    YAPi0 Installer Stretch Lite
    118 Posts 4 Posters 114.5k Views 3 Watching
      sdetweil @bdream
      @bdream all good!
      Make sure to copy the sample config.js to config.js in the config folder.
      Then npm start
        bdream
        Seems not to be an easy task.
        And I totally lost what I have to do in case I want to setup it again on Pi0 :dizzy_face:
        Cheers, bdream
        cheers, bdream
          sdetweil @bdream
          @bdream hm… this hardware is not enough like pi0. My script works there.
          I will have to look at the YAPI0 doc and see what is different
            sdetweil @bdream
            @bdream said in YAPi0 Installer Stretch Lite:
            I’m not alowed to attach because the file type is .log
            change the filetype to .txt
              sdetweil @bdream
              @bdream ok, partial install is a mess… lets try this way
              cd ~/MagicMirror
              rm -rf node_modules
              npm install --arch=armv71
              then
              npm start
                bdream
                npm install not yet. right?
                [0_1569360293647_2019-09-24T17_21_45_114Z-debug.txt](Uploading 100%)
                Not a working hint wit log -> txt. Only pics are allowed :(
                maybe as jpg even it is an log!
                [0_1569360379845_2019-09-24T17_21_45_114Z-debug.jpg](Uploading 100%)
                this is also not possible. what can I do?
                cheers, bdream
                cheers, bdream
                  sdetweil @bdream
                  @bdream hm… failed to find Electron v1.8.0… this should not be the case…
                  what is the version in the ~/MagicMirror/package.json for electron?
                   "electron": "^3.0.13",
                    bdream
                    you mean this part here?
                      "dependencies": {
                        "colors": "^1.1.2",
                        "electron-chromedriver": "^1.8.0",
                        "express": "^4.16.2",
                        "express-ipfilter": "^1.0.1",
                        "feedme": "latest",
                        "helmet": "^3.9.0",
                        "iconv-lite": "latest",
                        "moment": "latest",
                        "request": "^2.88.0",
                        "rrule": "^2.6.2",
                        "rrule-alt": "^2.2.8",
                        "simple-git": "^1.85.0",
                        "socket.io": "^2.1.1",
                        "valid-url": "latest"
                    cheers, bdream
                    cheers, bdream
                      sdetweil @bdream
                      @bdream weird…
                      don’t know why it works sometimes
                      in the npm info for chromedriver is lists different code mirrors…
                      # Electron mirror for China
                      export ELECTRON_MIRROR="https://npm.taobao.org/mirrors/electron/"
                      then
                      cd ~/MagicMirror
                      npm install electron-chromedriver@v1.8.0 --arch=armv71
                        bdream
                        here the result :pouting_face:
                        pi@RasPiZeroWH:~/MagicMirror $ export ELECTRON_MIRROR=“https://npm.taobao.org/mirrors/electron/”
                        pi@RasPiZeroWH:~/MagicMirror $ npm install electron-chromedriver@v1.8.0 --arch=armv71
                        > electron-chromedriver@1.8.0 install /home/pi/MagicMirror/node_modules/electron-chromedriver
                        > node ./download-chromedriver.js
                        events.js:174
                              throw er; // Unhandled 'error' event
                        Error: Invalid URI "“https://npm.taobao.org/mirrors/electron/”1.8.0/chromedriver-v1.8.0-linux-armv71.zip"
                            at Request.init (/home/pi/MagicMirror/node_modules/request/request.js:273:31)
                            at new Request (/home/pi/MagicMirror/node_modules/request/request.js:127:8)
                            at request (/home/pi/MagicMirror/node_modules/request/index.js:53:10)
                            at /home/pi/MagicMirror/node_modules/request/index.js:100:12
                            at download (/home/pi/MagicMirror/node_modules/nugget/index.js:164:18)
                            at /home/pi/MagicMirror/node_modules/nugget/index.js:133:18
                            at FSReqWrap.oncomplete (fs.js:154:21)
                        Emitted 'error' event at:
                            at Request.init (/home/pi/MagicMirror/node_modules/request/request.js:273:17)
                            [... lines matching original stack trace ...]
