    YAPi0 Installer Stretch Lite
    118 Posts 4 Posters 114.3k Views 3 Watching
      sdetweil @bdream
      @bdream ok, partial install is a mess… lets try this way
      rm -rf node_modules
      npm install --arch=armv71
      then
      npm start
        bdream
        npm install not yet. right?
        [0_1569360293647_2019-09-24T17_21_45_114Z-debug.txt](Uploading 100%)
        Not a working hint wit log -> txt. Only pics are allowed :(
        maybe as jpg even it is an log!
        [0_1569360379845_2019-09-24T17_21_45_114Z-debug.jpg](Uploading 100%)
        this is also not possible. what can I do?
        cheers, bdream
        cheers, bdream
          sdetweil @bdream
          @bdream hm… failed to find Electron v1.8.0… this should not be the case…
          what is the version in the ~/MagicMirror/package.json for electron?
           "electron": "^3.0.13",
            bdream
            you mean this part here?
              "dependencies": {
                "colors": "^1.1.2",
                "electron-chromedriver": "^1.8.0",
                "express": "^4.16.2",
                "express-ipfilter": "^1.0.1",
                "feedme": "latest",
                "helmet": "^3.9.0",
                "iconv-lite": "latest",
                "moment": "latest",
                "request": "^2.88.0",
                "rrule": "^2.6.2",
                "rrule-alt": "^2.2.8",
                "simple-git": "^1.85.0",
                "socket.io": "^2.1.1",
                "valid-url": "latest"
            cheers, bdream
            cheers, bdream
              sdetweil @bdream
              @bdream weird…
              don’t know why it works sometimes
              in the npm info for chromedriver is lists different code mirrors…
              # Electron mirror for China
              export ELECTRON_MIRROR="https://npm.taobao.org/mirrors/electron/"
              then
              npm install electron-chromedriver@v1.8.0 --arch=armv71
                bdream
                here the result :pouting_face:
                pi@RasPiZeroWH:~/MagicMirror $ export ELECTRON_MIRROR=“https://npm.taobao.org/mirrors/electron/”
                pi@RasPiZeroWH:~/MagicMirror $ npm install electron-chromedriver@v1.8.0 --arch=armv71
                > electron-chromedriver@1.8.0 install /home/pi/MagicMirror/node_modules/electron-chromedriver
                > node ./download-chromedriver.js
                events.js:174
                      throw er; // Unhandled 'error' event
                Error: Invalid URI "“https://npm.taobao.org/mirrors/electron/”1.8.0/chromedriver-v1.8.0-linux-armv71.zip"
                    at Request.init (/home/pi/MagicMirror/node_modules/request/request.js:273:31)
                    at new Request (/home/pi/MagicMirror/node_modules/request/request.js:127:8)
                    at request (/home/pi/MagicMirror/node_modules/request/index.js:53:10)
                    at /home/pi/MagicMirror/node_modules/request/index.js:100:12
                    at download (/home/pi/MagicMirror/node_modules/nugget/index.js:164:18)
                    at /home/pi/MagicMirror/node_modules/nugget/index.js:133:18
                    at FSReqWrap.oncomplete (fs.js:154:21)
                Emitted 'error' event at:
                    at Request.init (/home/pi/MagicMirror/node_modules/request/request.js:273:17)
                    [... lines matching original stack trace ...]
                npm WARN grunt-stylelint@0.11.1 requires a peer of stylelint@^10.0.0 but none is installed. You must install peer dependencies yourself.
                npm ERR! code ELIFECYCLE
                npm ERR! errno 1
                npm ERR! electron-chromedriver@1.8.0 install: `node ./download-chromedriver.js`
                npm ERR! Exit status 1
                npm ERR!
                npm ERR! Failed at the electron-chromedriver@1.8.0 install script.
                npm ERR!     /home/pi/.npm/_logs/2019-09-25T13_49_38_086Z-debug.log
                Will it make sense starting again with a clean raspbian?
