    YAPi0 Installer Stretch Lite
    118 Posts 4 Posters 120.4k Views 3 Watching
      bdream
      Here it is…
      pi@RasPiZeroWH:~/MagicMirror $ npm install  --arch=armv7l electron-chromedriver@1.8.0
      > electron-chromedriver@1.8.0 install /home/pi/MagicMirror/node_modules/electron-chromedriver
      > node ./download-chromedriver.js
      successfully dowloaded and extracted!
      npm WARN grunt-stylelint@0.11.1 requires a peer of stylelint@^10.0.0 but none is installed. You must install peer dependencies yourself.
      + electron-chromedriver@1.8.0
      updated 1 package and audited 3773 packages in 640.327s
      found 16 high severity vulnerabilities
        run `npm audit fix` to fix them, or `npm audit` for details
      cheers, bdream
      cheers, bdream
        sdetweil @bdream
        @bdream weird. Works normal, fails in script.
        So, do this.
        npm install --arch=armv71
        Please advise your results
          bdream
          see here:
          pi@RasPiZeroWH:~/MagicMirror $ npm install --arch=armv71
          > magicmirror@2.8.0 install /home/pi/MagicMirror
          > cd vendor && npm install
          npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@1.2.4 (node_modules/fsevents):
          npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@1.2.4: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
          audited 220 packages in 69.246s
          found 5 vulnerabilities (4 low, 1 high)
          > magicmirror@2.8.0 postinstall /home/pi/MagicMirror
          > sh installers/postinstall/postinstall.sh && npm run install-fonts
          MagicMirror installation successful!
          > magicmirror@2.8.0 install-fonts /home/pi/MagicMirror
          > cd fonts && npm install
          audited 1 package in 7.131s
          found 0 vulnerabilities
          audited 3773 packages in 413.334s
          cheers, bdream
          cheers, bdream
            sdetweil @bdream
            @bdream all good!
            Make sure to copy the sample config.js to config.js in the config folder.
            Then npm start
              bdream
              Seems not to be an easy task.
              And I totally lost what I have to do in case I want to setup it again on Pi0 :dizzy_face:
              Cheers, bdream
              cheers, bdream
              S 2 Replies Last reply
                sdetweil @bdream
                @bdream hm… this hardware is not enough like pi0. My script works there.
                I will have to look at the YAPI0 doc and see what is different
                  sdetweil @bdream
                  @bdream said in YAPi0 Installer Stretch Lite:
                  I’m not alowed to attach because the file type is .log
                  change the filetype to .txt
                    sdetweil @bdream
                    @bdream ok, partial install is a mess… lets try this way
                    rm -rf node_modules
                    then
                    npm start
                      bdream
                      npm install not yet. right?
                      [0_1569360293647_2019-09-24T17_21_45_114Z-debug.txt](Uploading 100%)
                      Not a working hint wit log -> txt. Only pics are allowed :(
                      maybe as jpg even it is an log!
                      [0_1569360379845_2019-09-24T17_21_45_114Z-debug.jpg](Uploading 100%)
                      this is also not possible. what can I do?
                      cheers, bdream
                      cheers, bdream
                        sdetweil @bdream
                        @bdream hm… failed to find Electron v1.8.0… this should not be the case…
                        what is the version in the ~/MagicMirror/package.json for electron?
                         "electron": "^3.0.13",
                          bdream
                          you mean this part here?