                        npm WARN grunt-stylelint@0.11.1 requires a peer of stylelint@^10.0.0 but none is installed. You must install peer dependencies yourself.
                        npm ERR! code ELIFECYCLE
                        npm ERR! errno 1
                        npm ERR! electron-chromedriver@1.8.0 install: `node ./download-chromedriver.js`
                        npm ERR! Exit status 1
                        npm ERR!
                        npm ERR! Failed at the electron-chromedriver@1.8.0 install script.
                        npm ERR!     /home/pi/.npm/_logs/2019-09-25T13_49_38_086Z-debug.log
                        Will it make sense starting again with a clean raspbian?
                        Maybe there is anything weird on it…
                        Cheers, bdream
                        cheers, bdream
                          sdetweil @bdream
                          no, this is the weird double quotes(the forum turns them into word document quotes), bad cut and paste on my part
                          either re-copy the commandline (I fixed my post) , or delete the double quote " and redo, start and end of the mirror setting
                            bdream
                            @sdetweil redo, start and end of the mirror setting
                            does it mean again (but single quotes in export ELECTRON…)?
                            export ELECTRON_MIRROR='https://npm.taobao.org/mirrors/electron/'
                            Sorry for this many beginner-questions :disappointed_face:
                            cheers, bdream
                            cheers, bdream
                              sdetweil @bdream
                              @bdream no… need double quotes…
                              use this. the markup protects the quotes…
                                bdream
                                No change to before.
                                I tried already with double-quotes.
                                Only thing I changed now is executing
                                cd ~
                                and afterwards
                                cheers, bdream
                                  sdetweil @bdream
                                  @bdream weird…
                                  works here on three different systems…
                                  can u show me the output of
                                  uname -a
                                  and
                                  lsb_release -a
                                    bdream
                                    uname -a
                                    Linux RasPiZeroWH 4.19.66+ #1253 Thu Aug 15 11:37:30 BST 2019 armv6l GNU/Linux
                                    lsb_release -a
                                    No LSB modules are available.
                                    Distributor ID: Raspbian
                                    Description:    Raspbian GNU/Linux 10 (buster)
                                    Release:        10
                                    Codename:       buster
                                    cheers, bdream
                                      sdetweil
                                      cd ~
                                      u need to be in the MagicMirror folder
                                      cd ~/MagicMirror
                                      I get the same error as you in the home folder
                                      every command MagicMirror related MUST be done from the MagicMirror folder (except the install script from the product or forum links)
                                        @sdetweil looks like once its messed up, its messed up, and u have to start over with
                                        (from the magicmirror folder)
                                        at least I had to…
                                          bdream
                                          Hi Sam, that was the first attempt I did anyway, starting in MagicMirror folder.
                                          Only last I missed it :frowning_face:
                                          I tried it again in this folder, but result is bad.
                                          I guess it makes no sense working on this.
                                          You said you have running multiple Pi0… let me try another one.
                                          Not starting with wrong way let me ask if my understanding is right.
                                          1. It dosn’t matter if I run SSH or direkt with keyboard attached. Also changing for the different steps?
                                          2. preperation as shown are done
                                          sudo apt-get update
                                          sudo apt-get upgrade
                                          sudo apt-get dist-upgrade
                                          sudo apt-get autoremove && sudo reboot
                                          1. I will run your updated script
                                          bash -c "$(curl -sL https://www.dropbox.com/s/rlh710ng0zwv3vp/raspberry.sh?dl=0)"
                                          1. start MM
                                          Is this right?
                                          cheers, bdream
                                            sdetweil @bdream
                                            @bdream my script does all the system updates too…
                                            and it will start MM at the end if u use pm2.
                                            I do all my work on my mirrors over ssh.
                                            • 6
                                            • 2 / 6
