    YAPi0 Installer Stretch Lite
    118 Posts 4 Posters 120.4k Views 3 Watching
      sdetweil @bdream
      @bdream the installer also fixes pm2 and the screen saver
      and creates a log of the install process results
      i don’t think u will need the other steps in the pi0 manual anymore
        bdream
        thanks for this info, so I know what to do if my attempt to fix first installation only by deleting /MagicMirror and start your script fails :frowning_face: :winking_face:. And it failed :frowning_face:
        I get a new “Raspbian Buster Lite” now and start again :nerd_face:
        Will let you know about the outcome. It will take long time :sleeping_face:
        Best gerads, bdream
        cheers, bdream
          sdetweil @bdream
          @bdream said in YAPi0 Installer Stretch Lite:
          start your script fails . And it failed
          please post the contents of ~/install.log
            bdream
            Ohh sdetweil, my bad. I overwrote the SD-card already with the new image. I have to learn how to work with forum and being sensitive for upcoming questions/requests.
            For now I started your script again an it seems it’s running :sleeping_face:
            I wonder as I have on screen a warning
            npm WARN npm npm does not support Node.js v10.15.2
            npm WARN npm You should probably upgrade to a newer version of node as we
            npm WARN npm can't make promises that npm will work with this version.
            npm WARN npm Supported releases of Node.js are the latest releases of 4, 6, 7, 8, 9.
            npm WARN npm You can find the latest version at https://nodejs.org/
            /usr/local/bin/npm -> /usr/local/lib/node_modules/npm/bin/npm-cli.js
            /usr/local/bin/npx -> /usr/local/lib/node_modules/npm/bin/npx-cli.js
            + npm@6.11.3
            added 430 packages from 833 contributors in 433.321s
            npm installation Done!
            Cloning MagicMirror ...
            Klone nach 'MagicMirror' ...
            remote: Enumerating objects: 315, done.
            remote: Counting objects: 100% (315/315), done.
            remote: Compressing objects: 100% (282/282), done.
            remote: Total 315 (delta 39), reused 193 (delta 21), pack-reused 0
            Empangene Obekte: 100% (315/315), 655.08 KiB | 867.00 KiB/s, Fertig.
            Löse Unterschiede auf: 100% (39/39), Fertig.
            Cloning MagicMirror Done!
            Installing dependencies ...
            npm WARN deprecated time-grunt@2.0.0: Deprecated because Grunt is practically unmaintained. Move on to something better. This package will continue to work with Grunt v1, but it will not receive any updates.
            > electron-chromedriver@1.8.0 install /home/pi/MagicMirror/node_modules/electron-chromedriver
            > node ./download-chromedriver.js
            That is the position cursor is blinking and nothing change since a long time.
            Here you are the install.log from actual running? installation.
            install starting  - So Sep 22 18:22:15 CEST 2019
            installing on armv6l processor system
            forcing armv71 architecture for pi 0
            Updating packages ...
            Installing helper tools ...
            Node.js is not installed.
            Installing Node.js ...
            Node.js installation Done! version=v10.15.2
            npm is not installed.
            Installing npm ...
            upgrading npm to latest
            Cheers, bdream
            cheers, bdream
              bdream
              Oh boy, so bad.
              Maybe I don’t understand what I’m doing here.
              install.log has not changed but MM ist also not running.
              After I stopped above stated blinking curser with Ctrl - C
              I did install MM
              npm install
              after I did
              npm install pm@latest -g
              what failed.
              I’m :pouting_face:
              Do I go total wrong way here?
              Where is my fault?
              Maybe it’s that I’m not clear in what will your script do and what have I to do additional and in which sequence?
              Have you any advise to me please?
              Many thanks fpor your help! bdream
              cheers, bdream
                sdetweil @bdream
                @bdream my script should do EVERYTHING…
                the chromedriver install had a problem…
                can u do this
                cd /home/pi/MagicMirror/node_modules/electron-chromedriver
                and show me what the results are…
                thanks
                  bdream
                  Hi Sam,
                  as I get Error replaying with code inside: 0_1569315660505_Error.JPG
                  cheers, bdream
                  cheers, bdream
                    sdetweil @bdream
                    @bdream
                    hmm…
                    try this from the MagicMirror folder
                    npm install  --arch=armv7l electron-chromedriver@1.8.0
                      bdream
                      Here it is…
                      pi@RasPiZeroWH:~/MagicMirror $ npm install  --arch=armv7l electron-chromedriver@1.8.0
                      successfully dowloaded and extracted!
                      npm WARN grunt-stylelint@0.11.1 requires a peer of stylelint@^10.0.0 but none is installed. You must install peer dependencies yourself.
