    YAPi0 Installer Stretch Lite
    118 Posts 4 Posters 120.4k Views 3 Watching
      @bdream said in YAPi0 Installer Stretch Lite:
      cd ~
      export ELECTRON_MIRROR=“https://npm.taobao.org/mirrors/electron/”
      u need to be in the MagicMirror folder
      I get the same error as you in the home folder
      every command MagicMirror related MUST be done from the MagicMirror folder (except the install script from the product or forum links)
        @sdetweil looks like once its messed up, its messed up, and u have to start over with
        npm install --arch=armv71
        (from the magicmirror folder)
        at least I had to…
          bdream
          Hi Sam, that was the first attempt I did anyway, starting in MagicMirror folder.
          Only last I missed it :frowning_face:
          I tried it again in this folder, but result is bad.
          I guess it makes no sense working on this.
          You said you have running multiple Pi0… let me try another one.
          Not starting with wrong way let me ask if my understanding is right.
          1. It dosn’t matter if I run SSH or direkt with keyboard attached. Also changing for the different steps?
          2. preperation as shown are done
          sudo apt-get update
          sudo apt-get upgrade
          sudo apt-get dist-upgrade
          sudo apt-get autoremove && sudo reboot
          1. I will run your updated script
          bash -c "$(curl -sL https://www.dropbox.com/s/rlh710ng0zwv3vp/raspberry.sh?dl=0)"
          1. start MM
          Is this right?
          cheers, bdream
            sdetweil @bdream
            @bdream my script does all the system updates too…
            and it will start MM at the end if u use pm2.
            I do all my work on my mirrors over ssh.
              bdream
              that’s great :grinning_face:
              at the beginning it asks that’s not an Raspberry 2 or 3… continue?
              So I try with Raspberry Zerro again.
              hope it will work now as I will be off next 2-3 weeks.
              cheers, bdream
                sdetweil @bdream
                @bdream correct, just hit enter to continue
                  bdream
                  it’s running now.:crossed_fingers_medium-light_skin_tone:
                  cheers, bdream
                    bdream
                    Just get following warnings similar to my post 3 days ago
                    npm WARN npm npm does not support Node.js v10.15.2
                    npm WARN npm You should probably upgrade to a newer version of node as we
                    npm WARN npm can't make promises that npm will work with this version.
                    npm WARN npm Supported releases of Node.js are the latest releases of 4, 6, 7, 8, 9.
                    npm WARN npm You can find the latest version at https://nodejs.org/
                    /usr/local/bin/npm -> /usr/local/lib/node_modules/npm/bin/npm-cli.js
                    /usr/local/bin/npx -> /usr/local/lib/node_modules/npm/bin/npx-cli.js
                    + npm@6.11.3
                    added 430 packages from 833 contributors in 299.269s
                    npm installation Done!
                    cheers, bdream
                      bdream
                      also this warning
                      Installing dependencies ...
                      npm WARN deprecated time-grunt@2.0.0: Deprecated because Grunt is practically unmaintained. Move on to something better. This package will continue to work with Grunt v1, but it will not receive any updates.
                      cheers, bdream
                        sdetweil @bdream
                        @bdream so far so good… ignore warnings… 1st upgraded npm to latest
                          bdream
                          < magicmirror2.8.0 install /home/pi/MagicMirror
                          > cd vendor && npm install
                          npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@1.2.4 (node_modules/fsevents):
                          npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@1.2.4: wanted {"os":"darwin","arch":"any"} (current: ("os":"linux","arch":"arm")
                          cheers, bdream
                            sdetweil @bdream
                              bdream
                              npm WARN grunt-stylelint@0.11.1 requires a peer of stylelint@^10.0.0 but none is installed. You must install peer dependencies yourself.
                              cheers, bdream
                                sdetweil @bdream
                                @bdream still good
                                  bdream
                                  now the question if I want to use pm2 for autostart MM I will state YES
                                  cheers, bdream
                                    sdetweil @bdream
                                    @bdream correct, reply yes or y
                                      bdream
                                      [PM2][WARN] Application MagicMirror not running, starting...
                                      [PM2] App [MagicMirror] launched (1 instances)
                                      App name | id | version | node | pid | status | restart | uptime | cpu | mem | user | watching
                                      MagicMirror | 0 | 2.8.0 | fork | 4835 | online | 0 | 3s | 0% | 2.5 MB | pi | enabled
                                      use 'pm2 show <id|name>' to get more details about an app
                                      I used pm2 show mm and got [PM2][WARN] mm doesn’t exist
                                      cheers, bdream
                                        sdetweil @bdream
                                        pm2 show mm
                                        correct,
                                        its called MagicMirror
                                        says its running…
                                        show me pm2 logs
                                        you can also use the id, instead of the name
                                        pm2 start 0,
                                        pm2 stop 0,
                                        pm2 show 0…
                                        etc
                                          bdream
                                          here you are
                                          last 3 rows coming multiple times
                                          cheers, bdream
                                            sdetweil @bdream
                                            @bdream ok, there are two logs… error and out…
                                            maybe best to do
                                            pm2 stop 0
                                            npm start
                                            • 3 / 6
