    YAPi0 Installer Stretch Lite
    118 Posts 4 Posters 118.1k Views 3 Watching
      sdetweil @bdream
      @bdream said in YAPi0 Installer Stretch Lite:
      start your script fails . And it failed
      please post the contents of ~/install.log
        bdream
        Ohh sdetweil, my bad. I overwrote the SD-card already with the new image. I have to learn how to work with forum and being sensitive for upcoming questions/requests.
        For now I started your script again an it seems it’s running :sleeping_face:
        I wonder as I have on screen a warning
        npm WARN npm npm does not support Node.js v10.15.2
        npm WARN npm You should probably upgrade to a newer version of node as we
        npm WARN npm can't make promises that npm will work with this version.
        npm WARN npm Supported releases of Node.js are the latest releases of 4, 6, 7, 8, 9.
        npm WARN npm You can find the latest version at https://nodejs.org/
        /usr/local/bin/npm -> /usr/local/lib/node_modules/npm/bin/npm-cli.js
        /usr/local/bin/npx -> /usr/local/lib/node_modules/npm/bin/npx-cli.js
        + npm@6.11.3
        added 430 packages from 833 contributors in 433.321s
        npm installation Done!
        Cloning MagicMirror ...
        Klone nach 'MagicMirror' ...
        remote: Enumerating objects: 315, done.
        remote: Counting objects: 100% (315/315), done.
        remote: Compressing objects: 100% (282/282), done.
        remote: Total 315 (delta 39), reused 193 (delta 21), pack-reused 0
        Empangene Obekte: 100% (315/315), 655.08 KiB | 867.00 KiB/s, Fertig.
        Löse Unterschiede auf: 100% (39/39), Fertig.
        Cloning MagicMirror Done!
        Installing dependencies ...
        npm WARN deprecated time-grunt@2.0.0: Deprecated because Grunt is practically unmaintained. Move on to something better. This package will continue to work with Grunt v1, but it will not receive any updates.
        > electron-chromedriver@1.8.0 install /home/pi/MagicMirror/node_modules/electron-chromedriver
        > node ./download-chromedriver.js
        That is the position cursor is blinking and nothing change since a long time.
        Here you are the install.log from actual running? installation.
        install starting  - So Sep 22 18:22:15 CEST 2019
        installing on armv6l processor system
        forcing armv71 architecture for pi 0
        Updating packages ...
        Installing helper tools ...
        Node.js is not installed.
        Installing Node.js ...
        Node.js installation Done! version=v10.15.2
        npm is not installed.
        Installing npm ...
        upgrading npm to latest
        Cheers, bdream
        cheers, bdream
          bdream
          Oh boy, so bad.
          Maybe I don’t understand what I’m doing here.
          install.log has not changed but MM ist also not running.
          After I stopped above stated blinking curser with Ctrl - C
          I did install MM
          npm install
          after I did
          npm install pm@latest -g
          what failed.
          I’m :pouting_face:
          Do I go total wrong way here?
          Where is my fault?
          Maybe it’s that I’m not clear in what will your script do and what have I to do additional and in which sequence?
          Have you any advise to me please?
          Many thanks fpor your help! bdream
          cheers, bdream
            sdetweil @bdream
            @bdream my script should do EVERYTHING…
            the chromedriver install had a problem…
            can u do this
            cd /home/pi/MagicMirror/node_modules/electron-chromedriver
            and show me what the results are…
            thanks
              bdream
              Hi Sam,
              as I get Error replaying with code inside: 0_1569315660505_Error.JPG
              cheers, bdream
              cheers, bdream
                sdetweil @bdream
                @bdream
                hmm…
                try this from the MagicMirror folder
                npm install  --arch=armv7l electron-chromedriver@1.8.0
                  bdream
                  Here it is…
                  pi@RasPiZeroWH:~/MagicMirror $ npm install  --arch=armv7l electron-chromedriver@1.8.0
                  successfully dowloaded and extracted!
                  npm WARN grunt-stylelint@0.11.1 requires a peer of stylelint@^10.0.0 but none is installed. You must install peer dependencies yourself.
                  + electron-chromedriver@1.8.0
                  updated 1 package and audited 3773 packages in 640.327s
                  found 16 high severity vulnerabilities
                    run `npm audit fix` to fix them, or `npm audit` for details
                  cheers, bdream
                  cheers, bdream
                    sdetweil @bdream
                    @bdream weird. Works normal, fails in script.
                    So, do this.
                    npm install --arch=armv71
                    Please advise your results
                      bdream
                      see here:
                      pi@RasPiZeroWH:~/MagicMirror $ npm install --arch=armv71
                      > magicmirror@2.8.0 install /home/pi/MagicMirror
                      > cd vendor && npm install
                      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@1.2.4 (node_modules/fsevents):
                      npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@1.2.4: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
                      audited 220 packages in 69.246s
                      found 5 vulnerabilities (4 low, 1 high)
                      > magicmirror@2.8.0 postinstall /home/pi/MagicMirror
                      > sh installers/postinstall/postinstall.sh && npm run install-fonts
                      MagicMirror installation successful!
