    YAPi0 Installer Stretch Lite
    118 Posts 4 Posters 103.7k Views 3 Watching
      @bdream also can u do
      ldd --version
      thanks
        bdream
        @sdetweil said in YAPi0 Installer Stretch Lite:
        you and another user are having the same trouble. both have armv6l devices and are using Buster.
        But I installed the armv7l :dizzy_face:
        npm install --arch=armv7l electron@latest
        there is a browser installed… its that globe on the task bar… Chrome also is a nice browser
        Yes, there is the globe…
        …and it success. localhost:8080 directs to MagicMirror² within all the standard modules :smiling_face:
        Anyway I do the debucg stuff:
        :backhand_index_pointing_up_light_skin_tone: um.
        I had to ctrl-c the action (on ssh console) while the browser (on the pi itself) already run MagicMirror
        pi@RasPiZeroW:~/MagicMirror $ node serveronly
        Starting MagicMirror: v2.9.0
        Loading config ...
        Loading module helpers ...
        All module helpers loaded.
        Server started ...
        Starting module: newsfeed
        Ready to go! Please point your browser to: http://localhost:8080
        Create new calendar fetcher for url: http://www.calendarlabs.com/ical-calendar/ics/76/US_Holidays.ics - Interval: 300000
        Create new news fetcher for url: http://www.nytimes.com/services/xml/rss/nyt/HomePage.xml - Interval: 300000
        ^C[SIGINT] Received. Shutting down server...
        Stopping module helper: updatenotification
        Stopping module helper: calendar
        Stopping module helper: newsfeed
        cd ~/MagicMirror
        export ELECTRON_ENABLE_LOGGING=true
        export ELECTRON_ENABLE_STACK_DUMPING=true
        ~/MagicMirror/node_modules/electron/dist/electron
        I got an storage acess error here.
        just reboot and again storage acess error.
        If I’m right, I can config the system running with standard browser.
        Can you tell me what exactly I need to do therefor?
        …and MagicMirror² run in this browser (It’s the Chromium) but not screenfilling.
        And, would it make sense deinstalling Electron then? How? :face_screaming_in_fear:
        Ohh, no. It sais localhost declined access :( why that is was running before?
        Any about this configurations?
        cheers, bdream
          sdetweil @bdream
          @bdream no reason to uninstall electron…
          to start mm using server only and then chrome
          edit ~/MagicMirror/run-start.sh
          comment out
          #electron js/electron.js $1
          then add
          # this starts the server in the background
          node serveronly &
          # waits 10 seconds -- you may need to increase this time
          sleep 10
          #you should test this from a command prompt window
          chromium-browser -kiosk -start_maximized http://localhost:8080
          then pm2 start MagicMirror will launch this file.
            bdream
            pi@RasPiZeroW:~/MagicMirror $ node serveronly &
            [1] 3121
            pi@RasPiZeroW:~/MagicMirror $ chromium-browser -kiosk -start_maximized http://localhost:8080
            [3127:3127:1020/181325.903037:ERROR:browser_main_loop.cc(596)] Failed to put Xlib into threaded mode.
            (chromium-browser:3127): Gtk-WARNING **: 18:13:26.114: cannot open display:
            pi@RasPiZeroW:~/MagicMirror $ Starting MagicMirror: v2.9.0
            Loading config ...
            Server started ...
            cheers, bdream
              sdetweil @bdream
              @bdream
              add
              export DISPLAY=:0
              in front of
              chromium...
                bdream
                export DISPLAY=:0
                that is I should know. SORRY!
                Get the information that Chromium is not the standardbrowser
                cheers, bdream
                  sdetweil @bdream
                  @bdream
                  yes, set as default
                    bdream
                    ahh, I have to make it standard ;)
                    it works now. That was a hard born (is this I can say in englich? :dizzy_face: )
                    RBB
                    cheers, bdream
                      sdetweil @bdream
                      @bdream very hard!!!.. bug in electron I THINK with glibc on buster…
                      i think if you went back to raspian stretch it would have worked with electron
                      I will test that when my pi 0 gets here
                        bdream @sdetweil
                        @sdetweil many, many thanks to you Sam!
                        To recab,
                        I need your script, not any Updates and Upgrades of raspbian System, and the last Chat entries?
                        Can I run it on Rpi1 also?
                        And you woumd prefer Streich instead of Buster?
                        cheers, bdream
                        B S 2 Replies Last reply Reply Quote 0
                        • 8
                        • 9
                        • 10
                        • 11
                        • 12
                        • 10 / 12