                      + electron-chromedriver@1.8.0
                      updated 1 package and audited 3773 packages in 640.327s
                      found 16 high severity vulnerabilities
                        run `npm audit fix` to fix them, or `npm audit` for details
                      cheers, bdream
                      cheers, bdream
                        sdetweil @bdream
                        @bdream weird. Works normal, fails in script.
                        So, do this.
                        npm install --arch=armv71
                        Please advise your results
                          bdream
                          see here:
                          pi@RasPiZeroWH:~/MagicMirror $ npm install --arch=armv71
                          > magicmirror@2.8.0 install /home/pi/MagicMirror
                          > cd vendor && npm install
                          npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@1.2.4 (node_modules/fsevents):
                          npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@1.2.4: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
                          audited 220 packages in 69.246s
                          found 5 vulnerabilities (4 low, 1 high)
                          > magicmirror@2.8.0 postinstall /home/pi/MagicMirror
                          > sh installers/postinstall/postinstall.sh && npm run install-fonts
                          MagicMirror installation successful!
                          > magicmirror@2.8.0 install-fonts /home/pi/MagicMirror
                          > cd fonts && npm install
                          audited 1 package in 7.131s
                          found 0 vulnerabilities
                          audited 3773 packages in 413.334s
                          cheers, bdream
                          cheers, bdream
                            sdetweil @bdream
                            @bdream all good!
                            Make sure to copy the sample config.js to config.js in the config folder.
                            Then npm start
                              bdream
                              Seems not to be an easy task.
                              And I totally lost what I have to do in case I want to setup it again on Pi0 :dizzy_face:
                              Cheers, bdream
                              cheers, bdream
                              S 2 Replies Last reply
                                sdetweil @bdream
                                @bdream hm… this hardware is not enough like pi0. My script works there.
                                I will have to look at the YAPI0 doc and see what is different
                                  sdetweil @bdream
                                  I’m not alowed to attach because the file type is .log
                                  change the filetype to .txt
                                    sdetweil @bdream
                                    @bdream ok, partial install is a mess… lets try this way
                                    rm -rf node_modules
                                    then
                                    npm start
                                      bdream
                                      npm install not yet. right?
                                      [0_1569360293647_2019-09-24T17_21_45_114Z-debug.txt](Uploading 100%)
                                      Not a working hint wit log -> txt. Only pics are allowed :(
                                      maybe as jpg even it is an log!
                                      [0_1569360379845_2019-09-24T17_21_45_114Z-debug.jpg](Uploading 100%)
                                      this is also not possible. what can I do?
                                      cheers, bdream
                                      cheers, bdream
                                        sdetweil @bdream
                                        @bdream hm… failed to find Electron v1.8.0… this should not be the case…
                                        what is the version in the ~/MagicMirror/package.json for electron?
                                         "electron": "^3.0.13",
                                          bdream
                                          you mean this part here?
                                            "dependencies": {
                                              "colors": "^1.1.2",
                                              "electron-chromedriver": "^1.8.0",
                                              "express": "^4.16.2",
                                              "express-ipfilter": "^1.0.1",
                                              "feedme": "latest",
                                              "helmet": "^3.9.0",
                                              "iconv-lite": "latest",
                                              "moment": "latest",
                                              "request": "^2.88.0",
                                              "rrule": "^2.6.2",
                                              "rrule-alt": "^2.2.8",
                                              "simple-git": "^1.85.0",
                                              "socket.io": "^2.1.1",
                                              "valid-url": "latest"
                                          cheers, bdream
                                          cheers, bdream
                                            sdetweil @bdream
                                            @bdream weird…
                                            don’t know why it works sometimes
                                            in the npm info for chromedriver is lists different code mirrors…
                                            # Electron mirror for China
                                            export ELECTRON_MIRROR="https://npm.taobao.org/mirrors/electron/"
                                            then
                                            npm install electron-chromedriver@v1.8.0 --arch=armv71
                                            • 1 / 6