                      > magicmirror@2.8.0 install-fonts /home/pi/MagicMirror
                      > cd fonts && npm install
                      audited 1 package in 7.131s
                      found 0 vulnerabilities
                      audited 3773 packages in 413.334s
                      cheers, bdream
                      cheers, bdream
                        sdetweil @bdream
                        @bdream all good!
                        Make sure to copy the sample config.js to config.js in the config folder.
                        Then npm start
                          bdream
                          Seems not to be an easy task.
                          And I totally lost what I have to do in case I want to setup it again on Pi0 :dizzy_face:
                          Cheers, bdream
                          cheers, bdream
                            sdetweil @bdream
                            @bdream hm… this hardware is not enough like pi0. My script works there.
                            I will have to look at the YAPI0 doc and see what is different
                              sdetweil @bdream
                              I’m not alowed to attach because the file type is .log
                              change the filetype to .txt
                                sdetweil @bdream
                                @bdream ok, partial install is a mess… lets try this way
                                rm -rf node_modules
                                then
                                npm start
                                  bdream
                                  npm install not yet. right?
                                  [0_1569360293647_2019-09-24T17_21_45_114Z-debug.txt](Uploading 100%)
                                  Not a working hint wit log -> txt. Only pics are allowed :(
                                  maybe as jpg even it is an log!
                                  [0_1569360379845_2019-09-24T17_21_45_114Z-debug.jpg](Uploading 100%)
                                  this is also not possible. what can I do?
                                  cheers, bdream
                                  cheers, bdream
                                    sdetweil @bdream
                                    @bdream hm… failed to find Electron v1.8.0… this should not be the case…
                                    what is the version in the ~/MagicMirror/package.json for electron?
                                     "electron": "^3.0.13",
                                      bdream
                                      you mean this part here?
                                        "dependencies": {
                                          "colors": "^1.1.2",
                                          "electron-chromedriver": "^1.8.0",
                                          "express": "^4.16.2",
                                          "express-ipfilter": "^1.0.1",
                                          "feedme": "latest",
                                          "helmet": "^3.9.0",
                                          "iconv-lite": "latest",
                                          "moment": "latest",
                                          "request": "^2.88.0",
                                          "rrule": "^2.6.2",
                                          "rrule-alt": "^2.2.8",
                                          "simple-git": "^1.85.0",
                                          "socket.io": "^2.1.1",
                                          "valid-url": "latest"
                                      cheers, bdream
                                      cheers, bdream
                                        sdetweil @bdream
                                        @bdream weird…
                                        don’t know why it works sometimes
                                        in the npm info for chromedriver is lists different code mirrors…
                                        # Electron mirror for China
                                        export ELECTRON_MIRROR="https://npm.taobao.org/mirrors/electron/"
                                        then
                                        npm install electron-chromedriver@v1.8.0 --arch=armv71
                                          bdream
                                          here the result :pouting_face:
                                          pi@RasPiZeroWH:~/MagicMirror $ export ELECTRON_MIRROR=“https://npm.taobao.org/mirrors/electron/”
                                          pi@RasPiZeroWH:~/MagicMirror $ npm install electron-chromedriver@v1.8.0 --arch=armv71
                                          events.js:174
                                                throw er; // Unhandled 'error' event
                                          Error: Invalid URI "“https://npm.taobao.org/mirrors/electron/”1.8.0/chromedriver-v1.8.0-linux-armv71.zip"
                                              at Request.init (/home/pi/MagicMirror/node_modules/request/request.js:273:31)
                                              at new Request (/home/pi/MagicMirror/node_modules/request/request.js:127:8)
                                              at request (/home/pi/MagicMirror/node_modules/request/index.js:53:10)
                                              at /home/pi/MagicMirror/node_modules/request/index.js:100:12
                                              at download (/home/pi/MagicMirror/node_modules/nugget/index.js:164:18)
                                              at /home/pi/MagicMirror/node_modules/nugget/index.js:133:18
                                              at FSReqWrap.oncomplete (fs.js:154:21)
                                          Emitted 'error' event at:
                                              at Request.init (/home/pi/MagicMirror/node_modules/request/request.js:273:17)
                                              [... lines matching original stack trace ...]
                                          npm ERR! code ELIFECYCLE
                                          npm ERR! errno 1
                                          npm ERR! electron-chromedriver@1.8.0 install: `node ./download-chromedriver.js`
                                          npm ERR! Exit status 1
                                          npm ERR!
                                          npm ERR! Failed at the electron-chromedriver@1.8.0 install script.
                                          npm ERR!     /home/pi/.npm/_logs/2019-09-25T13_49_38_086Z-debug.log
                                          Will it make sense starting again with a clean raspbian?
                                          Maybe there is anything weird on it…
                                          Cheers, bdream
                                          cheers, bdream
                                            sdetweil @bdream
                                            no, this is the weird double quotes(the forum turns them into word document quotes), bad cut and paste on my part
                                            either re-copy the commandline (I fixed my post) , or delete the double quote " and redo, start and end of the mirror setting
                                            • 2 / 6
