    YAPi0 Installer Stretch Lite
    118 Posts 4 Posters 112.6k Views 3 Watching
      sdetweil @bdream
      @bdream my script should do EVERYTHING…
      the chromedriver install had a problem…
      can u do this
      cd /home/pi/MagicMirror/node_modules/electron-chromedriver
      node ./download-chromedriver.js
      and show me what the results are…
      thanks
        bdream
        Hi Sam,
        as I get Error replaying with code inside: 0_1569315660505_Error.JPG
        cheers, bdream
        cheers, bdream
          sdetweil @bdream
          @bdream
          hmm…
          try this from the MagicMirror folder
          npm install  --arch=armv7l electron-chromedriver@1.8.0
            bdream
            Here it is…
            pi@RasPiZeroWH:~/MagicMirror $ npm install  --arch=armv7l electron-chromedriver@1.8.0
            > electron-chromedriver@1.8.0 install /home/pi/MagicMirror/node_modules/electron-chromedriver
            successfully dowloaded and extracted!
            npm WARN grunt-stylelint@0.11.1 requires a peer of stylelint@^10.0.0 but none is installed. You must install peer dependencies yourself.
            + electron-chromedriver@1.8.0
            updated 1 package and audited 3773 packages in 640.327s
            found 16 high severity vulnerabilities
              run `npm audit fix` to fix them, or `npm audit` for details
            cheers, bdream
            cheers, bdream
              sdetweil @bdream
              @bdream weird. Works normal, fails in script.
              So, do this.
              npm install --arch=armv71
              Please advise your results
                bdream
                see here:
                pi@RasPiZeroWH:~/MagicMirror $ npm install --arch=armv71
                > magicmirror@2.8.0 install /home/pi/MagicMirror
                > cd vendor && npm install
                npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@1.2.4 (node_modules/fsevents):
                npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@1.2.4: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
                audited 220 packages in 69.246s
                found 5 vulnerabilities (4 low, 1 high)
                > magicmirror@2.8.0 postinstall /home/pi/MagicMirror
                > sh installers/postinstall/postinstall.sh && npm run install-fonts
                MagicMirror installation successful!
                > magicmirror@2.8.0 install-fonts /home/pi/MagicMirror
                > cd fonts && npm install
                audited 1 package in 7.131s
                found 0 vulnerabilities
                audited 3773 packages in 413.334s
                cheers, bdream
                cheers, bdream
                  sdetweil @bdream
                  @bdream all good!
                  Make sure to copy the sample config.js to config.js in the config folder.
                  Then npm start
                    bdream
                    Seems not to be an easy task.
                    And I totally lost what I have to do in case I want to setup it again on Pi0 :dizzy_face:
                    Cheers, bdream
                    cheers, bdream
                      sdetweil @bdream
                      @bdream hm… this hardware is not enough like pi0. My script works there.
                      I will have to look at the YAPI0 doc and see what is different
                        sdetweil @bdream
                        @bdream said in YAPi0 Installer Stretch Lite:
                        I’m not alowed to attach because the file type is .log
                        change the filetype to .txt
                          sdetweil @bdream
                          @bdream ok, partial install is a mess… lets try this way
                          rm -rf node_modules
                          then
                          npm start
                            bdream
                            npm install not yet. right?
                            [0_1569360293647_2019-09-24T17_21_45_114Z-debug.txt](Uploading 100%)
                            Not a working hint wit log -> txt. Only pics are allowed :(
                            maybe as jpg even it is an log!
                            [0_1569360379845_2019-09-24T17_21_45_114Z-debug.jpg](Uploading 100%)
                            this is also not possible. what can I do?
                            cheers, bdream
                            cheers, bdream
                              sdetweil @bdream
                              @bdream hm… failed to find Electron v1.8.0… this should not be the case…
                              what is the version in the ~/MagicMirror/package.json for electron?
                               "electron": "^3.0.13",
                                bdream
                                you mean this part here?
