux-gnueabihf/libXdamage.so.1 (0xb13c7000)
                    	libXfixes.so.3 => /usr/lib/arm-linux-gnueabihf/libXfixes.so.3 (0xb13b2000)
                    	libXi.so.6 => /usr/lib/arm-linux-gnueabihf/libXi.so.6 (0xb1394000)
                    	libXtst.so.6 => /usr/lib/arm-linux-gnueabihf/libXtst.so.6 (0xb137f000)
                    	libXrandr.so.2 => /usr/lib/arm-linux-gnueabihf/libXrandr.so.2 (0xb1366000)
                    	libXss.so.1 => /usr/lib/arm-linux-gnueabihf/libXss.so.1 (0xb1353000)
                    	libasound.so.2 => /usr/lib/arm-linux-gnueabihf/libasound.so.2 (0xb1272000)
                    	libatk-bridge-2.0.so.0 => /usr/lib/arm-linux-gnueabihf/libatk-bridge-2.0.so.0 (0xb1239000)
                    	libatspi.so.0 => /usr/lib/arm-linux-gnueabihf/libatspi.so.0 (0xb1202000)
                    	libcups.so.2 => /usr/lib/arm-linux-gnueabihf/libcups.so.2 (0xb1180000)
                    	libm.so.6 => /lib/arm-linux-gnueabihf/libm.so.6 (0xb10fe000)
                    	libgcc_s.so.1 => /lib/arm-linux-gnueabihf/libgcc_s.so.1 (0xb10d1000)
                    	libc.so.6 => /lib/arm-linux-gnueabihf/libc.so.6 (0xb0f83000)
                    	/lib/ld-linux-armhf.so.3 (0xb6f3e000)
                    	libffi.so.6 => /usr/lib/arm-linux-gnueabihf/libffi.so.6 (0xb0f6b000)
                    	libpcre.so.3 => /lib/arm-linux-gnueabihf/libpcre.so.3 (0xb0ef4000)
                    	libgmodule-2.0.so.0 => /usr/lib/arm-linux-gnueabihf/libgmodule-2.0.so.0 (0xb0ee0000)
                    	libz.so.1 => /lib/arm-linux-gnueabihf/libz.so.1 (0xb0eb5000)
                    	libmount.so.1 => /lib/arm-linux-gnueabihf/libmount.so.1 (0xb0e54000)
                    	libselinux.so.1 => /lib/arm-linux-gnueabihf/libselinux.so.1 (0xb0e22000)
                    	libresolv.so.2 => /lib/arm-linux-gnueabihf/libresolv.so.2 (0xb0dfe000)
                    	libplc4.so => /usr/lib/arm-linux-gnueabihf/libplc4.so (0xb0dea000)
                    	libplds4.so => /usr/lib/arm-linux-gnueabihf/libplds4.so (0xb0dd7000)
                    	libcairo-gobject.so.2 => /usr/lib/arm-linux-gnueabihf/libcairo-gobject.so.2 (0xb0dc0000)
                    	libxkbcommon.so.0 => /usr/lib/arm-linux-gnueabihf/libxkbcommon.so.0 (0xb0d77000)
                    	libwayland-cursor.so.0 => /usr/lib/arm-linux-gnueabihf/libwayland-cursor.so.0 (0xb0d60000)
                    	libwayland-egl.so.1 => /usr/lib/arm-linux-gnueabihf/libwayland-egl.so.1 (0xb0d4e000)
                    	libwayland-client.so.0 => /usr/lib/arm-linux-gnueabihf/libwayland-client.so.0 (0xb0d34000)
                    	libepoxy.so.0 => /usr/lib/arm-linux-gnueabihf/libepoxy.so.0 (0xb0c3e000)
                    	libharfbuzz.so.0 => /usr/lib/arm-linux-gnueabihf/libharfbuzz.so.0 (0xb0b40000)
                    	libpangoft2-1.0.so.0 => /usr/lib/arm-linux-gnueabihf/libpangoft2-1.0.so.0 (0xb0b1e000)
                    	libfontconfig.so.1 => /usr/lib/arm-linux-gnueabihf/libfontconfig.so.1 (0xb0ad6000)
                    	libfreetype.so.6 => /usr/lib/arm-linux-gnueabihf/libfreetype.so.6 (0xb0a33000)
                    	libXinerama.so.1 => /usr/lib/arm-linux-gnueabihf/libXinerama.so.1 (0xb0a20000)
