    YAPi0 Installer Stretch Lite
    118 Posts 4 Posters 120.4k Views 3 Watching
      bdream
      @ stuartiannaylor
      That sounds like exacly what I’m looking for :thumbs_up:
      I finished my first MagicMirror and looking for tuning options.
      As exp. I would like to small the case a bit and would be happy to use Rpi0 instead of Rpi3.
      I followed your instruction “MagicMirror-Install-Guide-Raspberry-0-to-3”
      I installed a new raspbian “Raspbian Buster with desktop”
      may this cause my issues not using “Raspbian Buster Lite”?
      I run in problem with command
      cd ~/MagicMirror/ && npm install
      as I got many WARN and ERR messages. I’m not alowed to attach because the file type is .log so I will paste only the WARN and ERR instead of the whole log-file.
      11359 timing action:extract Completed in 111604ms
      11360 silly extract lodash@^4.17.13 extracted to /home/pi/MagicMirror/node_modules/.staging/lodash-dee8f977 (111572ms)
      11361 warn tar ENOENT: no such file or directory, open '/home/pi/MagicMirror/node_modules/.staging/moment-fbf25dd9/min/moment-with-locales.js'
      11362 warn tar ENOENT: no such file or directory, open '/home/pi/MagicMirror/node_modules/.staging/lodash-20df1054/core.min.js'
      11363 warn tar ENOENT: no such file or directory, open '/home/pi/MagicMirror/node_modules/.staging/lodash-24d00653/core.min.js'
      // many similar WARN messages
      12301 warn tar ENOENT: no such file or directory, open '/home/pi/MagicMirror/node_modules/.staging/rrule-21671673/dist/es5/rrule-tz.js.map'
      12302 timing stage:rollbackFailedOptional Completed in 170ms
      12303 timing stage:runTopLevelLifecycles Completed in 545603ms
      12304 silly saveTree magicmirror@2.8.0
      12304 silly saveTree ├─┬ chai-as-promised@7.1.1
      12304 silly saveTree │ └── check-error@1.0.2
      12304 silly saveTree ├─┬ chai@4.2.0
      12304 silly saveTree │ ├── assertion-error@1.1.0
      12304 silly saveTree │   ├── parse-ms@1.0.1
      12304 silly saveTree │   └── plur@1.0.0
      12304 silly saveTree └── valid-url@1.0.9
      12305 warn grunt-stylelint@0.11.1 requires a peer of stylelint@^10.0.0 but none is installed. You must install peer dependencies yourself.
      12306 verbose type system
      12307 verbose stack FetchError: request to https://registry.npmjs.org/valid-url/-/valid-url-1.0.9.tgz failed, reason: getaddrinfo EAI_AGAIN registry.npmjs.org registry.npmjs.org:443
      12307 verbose stack     at ClientRequest.req.on.err (/home/pi/.config/versions/node/v10.16.3/lib/node_modules/npm/node_modules/node-fetch-npm/src/index.js:68:14)
      12307 verbose stack     at ClientRequest.emit (events.js:198:13)
      12307 verbose stack     at TLSSocket.socketErrorListener (_http_client.js:392:9)
      12307 verbose stack     at TLSSocket.emit (events.js:198:13)
      12307 verbose stack     at emitErrorNT (internal/streams/destroy.js:91:8)
      12307 verbose stack     at emitErrorAndCloseNT (internal/streams/destroy.js:59:3)
      12307 verbose stack     at process._tickCallback (internal/process/next_tick.js:63:19)
      12308 verbose cwd /home/pi/MagicMirror
      12309 verbose Linux 4.19.66+
      12310 verbose argv "/home/pi/.config/versions/node/v10.16.3/bin/node" "/home/pi/.config/versions/node/v10.16.3/bin/npm" "install"
      12311 verbose node v10.16.3
      12312 verbose npm  v6.9.0
      12313 error code EAI_AGAIN
      12314 error errno EAI_AGAIN
      12315 error request to https://registry.npmjs.org/valid-url/-/valid-url-1.0.9.tgz failed, reason: getaddrinfo EAI_AGAIN registry.npmjs.org registry.npmjs.org:443
      12316 verbose exit [ 1, true ]
      Any idea :nerd_face: what to do getting the RasPi0 run?
      Hold in mind what happen in case of newer MagicMirror software or other updates need to run automaticly.
      Many thanks, bdream
      cheers, bdream
      S 2 Replies Last reply
        sdetweil @bdream
        @bdream try my updated installer, I am working to get this to replace the current version…
        see https://forum.magicmirror.builders/topic/10171/anyone-want-to-try-updated-installer
        others have reported it works ok on Pi zero
        rename the MagicMirror folder or remove it before running the installer
          bdream
          ok, many thanks! :grinning_face: I will try it now.
          Just deleted the MagicMirror folder…
          If I understand you correctly the new script will replace the old one as:
          ~~curl -o- https://raw.githubusercontent.com/creationix/nvm/v0.34.0/install.sh | bash~~
          bash -c "$(curl -sL https://www.dropbox.com/s/rlh710ng0zwv3vp/raspberry.sh?dl=0)"
          but all other in your manual will stay. Right?
          CU, bdream
          cheers, bdream
            sdetweil @bdream
            @bdream the installer also fixes pm2 and the screen saver
            and creates a log of the install process results
            i don’t think u will need the other steps in the pi0 manual anymore
              bdream
              thanks for this info, so I know what to do if my attempt to fix first installation only by deleting /MagicMirror and start your script fails :frowning_face: :winking_face:. And it failed :frowning_face:
              I get a new “Raspbian Buster Lite” now and start again :nerd_face:
              Will let you know about the outcome. It will take long time :sleeping_face:
              Best gerads, bdream
              cheers, bdream
                sdetweil @bdream
                @bdream said in YAPi0 Installer Stretch Lite:
                start your script fails . And it failed
                please post the contents of ~/install.log
                  bdream
                  Ohh sdetweil, my bad. I overwrote the SD-card already with the new image. I have to learn how to work with forum and being sensitive for upcoming questions/requests.
