    YAPi0 Installer Stretch Lite
    118 Posts 4 Posters 115.6k Views 3 Watching
      @bdream also can u do
      ldd --version
      thanks
        bdream
        @sdetweil said in YAPi0 Installer Stretch Lite:
        you and another user are having the same trouble. both have armv6l devices and are using Buster.
        But I installed the armv7l :dizzy_face:
        npm install --arch=armv7l electron@latest
        there is a browser installed… its that globe on the task bar… Chrome also is a nice browser
        Yes, there is the globe…
        …and it success. localhost:8080 directs to MagicMirror² within all the standard modules :smiling_face:
        Anyway I do the debucg stuff:
        :backhand_index_pointing_up_light_skin_tone: um.
        I had to ctrl-c the action (on ssh console) while the browser (on the pi itself) already run MagicMirror
        pi@RasPiZeroW:~/MagicMirror $ node serveronly
        Starting MagicMirror: v2.9.0
        Loading config ...
        Loading module helpers ...
        All module helpers loaded.
        Server started ...
        Starting module: newsfeed
        Ready to go! Please point your browser to: http://localhost:8080
        Create new calendar fetcher for url: http://www.calendarlabs.com/ical-calendar/ics/76/US_Holidays.ics - Interval: 300000
        Create new news fetcher for url: http://www.nytimes.com/services/xml/rss/nyt/HomePage.xml - Interval: 300000
        ^C[SIGINT] Received. Shutting down server...
        Stopping module helper: updatenotification
        Stopping module helper: calendar
        Stopping module helper: newsfeed
        export ELECTRON_ENABLE_LOGGING=true
        export ELECTRON_ENABLE_STACK_DUMPING=true
        ~/MagicMirror/node_modules/electron/dist/electron
        I got an storage acess error here.
        just reboot and again storage acess error.
        If I’m right, I can config the system running with standard browser.
        Can you tell me what exactly I need to do therefor?
        …and MagicMirror² run in this browser (It’s the Chromium) but not screenfilling.
        And, would it make sense deinstalling Electron then? How? :face_screaming_in_fear:
        Ohh, no. It sais localhost declined access :( why that is was running before?
        Any about this configurations?
        cheers, bdream
          sdetweil @bdream
          @bdream no reason to uninstall electron…
          to start mm using server only and then chrome
          edit ~/MagicMirror/run-start.sh
          comment out
          #electron js/electron.js $1
          then add
          # this starts the server in the background
          node serveronly &
          # waits 10 seconds -- you may need to increase this time
          sleep 10
          #you should test this from a command prompt window
          chromium-browser -kiosk -start_maximized http://localhost:8080
          then pm2 start MagicMirror will launch this file.
            bdream
            pi@RasPiZeroW:~/MagicMirror $ node serveronly &
            [1] 3121
            pi@RasPiZeroW:~/MagicMirror $ chromium-browser -kiosk -start_maximized http://localhost:8080
            [3127:3127:1020/181325.903037:ERROR:browser_main_loop.cc(596)] Failed to put Xlib into threaded mode.
            (chromium-browser:3127): Gtk-WARNING **: 18:13:26.114: cannot open display:
            pi@RasPiZeroW:~/MagicMirror $ Starting MagicMirror: v2.9.0
            Loading config ...
            Server started ...
            cheers, bdream
              sdetweil @bdream
              @bdream
              add
              export DISPLAY=:0
              in front of
              chromium...
                bdream
                export DISPLAY=:0
                that is I should know. SORRY!
                Get the information that Chromium is not the standardbrowser
                cheers, bdream
                  sdetweil @bdream
                  @bdream
                  yes, set as default
                    bdream
                    ahh, I have to make it standard ;)
                    it works now. That was a hard born (is this I can say in englich? :dizzy_face: )
                    RBB
                    cheers, bdream
                      sdetweil @bdream
                      @bdream very hard!!!.. bug in electron I THINK with glibc on buster…
                      i think if you went back to raspian stretch it would have worked with electron
                      I will test that when my pi 0 gets here
                        bdream @sdetweil
                        @sdetweil many, many thanks to you Sam!
                        To recab,
                        I need your script, not any Updates and Upgrades of raspbian System, and the last Chat entries?
                        Can I run it on Rpi1 also?
                        And you woumd prefer Streich instead of Buster?
                        cheers, bdream
                        B S 2 Replies Last reply Reply Quote 0
                          bdream @bdream
                          @bdream excuse my typos!
                          cheers, bdream
                            sdetweil @bdream
                            @bdream said in YAPi0 Installer Stretch Lite:
                            yes, any pi version, plus odroid, jetson nano, ubuntu, macOS, Sierra-Catalina (all i have tested on)
                            And you would prefer Streich instead of Buster?
                            the bug is caused by a newer version of glibc (2.28), and buster has that, while stretch has 2.27
                            so, i think (will test myself later), with stretch, you would not need to use chrome browser
                              bdream
                              Great Sam!
                              I have next week some time and will try with Pi0 and Pi1 both ways:
                              1. Buster and additions
                              2. Strech
                                let you know results.
                              For now I will close this threat as solved
                              :smiling_face_with_open_mouth_closed_eyes: :grinning_face: :smiling_face_with_open_mouth: :smiling_face_with_open_mouth_smiling_eyes: :hugging_face: :hugging_face: :hugging_face:
                              cheers, bdream
                                sdetweil @bdream
                                @bdream good or bad news, I can create the problem on stretch on my pi0 w
                                so, more work to do figure out the problem…
                                  bdream
                                  You got your Pi0W :clapping_hands: have fun with this little thing :winking_face:
                                  …so no need to get strech installed instead of buster?
                                  cheers, bdream
                                    bdream
                                    just added -noerrdialogs getting rid of any messages from the browser.
                                    chromium-browser -noerrdialogs -kiosk -start_maximized http://localhost:8080
                                    cheers, bdream
                                      sdetweil @bdream
                                      @bdream would u be willing to look at some new options for your environment? see this topic
                                      https://forum.magicmirror.builders/topic/11433/proposed-new-processing-and-config-for-pi0-armv6-and-serveronly-mode
                                        bdream
                                        @sdetweil Hi Sam, u ask me to exchange my run-start.sh with your mentioned input?
                                        and do a reboot?
                                        cheers, bdream
                                          sdetweil @bdream
                                          @bdream really do you think it is a good idea?
                                          if u want to try it
                                          3 changes
                                          1. replace file (save old one)
                                          2 chmod +x run-start.sh
                                          3. edit package,json
                                              change
                                                    "start": "sh run-start.sh",
                                               to
                                                    "start": "./run-start.sh",
                                          for install we would move electron to the optional section, so install will finish ok
                                            	"optionalDependencies": {
                                          	  "electron": "^3.0.13"
                                          wait!!!
                                          have to edit 3 lines of new file to fix because of forum
                                          		exec 3< < (node serveronly)   # remove space before (
                                                 		done < &3      # remove space before &
                                                 		exec 3< &-	# remove space before &
                                          you should not have to reboot…
                                          just
                                          pm2 restart 0
                                            bdream
                                            At the moment I work on a RPi1!
                                            I’m just on the way installing Pi0 again. shall I wait until tomorror execuiting u installation script?
                                            will be off now until tomorrow morniong.
                                            cheers, bdream
                                            • 5 / 6