                    	libthai.so.0 => /usr/lib/arm-linux-gnueabihf/libthai.so.0 (0xb0a08000)
                    	libfribidi.so.0 => /usr/lib/arm-linux-gnueabihf/libfribidi.so.0 (0xb09de000)
                    	libpixman-1.so.0 => /usr/lib/arm-linux-gnueabihf/libpixman-1.so.0 (0xb0903000)
                    	libpng16.so.16 => /usr/lib/arm-linux-gnueabihf/libpng16.so.16 (0xb08c7000)
                    	libxcb-shm.so.0 => /usr/lib/arm-linux-gnueabihf/libxcb-shm.so.0 (0xb08b4000)
                    	libxcb-render.so.0 => /usr/lib/arm-linux-gnueabihf/libxcb-render.so.0 (0xb0899000)
                    	libsystemd.so.0 => /lib/arm-linux-gnueabihf/libsystemd.so.0 (0xb07fc000)
                    	libXau.so.6 => /usr/lib/arm-linux-gnueabihf/libXau.so.6 (0xb07e9000)
                    	libXdmcp.so.6 => /usr/lib/arm-linux-gnueabihf/libXdmcp.so.6 (0xb07d4000)
                    	libgssapi_krb5.so.2 => /usr/lib/arm-linux-gnueabihf/libgssapi_krb5.so.2 (0xb078a000)
                    	libgnutls.so.30 => /usr/lib/arm-linux-gnueabihf/libgnutls.so.30 (0xb05e6000)
                    	libavahi-common.so.3 => /usr/lib/arm-linux-gnueabihf/libavahi-common.so.3 (0xb05cb000)
                    	libavahi-client.so.3 => /usr/lib/arm-linux-gnueabihf/libavahi-client.so.3 (0xb05ac000)
                    	libblkid.so.1 => /lib/arm-linux-gnueabihf/libblkid.so.1 (0xb0554000)
                    	libgraphite2.so.3 => /usr/lib/arm-linux-gnueabihf/libgraphite2.so.3 (0xb0523000)
                    	libdatrie.so.1 => /usr/lib/arm-linux-gnueabihf/libdatrie.so.1 (0xb050d000)
                    	liblzma.so.5 => /lib/arm-linux-gnueabihf/liblzma.so.5 (0xb04dc000)
                    	liblz4.so.1 => /usr/lib/arm-linux-gnueabihf/liblz4.so.1 (0xb04b0000)
                    	libgcrypt.so.20 => /lib/arm-linux-gnueabihf/libgcrypt.so.20 (0xb03d6000)
                    	libbsd.so.0 => /usr/lib/arm-linux-gnueabihf/libbsd.so.0 (0xb03ac000)
                    	libkrb5.so.3 => /usr/lib/arm-linux-gnueabihf/libkrb5.so.3 (0xb02f1000)
                    	libk5crypto.so.3 => /usr/lib/arm-linux-gnueabihf/libk5crypto.so.3 (0xb02b1000)
                    	libcom_err.so.2 => /lib/arm-linux-gnueabihf/libcom_err.so.2 (0xb029e000)
                    	libkrb5support.so.0 => /usr/lib/arm-linux-gnueabihf/libkrb5support.so.0 (0xb0284000)
                    	libkeyutils.so.1 => /lib/arm-linux-gnueabihf/libkeyutils.so.1 (0xb0270000)
                    	libp11-kit.so.0 => /usr/lib/arm-linux-gnueabihf/libp11-kit.so.0 (0xb016b000)
                    	libidn2.so.0 => /usr/lib/arm-linux-gnueabihf/libidn2.so.0 (0xb013f000)
                    	libunistring.so.2 => /usr/lib/arm-linux-gnueabihf/libunistring.so.2 (0xaffc3000)
                    	libtasn1.so.6 => /usr/lib/arm-linux-gnueabihf/libtasn1.so.6 (0xaffa3000)
                    	libnettle.so.6 => /usr/lib/arm-linux-gnueabihf/libnettle.so.6 (0xaff5d000)
                    	libhogweed.so.4 => /usr/lib/arm-linux-gnueabihf/libhogweed.so.4 (0xaff1e000)
                    	libgmp.so.10 => /usr/lib/arm-linux-gnueabihf/libgmp.so.10 (0xafea5000)
                    	libgpg-error.so.0 => /lib/arm-linux-gnueabihf/libgpg-error.so.0 (0xafe7b000)
