    YAPi0 Installer Stretch Lite
    118 Posts 4 Posters 118.1k Views 3 Watching
      sdetweil @bdream
      @bdream
      hmm…
      try this from the MagicMirror folder
      npm install  --arch=armv7l electron-chromedriver@1.8.0
        bdream
        Here it is…
        pi@RasPiZeroWH:~/MagicMirror $ npm install  --arch=armv7l electron-chromedriver@1.8.0
        > electron-chromedriver@1.8.0 install /home/pi/MagicMirror/node_modules/electron-chromedriver
        > node ./download-chromedriver.js
        successfully dowloaded and extracted!
        npm WARN grunt-stylelint@0.11.1 requires a peer of stylelint@^10.0.0 but none is installed. You must install peer dependencies yourself.
        + electron-chromedriver@1.8.0
        updated 1 package and audited 3773 packages in 640.327s
        found 16 high severity vulnerabilities
          run `npm audit fix` to fix them, or `npm audit` for details
        cheers, bdream
        cheers, bdream
          sdetweil @bdream
          @bdream weird. Works normal, fails in script.
          So, do this.
          npm install --arch=armv71
          Please advise your results
            bdream
            see here:
            pi@RasPiZeroWH:~/MagicMirror $ npm install --arch=armv71
            > magicmirror@2.8.0 install /home/pi/MagicMirror
            > cd vendor && npm install
            npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@1.2.4 (node_modules/fsevents):
            npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@1.2.4: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
            audited 220 packages in 69.246s
            found 5 vulnerabilities (4 low, 1 high)
            > magicmirror@2.8.0 postinstall /home/pi/MagicMirror
            > sh installers/postinstall/postinstall.sh && npm run install-fonts
            MagicMirror installation successful!
            > magicmirror@2.8.0 install-fonts /home/pi/MagicMirror
            > cd fonts && npm install
            audited 1 package in 7.131s
            found 0 vulnerabilities
            audited 3773 packages in 413.334s
            cheers, bdream
            cheers, bdream
              sdetweil @bdream
              @bdream all good!
              Make sure to copy the sample config.js to config.js in the config folder.
              Then npm start
                bdream
                Seems not to be an easy task.
                And I totally lost what I have to do in case I want to setup it again on Pi0 :dizzy_face:
                Cheers, bdream
                cheers, bdream
                  sdetweil @bdream
                  @bdream hm… this hardware is not enough like pi0. My script works there.
                  I will have to look at the YAPI0 doc and see what is different
                    sdetweil @bdream
                    @bdream said in YAPi0 Installer Stretch Lite:
                    I’m not alowed to attach because the file type is .log
                    change the filetype to .txt
                      sdetweil @bdream
                      @bdream ok, partial install is a mess… lets try this way
                      rm -rf node_modules
                      then
                      npm start
                        bdream
                        npm install not yet. right?
                        [0_1569360293647_2019-09-24T17_21_45_114Z-debug.txt](Uploading 100%)
                        Not a working hint wit log -> txt. Only pics are allowed :(
                        maybe as jpg even it is an log!
                        [0_1569360379845_2019-09-24T17_21_45_114Z-debug.jpg](Uploading 100%)
                        this is also not possible. what can I do?
                        cheers, bdream
                        cheers, bdream
                          sdetweil @bdream
                          @bdream hm… failed to find Electron v1.8.0… this should not be the case…
                          what is the version in the ~/MagicMirror/package.json for electron?
                           "electron": "^3.0.13",
                            bdream
                            you mean this part here?
