    YAPi0 Installer Stretch Lite
    118 Posts 4 Posters 102.6k Views 3 Watching
      bdream
      pi@RasPiZeroW:~ $ npm install --arch=arm7l electron@latest
      > electron@6.0.12 postinstall /home/pi/node_modules/electron
      > node install.js
      Downloading tmp-2171-0-electron-v6.0.12-linux-arm7l.zip
      Error: GET https://github.com/electron/electron/releases/download/v6.0.12/electron-v6.0.12-linux-arm7l.zip returned 404
      /home/pi/node_modules/electron/install.js:53
        throw err
      Error: Failed to find Electron v6.0.12 for linux-arm7l at https://github.com/electron/electron/releases/download/v6.0.12/electron-v6.0.12-linux-arm7l.zip
          at Request.<anonymous> (/home/pi/node_modules/nugget/index.js:169:61)
          at Request.emit (events.js:189:13)
          at Request.onRequestResponse (/home/pi/node_modules/request/request.js:1066:10)
          at ClientRequest.emit (events.js:189:13)
          at HTTPParser.parserOnIncomingClient [as onIncoming] (_http_client.js:556:21)
          at HTTPParser.parserOnHeadersComplete (_http_common.js:109:17)
          at TLSSocket.socketOnData (_http_client.js:442:20)
          at TLSSocket.emit (events.js:189:13)
          at addChunk (_stream_readable.js:284:12)
          at readableAddChunk (_stream_readable.js:265:11)
      npm WARN enoent ENOENT: no such file or directory, open '/home/pi/package.json'
      npm WARN pi No description
      npm WARN pi No repository field.
      npm WARN pi No README data
      npm WARN pi No license field.
      npm ERR! code ELIFECYCLE
      npm ERR! errno 1
      npm ERR! electron@6.0.12 postinstall: `node install.js`
      npm ERR! Exit status 1
      npm ERR!
      npm ERR! Failed at the electron@6.0.12 postinstall script.
      npm ERR!     /home/pi/.npm/_logs/2019-10-18T15_04_49_780Z-debug.log
      cheers, bdream
        sdetweil @bdream
        @bdream sorry,. please in the MagicMirror folder
        all things MagicMirror should be done from the MagicMirror folder
        npm install --arch=armv7l electron@latest
        notice the added lowercase V --arch=armV7L (all lowercase)
        I get a file download for
        https://github.com/electron/electron/releases/download/v6.0.12/electron-v6.0.12-linux-armv7l.zip
          @bdream did you have time to look at this?
          also, after loading do
          cd ~/MagicMirror/node_modules/electron
          ldd dist/electron  >>~/logfile.txt
          readelf -A  dist/electron >>~/logfile.txt
          also
          grep electron /var/log/syslog >>~/logfile
          and send me ~/logfile.txt
          thanks
            bdream
            @sdetweil said in YAPi0 Installer Stretch Lite:
            Sorry for delay!
