    YAPi0 Installer Stretch Lite
    118 Posts 4 Posters 120.4k Views 3 Watching
      sdetweil @bdream
      @bdream hm… failed to find Electron v1.8.0… this should not be the case…
      what is the version in the ~/MagicMirror/package.json for electron?
       "electron": "^3.0.13",
        bdream
        you mean this part here?
          "dependencies": {
            "colors": "^1.1.2",
            "electron-chromedriver": "^1.8.0",
            "express": "^4.16.2",
            "express-ipfilter": "^1.0.1",
            "feedme": "latest",
            "helmet": "^3.9.0",
            "iconv-lite": "latest",
            "moment": "latest",
            "request": "^2.88.0",
            "rrule": "^2.6.2",
            "rrule-alt": "^2.2.8",
            "simple-git": "^1.85.0",
            "socket.io": "^2.1.1",
            "valid-url": "latest"
        cheers, bdream
        cheers, bdream
          sdetweil @bdream
          @bdream weird…
          don’t know why it works sometimes
          in the npm info for chromedriver is lists different code mirrors…
          # Electron mirror for China
          export ELECTRON_MIRROR="https://npm.taobao.org/mirrors/electron/"
          then
          npm install electron-chromedriver@v1.8.0 --arch=armv71
            bdream
            here the result :pouting_face:
            pi@RasPiZeroWH:~/MagicMirror $ export ELECTRON_MIRROR=“https://npm.taobao.org/mirrors/electron/”
            pi@RasPiZeroWH:~/MagicMirror $ npm install electron-chromedriver@v1.8.0 --arch=armv71
            > electron-chromedriver@1.8.0 install /home/pi/MagicMirror/node_modules/electron-chromedriver
            > node ./download-chromedriver.js
            events.js:174
                  throw er; // Unhandled 'error' event
            Error: Invalid URI "“https://npm.taobao.org/mirrors/electron/”1.8.0/chromedriver-v1.8.0-linux-armv71.zip"
                at Request.init (/home/pi/MagicMirror/node_modules/request/request.js:273:31)
                at new Request (/home/pi/MagicMirror/node_modules/request/request.js:127:8)
                at request (/home/pi/MagicMirror/node_modules/request/index.js:53:10)
                at /home/pi/MagicMirror/node_modules/request/index.js:100:12
                at download (/home/pi/MagicMirror/node_modules/nugget/index.js:164:18)
                at /home/pi/MagicMirror/node_modules/nugget/index.js:133:18
                at FSReqWrap.oncomplete (fs.js:154:21)
            Emitted 'error' event at:
                at Request.init (/home/pi/MagicMirror/node_modules/request/request.js:273:17)
                [... lines matching original stack trace ...]
            npm WARN grunt-stylelint@0.11.1 requires a peer of stylelint@^10.0.0 but none is installed. You must install peer dependencies yourself.
            npm ERR! code ELIFECYCLE
            npm ERR! errno 1
            npm ERR! electron-chromedriver@1.8.0 install: `node ./download-chromedriver.js`
            npm ERR! Exit status 1
            npm ERR!
            npm ERR! Failed at the electron-chromedriver@1.8.0 install script.
            npm ERR!     /home/pi/.npm/_logs/2019-09-25T13_49_38_086Z-debug.log
            Will it make sense starting again with a clean raspbian?
            Maybe there is anything weird on it…
            Cheers, bdream
            cheers, bdream
              sdetweil @bdream
              @bdream said in YAPi0 Installer Stretch Lite:
              no, this is the weird double quotes(the forum turns them into word document quotes), bad cut and paste on my part
              either re-copy the commandline (I fixed my post) , or delete the double quote " and redo, start and end of the mirror setting
                bdream
                @sdetweil redo, start and end of the mirror setting
                does it mean again (but single quotes in export ELECTRON…)?
                export ELECTRON_MIRROR='https://npm.taobao.org/mirrors/electron/'
                Sorry for this many beginner-questions :disappointed_face:
                cheers, bdream
                cheers, bdream
                  sdetweil @bdream
                  @bdream no… need double quotes…
                  use this. the markup protects the quotes…
                    bdream
                    No change to before.
