    YAPi0 Installer Stretch Lite
    118 Posts 4 Posters 118.1k Views 3 Watching
      sdetweil @bdream
      @bdream good or bad news, I can create the problem on stretch on my pi0 w
      so, more work to do figure out the problem…
        bdream
        @sdetweil said in YAPi0 Installer Stretch Lite:
        You got your Pi0W :clapping_hands: have fun with this little thing :winking_face:
        …so no need to get strech installed instead of buster?
        cheers, bdream
          bdream
          chromium-browser -kiosk -start_maximized http://localhost:8080
          just added -noerrdialogs getting rid of any messages from the browser.
          chromium-browser -noerrdialogs -kiosk -start_maximized http://localhost:8080
          cheers, bdream
            sdetweil @bdream
            @bdream would u be willing to look at some new options for your environment? see this topic
            https://forum.magicmirror.builders/topic/11433/proposed-new-processing-and-config-for-pi0-armv6-and-serveronly-mode
              bdream
              @sdetweil Hi Sam, u ask me to exchange my run-start.sh with your mentioned input?
              and do a reboot?
              cheers, bdream
                sdetweil @bdream
                @bdream really do you think it is a good idea?
                if u want to try it
                3 changes
                1. replace file (save old one)
                2 chmod +x run-start.sh
                3. edit package,json
                    change
                          "start": "sh run-start.sh",
                     to
                          "start": "./run-start.sh",
                for install we would move electron to the optional section, so install will finish ok
                  	"optionalDependencies": {
                	  "electron": "^3.0.13"
                wait!!!
                have to edit 3 lines of new file to fix because of forum
                		exec 3< < (node serveronly)   # remove space before (
                       		done < &3      # remove space before &
                       		exec 3< &-	# remove space before &
                you should not have to reboot…
                just
                pm2 restart 0
                  bdream
                  At the moment I work on a RPi1!
                  I’m just on the way installing Pi0 again. shall I wait until tomorror execuiting u installation script?
                  will be off now until tomorrow morniong.
                  cheers, bdream
                    sdetweil @bdream
                    @bdream wait… for pi1 what is output of uname -m
                      bdream
                      uname -m
                      pi@RPi1:~/MagicMirror $ uname -m
                      armv6l
                      cheers, bdream
                        sdetweil @bdream
                        @bdream thank you… so it would work there the same as pi0.
                          bdream
                          that is good.
                          I will run your script and will have tomorrow a Pi0 also running again
                          And it’s great working on old Pi also, even it’s so slow starting.
                          But if it’s running, it’s fine.
                          cheers, bdream
                            sdetweil @bdream
                            @bdream said in YAPi0 Installer Stretch Lite:
                            the install script will fail because of the electron problem
                              bdream
                              it will run and I have to update the run-start.sh again and package.json
                              cheers, bdream
                                sdetweil @bdream
                                @bdream correct…
                                  bdream
                                  so lets run and let me know if you need any to test
                                  It works as designed I would say :grinning_face:
                                  @sdetweil good job! :thumbs_up:
                                  cheers, bdream
                                  • 6 / 6