                                  "dependencies": {
                                    "colors": "^1.1.2",
                                    "electron-chromedriver": "^1.8.0",
                                    "express": "^4.16.2",
                                    "express-ipfilter": "^1.0.1",
                                    "feedme": "latest",
                                    "helmet": "^3.9.0",
                                    "iconv-lite": "latest",
                                    "moment": "latest",
                                    "request": "^2.88.0",
                                    "rrule": "^2.6.2",
                                    "rrule-alt": "^2.2.8",
                                    "simple-git": "^1.85.0",
                                    "socket.io": "^2.1.1",
                                    "valid-url": "latest"
                                cheers, bdream
                                cheers, bdream
                                  sdetweil @bdream
                                  @bdream weird…
                                  don’t know why it works sometimes
                                  in the npm info for chromedriver is lists different code mirrors…
                                  # Electron mirror for China
                                  export ELECTRON_MIRROR="https://npm.taobao.org/mirrors/electron/"
                                  then
                                  npm install electron-chromedriver@v1.8.0 --arch=armv71
                                    bdream
                                    here the result :pouting_face:
                                    pi@RasPiZeroWH:~/MagicMirror $ export ELECTRON_MIRROR=“https://npm.taobao.org/mirrors/electron/”
                                    pi@RasPiZeroWH:~/MagicMirror $ npm install electron-chromedriver@v1.8.0 --arch=armv71
                                    events.js:174
                                          throw er; // Unhandled 'error' event
                                    Error: Invalid URI "“https://npm.taobao.org/mirrors/electron/”1.8.0/chromedriver-v1.8.0-linux-armv71.zip"
                                        at Request.init (/home/pi/MagicMirror/node_modules/request/request.js:273:31)
                                        at new Request (/home/pi/MagicMirror/node_modules/request/request.js:127:8)
                                        at request (/home/pi/MagicMirror/node_modules/request/index.js:53:10)
                                        at /home/pi/MagicMirror/node_modules/request/index.js:100:12
                                        at download (/home/pi/MagicMirror/node_modules/nugget/index.js:164:18)
                                        at /home/pi/MagicMirror/node_modules/nugget/index.js:133:18
                                        at FSReqWrap.oncomplete (fs.js:154:21)
                                    Emitted 'error' event at:
                                        at Request.init (/home/pi/MagicMirror/node_modules/request/request.js:273:17)
                                        [... lines matching original stack trace ...]
                                    npm ERR! code ELIFECYCLE
                                    npm ERR! errno 1
                                    npm ERR! electron-chromedriver@1.8.0 install: `node ./download-chromedriver.js`
                                    npm ERR! Exit status 1
                                    npm ERR!
                                    npm ERR! Failed at the electron-chromedriver@1.8.0 install script.
                                    npm ERR!     /home/pi/.npm/_logs/2019-09-25T13_49_38_086Z-debug.log
                                    Will it make sense starting again with a clean raspbian?
                                    Maybe there is anything weird on it…
                                    Cheers, bdream
                                    cheers, bdream
                                      sdetweil @bdream
                                      no, this is the weird double quotes(the forum turns them into word document quotes), bad cut and paste on my part
                                      either re-copy the commandline (I fixed my post) , or delete the double quote " and redo, start and end of the mirror setting
                                        bdream
                                        @sdetweil redo, start and end of the mirror setting
                                        does it mean again (but single quotes in export ELECTRON…)?
                                        export ELECTRON_MIRROR='https://npm.taobao.org/mirrors/electron/'
                                        Sorry for this many beginner-questions :disappointed_face:
                                        cheers, bdream
                                        cheers, bdream
                                          sdetweil @bdream
                                          @bdream no… need double quotes…
                                          use this. the markup protects the quotes…
                                            bdream
                                            No change to before.
                                            I tried already with double-quotes.
                                            Only thing I changed now is executing
                                            cd ~
                                            and afterwards
                                            cheers, bdream
                                            • 2 / 6
