    YAPi0 Installer Stretch Lite
    118 Posts 4 Posters 120.4k Views 3 Watching
      bdream
      @sdetweil said in YAPi0 Installer Stretch Lite:
      chromium-browser -kiosk -start_maximized http://localhost:8080
      just added -noerrdialogs getting rid of any messages from the browser.
      chromium-browser -noerrdialogs -kiosk -start_maximized http://localhost:8080
      cheers, bdream
        sdetweil @bdream
        @bdream would u be willing to look at some new options for your environment? see this topic
        https://forum.magicmirror.builders/topic/11433/proposed-new-processing-and-config-for-pi0-armv6-and-serveronly-mode
          bdream
          @sdetweil Hi Sam, u ask me to exchange my run-start.sh with your mentioned input?
          and do a reboot?
          cheers, bdream
            sdetweil @bdream
            @bdream really do you think it is a good idea?
            if u want to try it
            3 changes
            1. replace file (save old one)
            2 chmod +x run-start.sh
            3. edit package,json
                change
                      "start": "sh run-start.sh",
                 to
                      "start": "./run-start.sh",
            for install we would move electron to the optional section, so install will finish ok
              	"optionalDependencies": {
            	  "electron": "^3.0.13"
            wait!!!
            have to edit 3 lines of new file to fix because of forum
            		exec 3< < (node serveronly)   # remove space before (
                   		done < &3      # remove space before &
                   		exec 3< &-	# remove space before &
            you should not have to reboot…
            just
            pm2 restart 0
              bdream
              At the moment I work on a RPi1!
              I’m just on the way installing Pi0 again. shall I wait until tomorror execuiting u installation script?
              will be off now until tomorrow morniong.
              cheers, bdream
              S 2 Replies Last reply
                sdetweil @bdream
                @bdream wait… for pi1 what is output of uname -m
                  bdream
                  uname -m
                  pi@RPi1:~/MagicMirror $ uname -m
                  armv6l
                  cheers, bdream
                    sdetweil @bdream
                    @bdream thank you… so it would work there the same as pi0.
                      bdream
                      that is good.
                      I will run your script and will have tomorrow a Pi0 also running again
                      And it’s great working on old Pi also, even it’s so slow starting.
                      But if it’s running, it’s fine.
                      cheers, bdream
                        sdetweil @bdream
                        @bdream said in YAPi0 Installer Stretch Lite:
                        the install script will fail because of the electron problem
                          bdream
                          it will run and I have to update the run-start.sh again and package.json
                          cheers, bdream
                            sdetweil @bdream
                            @bdream correct…
                              bdream
                              so lets run and let me know if you need any to test
                              It works as designed I would say :grinning_face:
                              @sdetweil good job! :thumbs_up:
                              cheers, bdream
                              • 6 / 6