                              "dependencies": {
                                "colors": "^1.1.2",
                                "electron-chromedriver": "^1.8.0",
                                "express": "^4.16.2",
                                "express-ipfilter": "^1.0.1",
                                "feedme": "latest",
                                "helmet": "^3.9.0",
                                "iconv-lite": "latest",
                                "moment": "latest",
                                "request": "^2.88.0",
                                "rrule": "^2.6.2",
                                "rrule-alt": "^2.2.8",
                                "simple-git": "^1.85.0",
                                "socket.io": "^2.1.1",
                                "valid-url": "latest"
                            cheers, bdream
                            cheers, bdream
                              sdetweil @bdream
                              @bdream weird…
                              don’t know why it works sometimes
                              in the npm info for chromedriver is lists different code mirrors…
                              # Electron mirror for China
                              export ELECTRON_MIRROR="https://npm.taobao.org/mirrors/electron/"
                              then
                              npm install electron-chromedriver@v1.8.0 --arch=armv71
                                bdream
                                here the result :pouting_face:
                                pi@RasPiZeroWH:~/MagicMirror $ export ELECTRON_MIRROR=“https://npm.taobao.org/mirrors/electron/”
                                pi@RasPiZeroWH:~/MagicMirror $ npm install electron-chromedriver@v1.8.0 --arch=armv71
                                events.js:174
                                      throw er; // Unhandled 'error' event
                                Error: Invalid URI "“https://npm.taobao.org/mirrors/electron/”1.8.0/chromedriver-v1.8.0-linux-armv71.zip"
                                    at Request.init (/home/pi/MagicMirror/node_modules/request/request.js:273:31)
                                    at new Request (/home/pi/MagicMirror/node_modules/request/request.js:127:8)
                                    at request (/home/pi/MagicMirror/node_modules/request/index.js:53:10)
                                    at /home/pi/MagicMirror/node_modules/request/index.js:100:12
                                    at download (/home/pi/MagicMirror/node_modules/nugget/index.js:164:18)
                                    at /home/pi/MagicMirror/node_modules/nugget/index.js:133:18
                                    at FSReqWrap.oncomplete (fs.js:154:21)
                                Emitted 'error' event at:
                                    at Request.init (/home/pi/MagicMirror/node_modules/request/request.js:273:17)
                                    [... lines matching original stack trace ...]
                                npm ERR! code ELIFECYCLE
                                npm ERR! errno 1
                                npm ERR! electron-chromedriver@1.8.0 install: `node ./download-chromedriver.js`
                                npm ERR! Exit status 1
                                npm ERR!
                                npm ERR! Failed at the electron-chromedriver@1.8.0 install script.
                                npm ERR!     /home/pi/.npm/_logs/2019-09-25T13_49_38_086Z-debug.log
                                Will it make sense starting again with a clean raspbian?
                                Maybe there is anything weird on it…
                                Cheers, bdream
                                cheers, bdream
                                  sdetweil @bdream
                                  no, this is the weird double quotes(the forum turns them into word document quotes), bad cut and paste on my part
                                  either re-copy the commandline (I fixed my post) , or delete the double quote " and redo, start and end of the mirror setting
                                    bdream
                                    @sdetweil redo, start and end of the mirror setting
                                    does it mean again (but single quotes in export ELECTRON…)?
                                    export ELECTRON_MIRROR='https://npm.taobao.org/mirrors/electron/'
                                    Sorry for this many beginner-questions :disappointed_face:
                                    cheers, bdream
                                    cheers, bdream
                                      sdetweil @bdream
                                      @bdream no… need double quotes…
                                      use this. the markup protects the quotes…
                                        bdream
                                        No change to before.
                                        I tried already with double-quotes.
                                        Only thing I changed now is executing
                                        cd ~
                                        and afterwards
                                        cheers, bdream
                                          sdetweil @bdream
                                          @bdream weird…
                                          works here on three different systems…
                                          can u show me the output of
                                          uname -a
                                          and
                                          lsb_release -a
                                            bdream
                                            uname -a
                                            Linux RasPiZeroWH 4.19.66+ #1253 Thu Aug 15 11:37:30 BST 2019 armv6l GNU/Linux
                                            lsb_release -a
                                            No LSB modules are available.
                                            Distributor ID: Raspbian
                                            Description:    Raspbian GNU/Linux 10 (buster)
                                            Release:        10
                                            Codename:       buster
                                            cheers, bdream
                                            • 2 / 6