                    Attribute Section: aeabi
                    File Attributes
                      Tag_CPU_name: "7-A"
                      Tag_CPU_arch: v7
                      Tag_CPU_arch_profile: Application
                      Tag_ARM_ISA_use: Yes
                      Tag_THUMB_ISA_use: Thumb-2
                      Tag_FP_arch: VFPv3-D16
                      Tag_ABI_PCS_wchar_t: 4
                      Tag_ABI_FP_rounding: Needed
                      Tag_ABI_FP_denormal: Needed
                      Tag_ABI_FP_exceptions: Needed
                      Tag_ABI_FP_number_model: IEEE 754
                      Tag_ABI_align_needed: 8-byte
                      Tag_ABI_align_preserved: 8-byte, except leaf SP
                      Tag_ABI_enum_size: int
                      Tag_ABI_VFP_args: VFP registers
                      Tag_CPU_unaligned_access: v6
                    cheers, bdream
                      sdetweil @bdream
                      @bdream thx.
                      And if you do
                      ~/MagicMirror/node_modules/electron/dist/electron
                      Does it open browser?
                        bdream
                        pi@RasPiZeroW:~ $ ~/MagicMirror/node_modules/electron/dist/electron
                        Speicherzugriffsfehler
                        pi@RasPiZeroW:~ $ cd ~/MagicMirror/node_modules/electron/dist/electron
                        -bash: cd: /home/pi/MagicMirror/node_modules/electron/dist/electron: Ist kein Verzeichnis
                        pi@RasPiZeroW:~/MagicMirror/node_modules/electron/dist $ ls -la
                        insgesamt 107480
                        drwxr-xr-x 4 pi pi     4096 Okt 19 10:56 .
                        drwxr-xr-x 4 pi pi     4096 Okt 19 10:56 ..
                        -rw-r--r-- 1 pi pi   145945 Okt 19 10:55 chrome_100_percent.pak
                        -rw-r--r-- 1 pi pi   209147 Okt 19 10:55 chrome_200_percent.pak
                        -rwxr-xr-x 1 pi pi  4202140 Okt 19 10:56 chrome-sandbox
                        -rwxr-xr-x 1 pi pi 74648480 Okt 19 10:55 electron
                        -rw-r--r-- 1 pi pi 10410272 Okt 19 10:55 icudtl.dat
                        -rwxr-xr-x 1 pi pi   157372 Okt 19 10:55 libEGL.so
                        -rwxr-xr-x 1 pi pi  1949660 Okt 19 10:55 libffmpeg.so
                        -rwxr-xr-x 1 pi pi  4883208 Okt 19 10:55 libGLESv2.so
                        -rw-r--r-- 1 pi pi     1060 Okt 19 10:54 LICENSE
                        -rw-r--r-- 1 pi pi  3961766 Okt 19 10:54 LICENSES.chromium.html
                        drwxr-xr-x 2 pi pi     4096 Okt 19 10:56 locales
                        -rw-r--r-- 1 pi pi    83237 Okt 19 10:55 natives_blob.bin
                        drwxr-xr-x 2 pi pi     4096 Okt 19 10:55 resources
                        -rw-r--r-- 1 pi pi  8471329 Okt 19 10:54 resources.pak
                        -rw-r--r-- 1 pi pi   275792 Okt 19 10:55 snapshot_blob.bin
                        -rw-r--r-- 1 pi pi   608820 Okt 19 10:56 v8_context_snapshot.bin
                        -rw-r--r-- 1 pi pi        6 Okt 19 10:55 version
                        do I need to do eny else as ?