                    I tried already with double-quotes.
                    Only thing I changed now is executing
                    cd ~
                    and afterwards
                    cheers, bdream
                      sdetweil @bdream
                      @bdream weird…
                      works here on three different systems…
                      can u show me the output of
                      uname -a
                      and
                      lsb_release -a
                        bdream
                        uname -a
                        Linux RasPiZeroWH 4.19.66+ #1253 Thu Aug 15 11:37:30 BST 2019 armv6l GNU/Linux
                        lsb_release -a
                        No LSB modules are available.
                        Distributor ID: Raspbian
                        Description:    Raspbian GNU/Linux 10 (buster)
                        Release:        10
                        Codename:       buster
                        cheers, bdream
                          cd ~
                          u need to be in the MagicMirror folder
                          I get the same error as you in the home folder
                          every command MagicMirror related MUST be done from the MagicMirror folder (except the install script from the product or forum links)
                            @sdetweil looks like once its messed up, its messed up, and u have to start over with
                            npm install --arch=armv71
                            (from the magicmirror folder)
                            at least I had to…
                              bdream
                              Hi Sam, that was the first attempt I did anyway, starting in MagicMirror folder.
                              Only last I missed it :frowning_face:
                              I tried it again in this folder, but result is bad.
                              I guess it makes no sense working on this.
                              You said you have running multiple Pi0… let me try another one.
                              Not starting with wrong way let me ask if my understanding is right.
                              1. It dosn’t matter if I run SSH or direkt with keyboard attached. Also changing for the different steps?
                              2. preperation as shown are done
                              sudo apt-get update
                              sudo apt-get upgrade
                              sudo apt-get dist-upgrade
                              sudo apt-get autoremove && sudo reboot
                              1. I will run your updated script
                              bash -c "$(curl -sL https://www.dropbox.com/s/rlh710ng0zwv3vp/raspberry.sh?dl=0)"
                              1. start MM
                              Is this right?
                              cheers, bdream
                                sdetweil @bdream
                                @bdream my script does all the system updates too…
                                and it will start MM at the end if u use pm2.
                                I do all my work on my mirrors over ssh.
                                  bdream
                                  that’s great :grinning_face:
                                  at the beginning it asks that’s not an Raspberry 2 or 3… continue?
                                  So I try with Raspberry Zerro again.
                                  hope it will work now as I will be off next 2-3 weeks.
                                  cheers, bdream
                                    sdetweil @bdream
                                    @bdream correct, just hit enter to continue
                                      bdream
                                      it’s running now.:crossed_fingers_medium-light_skin_tone:
                                      cheers, bdream
                                        bdream
                                        Just get following warnings similar to my post 3 days ago
                                        npm WARN npm npm does not support Node.js v10.15.2
                                        npm WARN npm You should probably upgrade to a newer version of node as we
                                        npm WARN npm can't make promises that npm will work with this version.
                                        npm WARN npm Supported releases of Node.js are the latest releases of 4, 6, 7, 8, 9.
                                        npm WARN npm You can find the latest version at https://nodejs.org/
                                        /usr/local/bin/npm -> /usr/local/lib/node_modules/npm/bin/npm-cli.js
                                        /usr/local/bin/npx -> /usr/local/lib/node_modules/npm/bin/npx-cli.js
                                        + npm@6.11.3
                                        added 430 packages from 833 contributors in 299.269s
                                        npm installation Done!
                                        cheers, bdream
                                          bdream
                                          also this warning
                                          Installing dependencies ...
                                          npm WARN deprecated time-grunt@2.0.0: Deprecated because Grunt is practically unmaintained. Move on to something better. This package will continue to work with Grunt v1, but it will not receive any updates.
                                          cheers, bdream
                                            sdetweil @bdream
                                            @bdream so far so good… ignore warnings… 1st upgraded npm to latest
                                            • 2 / 6