            logfile is empty :angry_face:
            May you what ~/logfile.txt
            	/usr/lib/arm-linux-gnueabihf/libarmmem-${PLATFORM}.so => /usr/lib/arm-linux-gnueabihf/libarmmem-v6l.so (0xb2761000)
            	libffmpeg.so => /home/pi/MagicMirror/node_modules/electron/dist/libffmpeg.so (0xb2409000)
            	libdl.so.2 => /lib/arm-linux-gnueabihf/libdl.so.2 (0xb23e2000)
            	libpthread.so.0 => /lib/arm-linux-gnueabihf/libpthread.so.0 (0xb23b8000)
            	librt.so.1 => /lib/arm-linux-gnueabihf/librt.so.1 (0xb23a1000)
            	libgobject-2.0.so.0 => /usr/lib/arm-linux-gnueabihf/libgobject-2.0.so.0 (0xb2344000)
            	libglib-2.0.so.0 => /usr/lib/arm-linux-gnueabihf/libglib-2.0.so.0 (0xb2234000)
            	libgio-2.0.so.0 => /usr/lib/arm-linux-gnueabihf/libgio-2.0.so.0 (0xb20b9000)
            	libnss3.so => /usr/lib/arm-linux-gnueabihf/libnss3.so (0xb1f9d000)
            	libnssutil3.so => /usr/lib/arm-linux-gnueabihf/libnssutil3.so (0xb1f6a000)
            	libsmime3.so => /usr/lib/arm-linux-gnueabihf/libsmime3.so (0xb1f39000)
            	libnspr4.so => /usr/lib/arm-linux-gnueabihf/libnspr4.so (0xb1ef9000)
            	libgdk_pixbuf-2.0.so.0 => /usr/lib/arm-linux-gnueabihf/libgdk_pixbuf-2.0.so.0 (0xb1ec7000)
            	libgtk-3.so.0 => /usr/lib/arm-linux-gnueabihf/libgtk-3.so.0 (0xb18b1000)
            	libgdk-3.so.0 => /usr/lib/arm-linux-gnueabihf/libgdk-3.so.0 (0xb17d9000)
            	libpangocairo-1.0.so.0 => /usr/lib/arm-linux-gnueabihf/libpangocairo-1.0.so.0 (0xb17be000)
            	libpango-1.0.so.0 => /usr/lib/arm-linux-gnueabihf/libpango-1.0.so.0 (0xb1771000)
            	libatk-1.0.so.0 => /usr/lib/arm-linux-gnueabihf/libatk-1.0.so.0 (0xb1743000)
            	libcairo.so.2 => /usr/lib/arm-linux-gnueabihf/libcairo.so.2 (0xb164a000)
            	libdbus-1.so.3 => /lib/arm-linux-gnueabihf/libdbus-1.so.3 (0xb15f9000)
            	libXext.so.6 => /usr/lib/arm-linux-gnueabihf/libXext.so.6 (0xb15da000)
            	libX11.so.6 => /usr/lib/arm-linux-gnueabihf/libX11.so.6 (0xb14b8000)
            	libXcomposite.so.1 => /usr/lib/arm-linux-gnueabihf/libXcomposite.so.1 (0xb14a5000)
            	libXrender.so.1 => /usr/lib/arm-linux-gnueabihf/libXrender.so.1 (0xb148c000)
            	libexpat.so.1 => /lib/arm-linux-gnueabihf/libexpat.so.1 (0xb144b000)
            	libuuid.so.1 => /lib/arm-linux-gnueabihf/libuuid.so.1 (0xb1434000)
            	libX11-xcb.so.1 => /usr/lib/arm-linux-gnueabihf/libX11-xcb.so.1 (0xb1422000)
            	libxcb.so.1 => /usr/lib/arm-linux-gnueabihf/libxcb.so.1 (0xb13f3000)
            	libXcursor.so.1 => /usr/lib/arm-linux-gnueabihf/libXcursor.so.1 (0xb13da000)
            	libXdamage.so.1 => /usr/lib/arm-linux-gnueabihf/libXdamage.so.1 (0xb13c7000)
            	libXfixes.so.3 => /usr/lib/arm-linux-gnueabihf/libXfixes.so.3 (0xb13b2000)
            	libXi.so.6 => /usr/lib/arm-linux-gnueabihf/libXi.so.6 (0xb1394000)
            	libXtst.so.6 => /usr/lib/arm-linux-gnueabihf/libXtst.so.6 (0xb137f000)
            	libXrandr.so.2 => /usr/lib/arm-linux-gnueabihf/libXrandr.so.2 (0xb1366000)