                        cheers, bdream
                          sdetweil @bdream
                          @bdream said in YAPi0 Installer Stretch Lite:
                          no… I am researching the cause…
                          thanks
                          does
                          node serveronly
                          then use another browser to open the url shown
                          work?
                            bdream
                            that means, I need to install another browser?
                            Have you advise please?
                            cheers, bdream
                              sdetweil @bdream
                              @bdream there is a browser installed… its that globe on the task bar… Chrome also is a nice browser
                              i wonder if this is a Raspian Buster problem…
                              I have a pi 0 w coming today.
                              you and another user are having the same trouble. both have armv6l devices and are using Buster.
                                I see some debug for the current problem
                                do
                                export ELECTRON_ENABLE_LOGGING=true
                                export ELECTRON_ENABLE_STACK_DUMPING=true
                                thanks
                                  @bdream also can u do
                                  ldd --version
                                  thanks
                                    bdream
                                    But I installed the armv7l :dizzy_face:
                                    Yes, there is the globe…
                                    …and it success. localhost:8080 directs to MagicMirror² within all the standard modules :smiling_face:
                                    Anyway I do the debucg stuff:
                                    :backhand_index_pointing_up_light_skin_tone: um.
                                    I had to ctrl-c the action (on ssh console) while the browser (on the pi itself) already run MagicMirror
                                    pi@RasPiZeroW:~/MagicMirror $ node serveronly
                                    Starting MagicMirror: v2.9.0
                                    Loading config ...
                                    Loading module helpers ...
                                    All module helpers loaded.
                                    Server started ...
                                    Starting module: newsfeed
                                    Ready to go! Please point your browser to: http://localhost:8080
                                    Create new calendar fetcher for url: http://www.calendarlabs.com/ical-calendar/ics/76/US_Holidays.ics - Interval: 300000
                                    Create new news fetcher for url: http://www.nytimes.com/services/xml/rss/nyt/HomePage.xml - Interval: 300000
                                    ^C[SIGINT] Received. Shutting down server...
                                    Stopping module helper: updatenotification
                                    Stopping module helper: calendar
                                    Stopping module helper: newsfeed
                                    I got an storage acess error here.
                                    just reboot and again storage acess error.
                                    If I’m right, I can config the system running with standard browser.
                                    Can you tell me what exactly I need to do therefor?
                                    …and MagicMirror² run in this browser (It’s the Chromium) but not screenfilling.
                                    And, would it make sense deinstalling Electron then? How? :face_screaming_in_fear:
                                    Ohh, no. It sais localhost declined access :( why that is was running before?
                                    Any about this configurations?
                                    cheers, bdream
                                      sdetweil @bdream
                                      @bdream no reason to uninstall electron…
                                      to start mm using server only and then chrome
                                      edit ~/MagicMirror/run-start.sh
                                      comment out
                                      #electron js/electron.js $1
                                      then add
                                      # this starts the server in the background
                                      node serveronly &
                                      # waits 10 seconds -- you may need to increase this time
                                      sleep 10
                                      #you should test this from a command prompt window
                                      chromium-browser -kiosk -start_maximized http://localhost:8080
                                      then pm2 start MagicMirror will launch this file.
                                        bdream
                                        pi@RasPiZeroW:~/MagicMirror $ node serveronly &
                                        [1] 3121
                                        pi@RasPiZeroW:~/MagicMirror $ chromium-browser -kiosk -start_maximized http://localhost:8080
                                        [3127:3127:1020/181325.903037:ERROR:browser_main_loop.cc(596)] Failed to put Xlib into threaded mode.
                                        (chromium-browser:3127): Gtk-WARNING **: 18:13:26.114: cannot open display:
                                        pi@RasPiZeroW:~/MagicMirror $ Starting MagicMirror: v2.9.0
                                        Loading config ...
                                        Server started ...
                                        cheers, bdream
                                          sdetweil @bdream
                                          @bdream
                                          add
                                          export DISPLAY=:0
                                          in front of
                                          chromium...
                                            bdream
                                            export DISPLAY=:0
                                            that is I should know. SORRY!
                                            Get the information that Chromium is not the standardbrowser
                                            cheers, bdream
                                            • 5 / 6
