    YAPi0 Installer Stretch Lite
    118 Posts 4 Posters 120.4k Views 3 Watching
      sdetweil @bdream
      @bdream there is a browser installed… its that globe on the task bar… Chrome also is a nice browser
      i wonder if this is a Raspian Buster problem…
      I have a pi 0 w coming today.
      you and another user are having the same trouble. both have armv6l devices and are using Buster.
        I see some debug for the current problem
        do
        export ELECTRON_ENABLE_LOGGING=true
        export ELECTRON_ENABLE_STACK_DUMPING=true
        ~/MagicMirror/node_modules/electron/dist/electron
        thanks
          @bdream also can u do
          ldd --version
          thanks
            bdream
            @sdetweil said in YAPi0 Installer Stretch Lite:
            But I installed the armv7l :dizzy_face:
            npm install --arch=armv7l electron@latest
            Yes, there is the globe…
            …and it success. localhost:8080 directs to MagicMirror² within all the standard modules :smiling_face:
            Anyway I do the debucg stuff:
            :backhand_index_pointing_up_light_skin_tone: um.
            I had to ctrl-c the action (on ssh console) while the browser (on the pi itself) already run MagicMirror
            pi@RasPiZeroW:~/MagicMirror $ node serveronly
            Starting MagicMirror: v2.9.0
            Loading config ...
            Loading module helpers ...
            All module helpers loaded.
            Server started ...
            Starting module: newsfeed
            Ready to go! Please point your browser to: http://localhost:8080
            Create new calendar fetcher for url: http://www.calendarlabs.com/ical-calendar/ics/76/US_Holidays.ics - Interval: 300000
            Create new news fetcher for url: http://www.nytimes.com/services/xml/rss/nyt/HomePage.xml - Interval: 300000
            ^C[SIGINT] Received. Shutting down server...
            Stopping module helper: updatenotification
            Stopping module helper: calendar
            Stopping module helper: newsfeed
            I got an storage acess error here.
            just reboot and again storage acess error.
            If I’m right, I can config the system running with standard browser.
            Can you tell me what exactly I need to do therefor?
            …and MagicMirror² run in this browser (It’s the Chromium) but not screenfilling.
            And, would it make sense deinstalling Electron then? How? :face_screaming_in_fear:
            Ohh, no. It sais localhost declined access :( why that is was running before?
            Any about this configurations?
            cheers, bdream
              sdetweil @bdream
              @bdream no reason to uninstall electron…
              to start mm using server only and then chrome
              edit ~/MagicMirror/run-start.sh
              comment out
              #electron js/electron.js $1
              then add
              # this starts the server in the background
              node serveronly &
              # waits 10 seconds -- you may need to increase this time
              sleep 10
              #you should test this from a command prompt window
              chromium-browser -kiosk -start_maximized http://localhost:8080
              then pm2 start MagicMirror will launch this file.
                bdream
                pi@RasPiZeroW:~/MagicMirror $ node serveronly &
                [1] 3121
                pi@RasPiZeroW:~/MagicMirror $ chromium-browser -kiosk -start_maximized http://localhost:8080
                [3127:3127:1020/181325.903037:ERROR:browser_main_loop.cc(596)] Failed to put Xlib into threaded mode.
                (chromium-browser:3127): Gtk-WARNING **: 18:13:26.114: cannot open display:
                pi@RasPiZeroW:~/MagicMirror $ Starting MagicMirror: v2.9.0
                Loading config ...
                Server started ...
                cheers, bdream
                  sdetweil @bdream
                  @bdream
                  add
                  export DISPLAY=:0
                  in front of
                  chromium...
                    bdream
                    export DISPLAY=:0
                    that is I should know. SORRY!
                    Get the information that Chromium is not the standardbrowser
                    cheers, bdream
                      sdetweil @bdream
                      @bdream
                      yes, set as default
                        bdream
                        ahh, I have to make it standard ;)
                        it works now. That was a hard born (is this I can say in englich? :dizzy_face: )
                        RBB
                        cheers, bdream
                          sdetweil @bdream
                          @bdream very hard!!!.. bug in electron I THINK with glibc on buster…
                          i think if you went back to raspian stretch it would have worked with electron
                          I will test that when my pi 0 gets here
                          B 1 Reply Last reply
                            bdream @sdetweil
                            @sdetweil many, many thanks to you Sam!
                            To recab,
                            I need your script, not any Updates and Upgrades of raspbian System, and the last Chat entries?
                            Can I run it on Rpi1 also?
                            And you woumd prefer Streich instead of Buster?
                            cheers, bdream
                            B S 2 Replies Last reply
                              bdream @bdream
                              @bdream excuse my typos!
                              cheers, bdream
                                sdetweil @bdream
                                @bdream said in YAPi0 Installer Stretch Lite:
                                yes, any pi version, plus odroid, jetson nano, ubuntu, macOS, Sierra-Catalina (all i have tested on)
                                And you would prefer Streich instead of Buster?
                                the bug is caused by a newer version of glibc (2.28), and buster has that, while stretch has 2.27
                                so, i think (will test myself later), with stretch, you would not need to use chrome browser
                                  bdream
                                  Great Sam!
                                  I have next week some time and will try with Pi0 and Pi1 both ways:
                                  1. Buster and additions
                                  2. Strech
                                    let you know results.
                                  For now I will close this threat as solved
                                  :smiling_face_with_open_mouth_closed_eyes: :grinning_face: :smiling_face_with_open_mouth: :smiling_face_with_open_mouth_smiling_eyes: :hugging_face: :hugging_face: :hugging_face:
                                  cheers, bdream
                                    sdetweil @bdream
                                    @bdream good or bad news, I can create the problem on stretch on my pi0 w
                                    so, more work to do figure out the problem…
                                      bdream
                                      You got your Pi0W :clapping_hands: have fun with this little thing :winking_face:
                                      …so no need to get strech installed instead of buster?
                                      cheers, bdream
                                        bdream
                                        just added -noerrdialogs getting rid of any messages from the browser.
                                        chromium-browser -noerrdialogs -kiosk -start_maximized http://localhost:8080
                                        cheers, bdream
                                          sdetweil @bdream
                                          @bdream would u be willing to look at some new options for your environment? see this topic
                                          https://forum.magicmirror.builders/topic/11433/proposed-new-processing-and-config-for-pi0-armv6-and-serveronly-mode
                                            bdream
                                            @sdetweil Hi Sam, u ask me to exchange my run-start.sh with your mentioned input?
                                            and do a reboot?
                                            cheers, bdream
                                            • 5 / 6