            	libXss.so.1 => /usr/lib/arm-linux-gnueabihf/libXss.so.1 (0xb1353000)
            	libasound.so.2 => /usr/lib/arm-linux-gnueabihf/libasound.so.2 (0xb1272000)
            	libatk-bridge-2.0.so.0 => /usr/lib/arm-linux-gnueabihf/libatk-bridge-2.0.so.0 (0xb1239000)
            	libatspi.so.0 => /usr/lib/arm-linux-gnueabihf/libatspi.so.0 (0xb1202000)
            	libcups.so.2 => /usr/lib/arm-linux-gnueabihf/libcups.so.2 (0xb1180000)
            	libm.so.6 => /lib/arm-linux-gnueabihf/libm.so.6 (0xb10fe000)
            	libgcc_s.so.1 => /lib/arm-linux-gnueabihf/libgcc_s.so.1 (0xb10d1000)
            	libc.so.6 => /lib/arm-linux-gnueabihf/libc.so.6 (0xb0f83000)
            	/lib/ld-linux-armhf.so.3 (0xb6f3e000)
            	libffi.so.6 => /usr/lib/arm-linux-gnueabihf/libffi.so.6 (0xb0f6b000)
            	libpcre.so.3 => /lib/arm-linux-gnueabihf/libpcre.so.3 (0xb0ef4000)
            	libgmodule-2.0.so.0 => /usr/lib/arm-linux-gnueabihf/libgmodule-2.0.so.0 (0xb0ee0000)
            	libz.so.1 => /lib/arm-linux-gnueabihf/libz.so.1 (0xb0eb5000)
            	libmount.so.1 => /lib/arm-linux-gnueabihf/libmount.so.1 (0xb0e54000)
            	libselinux.so.1 => /lib/arm-linux-gnueabihf/libselinux.so.1 (0xb0e22000)
            	libresolv.so.2 => /lib/arm-linux-gnueabihf/libresolv.so.2 (0xb0dfe000)
            	libplc4.so => /usr/lib/arm-linux-gnueabihf/libplc4.so (0xb0dea000)
            	libplds4.so => /usr/lib/arm-linux-gnueabihf/libplds4.so (0xb0dd7000)
            	libcairo-gobject.so.2 => /usr/lib/arm-linux-gnueabihf/libcairo-gobject.so.2 (0xb0dc0000)
            	libxkbcommon.so.0 => /usr/lib/arm-linux-gnueabihf/libxkbcommon.so.0 (0xb0d77000)
            	libwayland-cursor.so.0 => /usr/lib/arm-linux-gnueabihf/libwayland-cursor.so.0 (0xb0d60000)
            	libwayland-egl.so.1 => /usr/lib/arm-linux-gnueabihf/libwayland-egl.so.1 (0xb0d4e000)
            	libwayland-client.so.0 => /usr/lib/arm-linux-gnueabihf/libwayland-client.so.0 (0xb0d34000)
            	libepoxy.so.0 => /usr/lib/arm-linux-gnueabihf/libepoxy.so.0 (0xb0c3e000)
            	libharfbuzz.so.0 => /usr/lib/arm-linux-gnueabihf/libharfbuzz.so.0 (0xb0b40000)
            	libpangoft2-1.0.so.0 => /usr/lib/arm-linux-gnueabihf/libpangoft2-1.0.so.0 (0xb0b1e000)
            	libfontconfig.so.1 => /usr/lib/arm-linux-gnueabihf/libfontconfig.so.1 (0xb0ad6000)
            	libfreetype.so.6 => /usr/lib/arm-linux-gnueabihf/libfreetype.so.6 (0xb0a33000)
            	libXinerama.so.1 => /usr/lib/arm-linux-gnueabihf/libXinerama.so.1 (0xb0a20000)
            	libthai.so.0 => /usr/lib/arm-linux-gnueabihf/libthai.so.0 (0xb0a08000)
            	libfribidi.so.0 => /usr/lib/arm-linux-gnueabihf/libfribidi.so.0 (0xb09de000)
            	libpixman-1.so.0 => /usr/lib/arm-linux-gnueabihf/libpixman-1.so.0 (0xb0903000)
            	libpng16.so.16 => /usr/lib/arm-linux-gnueabihf/libpng16.so.16 (0xb08c7000)
            	libxcb-shm.so.0 => /usr/lib/arm-linux-gnueabihf/libxcb-shm.so.0 (0xb08b4000)
            	libxcb-render.so.0 => /usr/lib/arm-linux-gnueabihf/libxcb-render.so.0 (0xb0899000)
            	libsystemd.so.0 => /lib/arm-linux-gnueabihf/libsystemd.so.0 (0xb07fc000)