                Maybe there is anything weird on it…
                Cheers, bdream
                cheers, bdream
                  sdetweil @bdream
                  @bdream said in YAPi0 Installer Stretch Lite:
                  no, this is the weird double quotes(the forum turns them into word document quotes), bad cut and paste on my part
                  either re-copy the commandline (I fixed my post) , or delete the double quote " and redo, start and end of the mirror setting
                    bdream
                    @sdetweil redo, start and end of the mirror setting
                    does it mean again (but single quotes in export ELECTRON…)?
                    export ELECTRON_MIRROR='https://npm.taobao.org/mirrors/electron/'
                    Sorry for this many beginner-questions :disappointed_face:
                    cheers, bdream
                    cheers, bdream
                      sdetweil @bdream
                      @bdream no… need double quotes…
                      use this. the markup protects the quotes…
                        bdream
                        No change to before.
                        I tried already with double-quotes.
                        Only thing I changed now is executing
                        cd ~
                        and afterwards
                        cheers, bdream
                          sdetweil @bdream
                          @bdream weird…
                          works here on three different systems…
                          can u show me the output of
                          uname -a
                          and
                          lsb_release -a
                            bdream
                            uname -a
                            Linux RasPiZeroWH 4.19.66+ #1253 Thu Aug 15 11:37:30 BST 2019 armv6l GNU/Linux
                            lsb_release -a
                            No LSB modules are available.
                            Distributor ID: Raspbian
                            Description:    Raspbian GNU/Linux 10 (buster)
                            Release:        10
                            Codename:       buster
                            cheers, bdream
                              cd ~
                              u need to be in the MagicMirror folder
                              I get the same error as you in the home folder
                              every command MagicMirror related MUST be done from the MagicMirror folder (except the install script from the product or forum links)
                                @sdetweil looks like once its messed up, its messed up, and u have to start over with
                                (from the magicmirror folder)
                                at least I had to…
                                  bdream
                                  Hi Sam, that was the first attempt I did anyway, starting in MagicMirror folder.
                                  Only last I missed it :frowning_face:
                                  I tried it again in this folder, but result is bad.
                                  I guess it makes no sense working on this.
                                  You said you have running multiple Pi0… let me try another one.
                                  Not starting with wrong way let me ask if my understanding is right.
                                  1. It dosn’t matter if I run SSH or direkt with keyboard attached. Also changing for the different steps?
                                  2. preperation as shown are done
                                  sudo apt-get update
                                  sudo apt-get upgrade
                                  sudo apt-get dist-upgrade
                                  sudo apt-get autoremove && sudo reboot
                                  1. I will run your updated script
                                  bash -c "$(curl -sL https://www.dropbox.com/s/rlh710ng0zwv3vp/raspberry.sh?dl=0)"
                                  1. start MM
                                  Is this right?
                                  cheers, bdream
                                    sdetweil @bdream
                                    @bdream my script does all the system updates too…
                                    and it will start MM at the end if u use pm2.
                                    I do all my work on my mirrors over ssh.
                                      bdream
                                      that’s great :grinning_face:
                                      at the beginning it asks that’s not an Raspberry 2 or 3… continue?
                                      So I try with Raspberry Zerro again.
                                      hope it will work now as I will be off next 2-3 weeks.
                                      cheers, bdream
                                        sdetweil @bdream
                                        @bdream correct, just hit enter to continue
                                          bdream
                                          it’s running now.:crossed_fingers_medium-light_skin_tone:
                                          cheers, bdream
                                            bdream
                                            Just get following warnings similar to my post 3 days ago
                                            npm WARN npm npm does not support Node.js v10.15.2
                                            npm WARN npm You should probably upgrade to a newer version of node as we
                                            npm WARN npm can't make promises that npm will work with this version.
                                            npm WARN npm Supported releases of Node.js are the latest releases of 4, 6, 7, 8, 9.
                                            npm WARN npm You can find the latest version at https://nodejs.org/
                                            /usr/local/bin/npm -> /usr/local/lib/node_modules/npm/bin/npm-cli.js
                                            /usr/local/bin/npx -> /usr/local/lib/node_modules/npm/bin/npx-cli.js
                                            + npm@6.11.3
                                            added 430 packages from 833 contributors in 299.269s
                                            npm installation Done!
                                            cheers, bdream
                                            • 2 / 6
