    YAPi0 Installer Stretch Lite
    118 Posts 4 Posters 118.1k Views 3 Watching
      sdetweil @bdream
      @bdream really do you think it is a good idea?
      if u want to try it
      3 changes
      1. replace file (save old one)
      2 chmod +x run-start.sh
      3. edit package,json
          change
                "start": "sh run-start.sh",
           to
                "start": "./run-start.sh",
      for install we would move electron to the optional section, so install will finish ok
        	"optionalDependencies": {
      	  "electron": "^3.0.13"
      wait!!!
      have to edit 3 lines of new file to fix because of forum
      		exec 3< < (node serveronly)   # remove space before (
             		done < &3      # remove space before &
             		exec 3< &-	# remove space before &
      you should not have to reboot…
      just
      pm2 restart 0
        bdream
        At the moment I work on a RPi1!
        I’m just on the way installing Pi0 again. shall I wait until tomorror execuiting u installation script?
        will be off now until tomorrow morniong.
        cheers, bdream
          sdetweil @bdream
          @bdream wait… for pi1 what is output of uname -m
            bdream
            @sdetweil said in YAPi0 Installer Stretch Lite:
            uname -m
            pi@RPi1:~/MagicMirror $ uname -m
            armv6l
            cheers, bdream
              sdetweil @bdream
              @bdream thank you… so it would work there the same as pi0.
                bdream
                that is good.
                I will run your script and will have tomorrow a Pi0 also running again
                And it’s great working on old Pi also, even it’s so slow starting.
                But if it’s running, it’s fine.
                cheers, bdream
                  sdetweil @bdream
                  @bdream said in YAPi0 Installer Stretch Lite:
                  the install script will fail because of the electron problem
                    bdream
                    it will run and I have to update the run-start.sh again and package.json
                    cheers, bdream
                      sdetweil @bdream
                      @bdream correct…
                        bdream
                        so lets run and let me know if you need any to test
                        It works as designed I would say :grinning_face:
                        @sdetweil good job! :thumbs_up:
                        cheers, bdream
                        • 6 / 6
