    YAPi0 Installer Stretch Lite
    118 Posts 4 Posters 120.4k Views 3 Watching
      sdetweil @bdream
      @bdream still good
        bdream
        now the question if I want to use pm2 for autostart MM I will state YES
        cheers, bdream
          sdetweil @bdream
          @bdream correct, reply yes or y
            bdream
            [PM2][WARN] Application MagicMirror not running, starting...
            [PM2] App [MagicMirror] launched (1 instances)
            App name | id | version | node | pid | status | restart | uptime | cpu | mem | user | watching
            MagicMirror | 0 | 2.8.0 | fork | 4835 | online | 0 | 3s | 0% | 2.5 MB | pi | enabled
            use 'pm2 show <id|name>' to get more details about an app
            I used pm2 show mm and got [PM2][WARN] mm doesn’t exist
            cheers, bdream
              sdetweil @bdream
              @bdream said in YAPi0 Installer Stretch Lite:
              pm2 show mm
              correct,
              its called MagicMirror
              says its running…
              show me pm2 logs
              you can also use the id, instead of the name
              pm2 start 0,
              pm2 stop 0,
              pm2 show 0…
              etc
                bdream
                here you are
                last 3 rows coming multiple times
                cheers, bdream
                  sdetweil @bdream
                  @bdream ok, there are two logs… error and out…
                  maybe best to do
                  pm2 stop 0
                  npm start
                    bdream
                    pi@RasPiZeroW:~ $ cd ~/MagicMirror/
                    pi@RasPiZeroW:~/MagicMirror $ pm2 stop 0
                    [PM2] Applying action stopProcessId on app [0](ids: 0)
                    [PM2] [MagicMirror](0) ✓
                    │ App name    │ id │ version │ mode │ pid │ status  │ restart │ uptime │ cpu │ mem    │ user │ watching │
                    │ MagicMirror │ 0  │ 2.8.0   │ fork │ 0   │ stopped │ 31      │ 0      │ 0%  │ 0 B    │ pi   │ disabled │
                     Use `pm2 show <id|name>` to get more details about an app
                    pi@RasPiZeroW:~/MagicMirror $ npm start
                    > magicmirror@2.8.0 start /home/pi/MagicMirror
                    > sh run-start.sh
                    /home/pi/MagicMirror/node_modules/electron/dist/electron: error while loading shared libraries: libgtk-3.so.0: cannot open shared object file: No such file or directory
                    npm ERR! code ELIFECYCLE
                    npm ERR! syscall spawn
                    npm ERR! file sh
                    npm ERR! errno ENOENT
                    npm ERR! magicmirror@2.8.0 start: `sh run-start.sh`
                    npm ERR! spawn ENOENT
                    npm ERR!
                    npm ERR! Failed at the magicmirror@2.8.0 start script.
                    npm ERR!     /home/pi/.npm/_logs/2019-09-25T17_26_03_649Z-debug.log
                    cheers, bdream
                      sdetweil @bdream
                      @bdream
                      you MUST install the graphical UI desktop on the pi, right? MM uses graphics to display the screen.
                        bdream
                        hmm, I guess I have to investigate about this in a few weeks.
                        So far many thanks for your help here. Will have a look later today and see what can I handle. Otherwise later. I have to run for a meeting now.
                        cheers, bdream
                          bdream
                          @sdetweil said in YAPi0 Installer Stretch Lite:
                          I wonder. I understood Pi0 don’t need to have UI installed. therefor I installed the light raspbian image - maybe I’m wrong :confounded_face:
                          Do I have to install lightdm or other?
                          And then I assume use raspi-config to boot to desktop?
                          cheers, bdream
                            sdetweil @bdream
                            @bdream you can do node serveronly , instead of npm start…
                            for pm2, edit installers/mm.sh and change npm start to node serveronly
                            then pm2 restart 0
                            others have had success at running UI on p0 as well…
                            make sure u change config/config.js to allow other machines to connect
                            to allow all
                            address: “”,
                            and
                            ipWhitelist: [],
                              bdream
                              Í’m back now and started to work further on my Pi0 with MM installation.
                              I tried to get UI desktop running by installing lightdm.
                              Then reconfigured Boot option to start Desktopn and Auotologin.
                              After reboot, wich looks good, PI starts an give Debian logon screen.
                              How to autologon?
                              After I put in my credentials pi and raspberry I stuck in login-loop.
                              cheers, bdream
                                bdream
                                Any idea what to do?
                                Maybe Pi0 is not the Hardware MM will run good. Especialy in regards to upcoming updates :dizzy_face:
                                But this small device will give more oportunities for nice looking projects based on MM :grinning_face_with_smiling_eyes:
                                cheers, bdream
                                  sdetweil @bdream
                                  @bdream others have made it work… you may have to reinstall the base raspian image to get the graphical desktop running properly…
                                  I don’t have one of these pi0 devices to test with
                                    bdream
                                    @sdetweil many thanks for your guidance.
                                    I thaught Pi0 must get installed without GUI :worried_face: my fault.
                                    I will start again and see what happen.
                                    I’ll let you know if success yur script!
                                    cheers, bdream
                                      sdetweil @bdream
                                      @bdream U can run it in serveronly mode
                                      Have to edit the installers/mm.sh
                                      Or run_start.sh to do
                                      node serveronly
                                      The use browser from some other system
                                        bdream
                                        @sdetweil Raspbian Buster with desktop image already written to the sc-card.
                                        will see the time I have to work on it next time.
                                        Stuff arount serveronly and using other browser is to far from me at the moment :unamused_face:
                                        cheers, bdream
                                          sdetweil @bdream
                                          @bdream ok… there is only one MM install… but two ways to run it… so, no problem
                                            bdream
                                            @sdetweil many thanks!!
                                            cheers, bdream
                                            • 3 / 6
