    YAPi0 Installer Stretch Lite
    118 Posts 4 Posters 120.4k Views 3 Watching
      sdetweil @bdream
      @bdream very hard!!!.. bug in electron I THINK with glibc on buster…
      i think if you went back to raspian stretch it would have worked with electron
      I will test that when my pi 0 gets here
      B 1 Reply Last reply
        bdream @sdetweil
        @sdetweil many, many thanks to you Sam!
        To recab,
        I need your script, not any Updates and Upgrades of raspbian System, and the last Chat entries?
        Can I run it on Rpi1 also?
        And you woumd prefer Streich instead of Buster?
        cheers, bdream
        B S 2 Replies Last reply
          bdream @bdream
          @bdream excuse my typos!
          cheers, bdream
            sdetweil @bdream
            @bdream said in YAPi0 Installer Stretch Lite:
            yes, any pi version, plus odroid, jetson nano, ubuntu, macOS, Sierra-Catalina (all i have tested on)
            And you would prefer Streich instead of Buster?
            the bug is caused by a newer version of glibc (2.28), and buster has that, while stretch has 2.27
            so, i think (will test myself later), with stretch, you would not need to use chrome browser
              bdream
              Great Sam!
              I have next week some time and will try with Pi0 and Pi1 both ways:
              1. Buster and additions
              2. Strech
                let you know results.
              For now I will close this threat as solved
              :smiling_face_with_open_mouth_closed_eyes: :grinning_face: :smiling_face_with_open_mouth: :smiling_face_with_open_mouth_smiling_eyes: :hugging_face: :hugging_face: :hugging_face:
              cheers, bdream
                sdetweil @bdream
                @bdream good or bad news, I can create the problem on stretch on my pi0 w
                so, more work to do figure out the problem…
                  bdream
                  @sdetweil said in YAPi0 Installer Stretch Lite:
                  You got your Pi0W :clapping_hands: have fun with this little thing :winking_face:
                  …so no need to get strech installed instead of buster?
                  cheers, bdream
                    bdream
                    chromium-browser -kiosk -start_maximized http://localhost:8080
                    just added -noerrdialogs getting rid of any messages from the browser.
                    chromium-browser -noerrdialogs -kiosk -start_maximized http://localhost:8080
                    cheers, bdream
                      sdetweil @bdream
                      @bdream would u be willing to look at some new options for your environment? see this topic
                      https://forum.magicmirror.builders/topic/11433/proposed-new-processing-and-config-for-pi0-armv6-and-serveronly-mode
                        bdream
                        @sdetweil Hi Sam, u ask me to exchange my run-start.sh with your mentioned input?
                        and do a reboot?
                        cheers, bdream
                          sdetweil @bdream
                          @bdream really do you think it is a good idea?
                          if u want to try it
                          3 changes
                          1. replace file (save old one)
                          2 chmod +x run-start.sh
                          3. edit package,json
                              change
                                    "start": "sh run-start.sh",
                               to
                                    "start": "./run-start.sh",
                          for install we would move electron to the optional section, so install will finish ok
                            	"optionalDependencies": {
                          	  "electron": "^3.0.13"
                          wait!!!
                          have to edit 3 lines of new file to fix because of forum
                          		exec 3< < (node serveronly)   # remove space before (
                                 		done < &3      # remove space before &
                                 		exec 3< &-	# remove space before &
                          you should not have to reboot…
                          just
                          pm2 restart 0
                            bdream
                            At the moment I work on a RPi1!
                            I’m just on the way installing Pi0 again. shall I wait until tomorror execuiting u installation script?
                            will be off now until tomorrow morniong.
                            cheers, bdream
                              sdetweil @bdream
                              @bdream wait… for pi1 what is output of uname -m
                                bdream
                                uname -m
                                pi@RPi1:~/MagicMirror $ uname -m
                                armv6l
                                cheers, bdream
                                  sdetweil @bdream
                                  @bdream thank you… so it would work there the same as pi0.
                                    bdream
                                    that is good.
                                    I will run your script and will have tomorrow a Pi0 also running again
                                    And it’s great working on old Pi also, even it’s so slow starting.
                                    But if it’s running, it’s fine.
                                    cheers, bdream
                                      sdetweil @bdream
                                      the install script will fail because of the electron problem
                                        bdream
                                        it will run and I have to update the run-start.sh again and package.json
                                        cheers, bdream
                                          sdetweil @bdream
                                          @bdream correct…
                                            bdream
                                            so lets run and let me know if you need any to test
                                            It works as designed I would say :grinning_face:
                                            @sdetweil good job! :thumbs_up:
                                            cheers, bdream
                                            • 6 / 6