            	libXau.so.6 => /usr/lib/arm-linux-gnueabihf/libXau.so.6 (0xb07e9000)
            	libXdmcp.so.6 => /usr/lib/arm-linux-gnueabihf/libXdmcp.so.6 (0xb07d4000)
            	libgssapi_krb5.so.2 => /usr/lib/arm-linux-gnueabihf/libgssapi_krb5.so.2 (0xb078a000)
            	libgnutls.so.30 => /usr/lib/arm-linux-gnueabihf/libgnutls.so.30 (0xb05e6000)
            	libavahi-common.so.3 => /usr/lib/arm-linux-gnueabihf/libavahi-common.so.3 (0xb05cb000)
            	libavahi-client.so.3 => /usr/lib/arm-linux-gnueabihf/libavahi-client.so.3 (0xb05ac000)
            	libblkid.so.1 => /lib/arm-linux-gnueabihf/libblkid.so.1 (0xb0554000)
            	libgraphite2.so.3 => /usr/lib/arm-linux-gnueabihf/libgraphite2.so.3 (0xb0523000)
            	libdatrie.so.1 => /usr/lib/arm-linux-gnueabihf/libdatrie.so.1 (0xb050d000)
            	liblzma.so.5 => /lib/arm-linux-gnueabihf/liblzma.so.5 (0xb04dc000)
            	liblz4.so.1 => /usr/lib/arm-linux-gnueabihf/liblz4.so.1 (0xb04b0000)
            	libgcrypt.so.20 => /lib/arm-linux-gnueabihf/libgcrypt.so.20 (0xb03d6000)
            	libbsd.so.0 => /usr/lib/arm-linux-gnueabihf/libbsd.so.0 (0xb03ac000)
            	libkrb5.so.3 => /usr/lib/arm-linux-gnueabihf/libkrb5.so.3 (0xb02f1000)
            	libk5crypto.so.3 => /usr/lib/arm-linux-gnueabihf/libk5crypto.so.3 (0xb02b1000)
            	libcom_err.so.2 => /lib/arm-linux-gnueabihf/libcom_err.so.2 (0xb029e000)
            	libkrb5support.so.0 => /usr/lib/arm-linux-gnueabihf/libkrb5support.so.0 (0xb0284000)
            	libkeyutils.so.1 => /lib/arm-linux-gnueabihf/libkeyutils.so.1 (0xb0270000)
            	libp11-kit.so.0 => /usr/lib/arm-linux-gnueabihf/libp11-kit.so.0 (0xb016b000)
            	libidn2.so.0 => /usr/lib/arm-linux-gnueabihf/libidn2.so.0 (0xb013f000)
            	libunistring.so.2 => /usr/lib/arm-linux-gnueabihf/libunistring.so.2 (0xaffc3000)
            	libtasn1.so.6 => /usr/lib/arm-linux-gnueabihf/libtasn1.so.6 (0xaffa3000)
            	libnettle.so.6 => /usr/lib/arm-linux-gnueabihf/libnettle.so.6 (0xaff5d000)
            	libhogweed.so.4 => /usr/lib/arm-linux-gnueabihf/libhogweed.so.4 (0xaff1e000)
            	libgmp.so.10 => /usr/lib/arm-linux-gnueabihf/libgmp.so.10 (0xafea5000)
            	libgpg-error.so.0 => /lib/arm-linux-gnueabihf/libgpg-error.so.0 (0xafe7b000)
            Attribute Section: aeabi
            File Attributes
              Tag_CPU_name: "7-A"
              Tag_CPU_arch: v7
              Tag_CPU_arch_profile: Application
              Tag_ARM_ISA_use: Yes
              Tag_THUMB_ISA_use: Thumb-2
              Tag_FP_arch: VFPv3-D16
              Tag_ABI_PCS_wchar_t: 4
              Tag_ABI_FP_rounding: Needed
              Tag_ABI_FP_denormal: Needed
              Tag_ABI_FP_exceptions: Needed
              Tag_ABI_FP_number_model: IEEE 754
              Tag_ABI_align_needed: 8-byte
              Tag_ABI_align_preserved: 8-byte, except leaf SP
              Tag_ABI_enum_size: int
              Tag_ABI_VFP_args: VFP registers
              Tag_CPU_unaligned_access: v6
            cheers, bdream
              sdetweil @bdream
              @bdream thx.