                            "dependencies": {
                              "colors": "^1.1.2",
                              "electron-chromedriver": "^1.8.0",
                              "express": "^4.16.2",
                              "express-ipfilter": "^1.0.1",
                              "feedme": "latest",
                              "helmet": "^3.9.0",
                              "iconv-lite": "latest",
                              "moment": "latest",
                              "request": "^2.88.0",
                              "rrule": "^2.6.2",
                              "rrule-alt": "^2.2.8",
                              "simple-git": "^1.85.0",
                              "socket.io": "^2.1.1",
                              "valid-url": "latest"
                          cheers, bdream
                          cheers, bdream
                            sdetweil @bdream
                            @bdream weird…
                            don’t know why it works sometimes
                            in the npm info for chromedriver is lists different code mirrors…
                            # Electron mirror for China
                            export ELECTRON_MIRROR="https://npm.taobao.org/mirrors/electron/"
                            then
                            npm install electron-chromedriver@v1.8.0 --arch=armv71
                              bdream
                              here the result :pouting_face:
                              pi@RasPiZeroWH:~/MagicMirror $ export ELECTRON_MIRROR=“https://npm.taobao.org/mirrors/electron/”
                              pi@RasPiZeroWH:~/MagicMirror $ npm install electron-chromedriver@v1.8.0 --arch=armv71
                              events.js:174
                                    throw er; // Unhandled 'error' event
                              Error: Invalid URI "“https://npm.taobao.org/mirrors/electron/”1.8.0/chromedriver-v1.8.0-linux-armv71.zip"
                                  at Request.init (/home/pi/MagicMirror/node_modules/request/request.js:273:31)
                                  at new Request (/home/pi/MagicMirror/node_modules/request/request.js:127:8)
                                  at request (/home/pi/MagicMirror/node_modules/request/index.js:53:10)
                                  at /home/pi/MagicMirror/node_modules/request/index.js:100:12
                                  at download (/home/pi/MagicMirror/node_modules/nugget/index.js:164:18)
                                  at /home/pi/MagicMirror/node_modules/nugget/index.js:133:18
                                  at FSReqWrap.oncomplete (fs.js:154:21)
                              Emitted 'error' event at:
                                  at Request.init (/home/pi/MagicMirror/node_modules/request/request.js:273:17)
                                  [... lines matching original stack trace ...]
                              npm ERR! code ELIFECYCLE
                              npm ERR! errno 1
                              npm ERR! electron-chromedriver@1.8.0 install: `node ./download-chromedriver.js`
                              npm ERR! Exit status 1
                              npm ERR!
                              npm ERR! Failed at the electron-chromedriver@1.8.0 install script.
                              npm ERR!     /home/pi/.npm/_logs/2019-09-25T13_49_38_086Z-debug.log
                              Will it make sense starting again with a clean raspbian?
                              Maybe there is anything weird on it…
                              Cheers, bdream
                              cheers, bdream
                                sdetweil @bdream
                                no, this is the weird double quotes(the forum turns them into word document quotes), bad cut and paste on my part
                                either re-copy the commandline (I fixed my post) , or delete the double quote " and redo, start and end of the mirror setting
                                  bdream
                                  @sdetweil redo, start and end of the mirror setting
                                  does it mean again (but single quotes in export ELECTRON…)?
                                  export ELECTRON_MIRROR='https://npm.taobao.org/mirrors/electron/'
                                  Sorry for this many beginner-questions :disappointed_face:
                                  cheers, bdream
                                  cheers, bdream
                                    sdetweil @bdream
                                    @bdream no… need double quotes…
                                    use this. the markup protects the quotes…
                                      bdream
                                      No change to before.
                                      I tried already with double-quotes.
                                      Only thing I changed now is executing
                                      cd ~
                                      and afterwards
                                      cheers, bdream
                                        sdetweil @bdream
                                        @bdream weird…
                                        works here on three different systems…
                                        can u show me the output of
                                        uname -a
                                        and
                                        lsb_release -a
                                          bdream
                                          uname -a
                                          Linux RasPiZeroWH 4.19.66+ #1253 Thu Aug 15 11:37:30 BST 2019 armv6l GNU/Linux
                                          lsb_release -a
                                          No LSB modules are available.
                                          Distributor ID: Raspbian
                                          Description:    Raspbian GNU/Linux 10 (buster)
                                          Release:        10
                                          Codename:       buster
                                          cheers, bdream
                                            cd ~
                                            u need to be in the MagicMirror folder
                                            I get the same error as you in the home folder
                                            every command MagicMirror related MUST be done from the MagicMirror folder (except the install script from the product or forum links)
                                            • 2 / 6
