    YAPi0 Installer Stretch Lite
    118 Posts 4 Posters 103.7k Views 3 Watching
      sdetweil @bdream
      @bdream so far so good… ignore warnings… 1st upgraded npm to latest
        bdream
        < magicmirror2.8.0 install /home/pi/MagicMirror
        > cd vendor && npm install
        npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@1.2.4 (node_modules/fsevents):
        npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@1.2.4: wanted {"os":"darwin","arch":"any"} (current: ("os":"linux","arch":"arm")
        cheers, bdream
          sdetweil @bdream
            bdream
            npm WARN grunt-stylelint@0.11.1 requires a peer of stylelint@^10.0.0 but none is installed. You must install peer dependencies yourself.
            cheers, bdream
              sdetweil @bdream
              @bdream still good
                bdream
                now the question if I want to use pm2 for autostart MM I will state YES
                cheers, bdream
                  sdetweil @bdream
                  @bdream correct, reply yes or y
                    bdream
                    [PM2][WARN] Application MagicMirror not running, starting...
                    [PM2] App [MagicMirror] launched (1 instances)
                    App name | id | version | node | pid | status | restart | uptime | cpu | mem | user | watching
                    MagicMirror | 0 | 2.8.0 | fork | 4835 | online | 0 | 3s | 0% | 2.5 MB | pi | enabled
                    use 'pm2 show <id|name>' to get more details about an app
                    I used pm2 show mm and got [PM2][WARN] mm doesn’t exist
                    cheers, bdream
                      sdetweil @bdream
                      @bdream said in YAPi0 Installer Stretch Lite:
                      pm2 show mm
                      correct,
                      its called MagicMirror
                      says its running…
                      show me pm2 logs
                      you can also use the id, instead of the name
                      pm2 start 0,
                      pm2 stop 0,
                      pm2 show 0…
                      etc
                        bdream
                        here you are
                        last 3 rows coming multiple times
                        cheers, bdream
                        • 11
                        • 12
                        • 5 / 12