              And if you do
              ~/MagicMirror/node_modules/electron/dist/electron
              Does it open browser?
                bdream
                pi@RasPiZeroW:~ $ ~/MagicMirror/node_modules/electron/dist/electron
                Speicherzugriffsfehler
                pi@RasPiZeroW:~ $ cd ~/MagicMirror/node_modules/electron/dist/electron
                -bash: cd: /home/pi/MagicMirror/node_modules/electron/dist/electron: Ist kein Verzeichnis
                pi@RasPiZeroW:~/MagicMirror/node_modules/electron/dist $ ls -la
                insgesamt 107480
                drwxr-xr-x 4 pi pi     4096 Okt 19 10:56 .
                drwxr-xr-x 4 pi pi     4096 Okt 19 10:56 ..
                -rw-r--r-- 1 pi pi   145945 Okt 19 10:55 chrome_100_percent.pak
                -rw-r--r-- 1 pi pi   209147 Okt 19 10:55 chrome_200_percent.pak
                -rwxr-xr-x 1 pi pi  4202140 Okt 19 10:56 chrome-sandbox
                -rwxr-xr-x 1 pi pi 74648480 Okt 19 10:55 electron
                -rw-r--r-- 1 pi pi 10410272 Okt 19 10:55 icudtl.dat
                -rwxr-xr-x 1 pi pi   157372 Okt 19 10:55 libEGL.so
                -rwxr-xr-x 1 pi pi  1949660 Okt 19 10:55 libffmpeg.so
                -rwxr-xr-x 1 pi pi  4883208 Okt 19 10:55 libGLESv2.so
                -rw-r--r-- 1 pi pi     1060 Okt 19 10:54 LICENSE
                -rw-r--r-- 1 pi pi  3961766 Okt 19 10:54 LICENSES.chromium.html
                drwxr-xr-x 2 pi pi     4096 Okt 19 10:56 locales
                -rw-r--r-- 1 pi pi    83237 Okt 19 10:55 natives_blob.bin
                drwxr-xr-x 2 pi pi     4096 Okt 19 10:55 resources
                -rw-r--r-- 1 pi pi  8471329 Okt 19 10:54 resources.pak
                -rw-r--r-- 1 pi pi   275792 Okt 19 10:55 snapshot_blob.bin
                -rw-r--r-- 1 pi pi   608820 Okt 19 10:56 v8_context_snapshot.bin
                -rw-r--r-- 1 pi pi        6 Okt 19 10:55 version
                do I need to do eny else as ?
                cheers, bdream
                  sdetweil @bdream
                  @bdream said in YAPi0 Installer Stretch Lite:
                  no… I am researching the cause…
                  thanks
                  does
                  cd ~/MagicMirror
                  node serveronly
                  then use another browser to open the url shown
                  work?
                    bdream
                    that means, I need to install another browser?
                    Have you advise please?
                    cheers, bdream
                      sdetweil @bdream
                      @bdream there is a browser installed… its that globe on the task bar… Chrome also is a nice browser
                      i wonder if this is a Raspian Buster problem…
                      I have a pi 0 w coming today.
                      you and another user are having the same trouble. both have armv6l devices and are using Buster.
                        sdetweil
                        I see some debug for the current problem
                        do
                        cd ~/MagicMirror
                        export ELECTRON_ENABLE_LOGGING=true
                        export ELECTRON_ENABLE_STACK_DUMPING=true
                        thanks
                        • 7
                        • 8
                        • 9
                        • 10
                        • 11
                        • 12
                        • 9 / 12