                  For now I started your script again an it seems it’s running :sleeping_face:
                  I wonder as I have on screen a warning
                  npm WARN npm npm does not support Node.js v10.15.2
                  npm WARN npm You should probably upgrade to a newer version of node as we
                  npm WARN npm can't make promises that npm will work with this version.
                  npm WARN npm Supported releases of Node.js are the latest releases of 4, 6, 7, 8, 9.
                  npm WARN npm You can find the latest version at https://nodejs.org/
                  /usr/local/bin/npm -> /usr/local/lib/node_modules/npm/bin/npm-cli.js
                  /usr/local/bin/npx -> /usr/local/lib/node_modules/npm/bin/npx-cli.js
                  + npm@6.11.3
                  added 430 packages from 833 contributors in 433.321s
                  npm installation Done!
                  Cloning MagicMirror ...
                  Klone nach 'MagicMirror' ...
                  remote: Enumerating objects: 315, done.
                  remote: Counting objects: 100% (315/315), done.
                  remote: Compressing objects: 100% (282/282), done.
                  remote: Total 315 (delta 39), reused 193 (delta 21), pack-reused 0
                  Empangene Obekte: 100% (315/315), 655.08 KiB | 867.00 KiB/s, Fertig.
                  Löse Unterschiede auf: 100% (39/39), Fertig.
                  Cloning MagicMirror Done!
                  Installing dependencies ...
                  npm WARN deprecated time-grunt@2.0.0: Deprecated because Grunt is practically unmaintained. Move on to something better. This package will continue to work with Grunt v1, but it will not receive any updates.
                  > electron-chromedriver@1.8.0 install /home/pi/MagicMirror/node_modules/electron-chromedriver
                  > node ./download-chromedriver.js
                  That is the position cursor is blinking and nothing change since a long time.
                  Here you are the install.log from actual running? installation.
                  install starting  - So Sep 22 18:22:15 CEST 2019
                  installing on armv6l processor system
                  forcing armv71 architecture for pi 0
                  Updating packages ...
                  Installing helper tools ...
                  Node.js is not installed.
                  Installing Node.js ...
                  Node.js installation Done! version=v10.15.2
                  npm is not installed.
                  Installing npm ...
                  upgrading npm to latest
                  Cheers, bdream
                  cheers, bdream
                    bdream
                    Oh boy, so bad.
                    Maybe I don’t understand what I’m doing here.
                    install.log has not changed but MM ist also not running.
                    After I stopped above stated blinking curser with Ctrl - C
                    I did install MM
                    npm install
                    after I did
                    npm install pm@latest -g
                    what failed.
                    I’m :pouting_face:
                    Do I go total wrong way here?
                    Where is my fault?
                    Maybe it’s that I’m not clear in what will your script do and what have I to do additional and in which sequence?
                    Have you any advise to me please?
                    Many thanks fpor your help! bdream
                    cheers, bdream
                      sdetweil @bdream
                      @bdream my script should do EVERYTHING…
                      the chromedriver install had a problem…
                      can u do this
                      cd /home/pi/MagicMirror/node_modules/electron-chromedriver
                      and show me what the results are…
                      thanks
                        bdream
                        Hi Sam,
                        as I get Error replaying with code inside: 0_1569315660505_Error.JPG
                        cheers, bdream
                        cheers, bdream
                          sdetweil @bdream
                          @bdream
                          hmm…
                          try this from the MagicMirror folder
                          npm install  --arch=armv7l electron-chromedriver@1.8.0
                            bdream
                            Here it is…
                            pi@RasPiZeroWH:~/MagicMirror $ npm install  --arch=armv7l electron-chromedriver@1.8.0
                            successfully dowloaded and extracted!
                            npm WARN grunt-stylelint@0.11.1 requires a peer of stylelint@^10.0.0 but none is installed. You must install peer dependencies yourself.
                            + electron-chromedriver@1.8.0
                            updated 1 package and audited 3773 packages in 640.327s
                            found 16 high severity vulnerabilities
                              run `npm audit fix` to fix them, or `npm audit` for details
                            cheers, bdream
                            cheers, bdream
                              sdetweil @bdream
                              @bdream weird. Works normal, fails in script.
                              So, do this.
                              npm install --arch=armv71
                              Please advise your results
                                bdream
                                see here:
                                pi@RasPiZeroWH:~/MagicMirror $ npm install --arch=armv71
                                > magicmirror@2.8.0 install /home/pi/MagicMirror
                                > cd vendor && npm install
                                npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@1.2.4 (node_modules/fsevents):
                                npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@1.2.4: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
                                audited 220 packages in 69.246s
                                found 5 vulnerabilities (4 low, 1 high)
                                > magicmirror@2.8.0 postinstall /home/pi/MagicMirror
                                > sh installers/postinstall/postinstall.sh && npm run install-fonts
                                MagicMirror installation successful!
                                > magicmirror@2.8.0 install-fonts /home/pi/MagicMirror
                                > cd fonts && npm install
                                audited 1 package in 7.131s
                                found 0 vulnerabilities
                                audited 3773 packages in 413.334s
                                cheers, bdream
                                cheers, bdream
                                  sdetweil @bdream
                                  @bdream all good!
                                  Make sure to copy the sample config.js to config.js in the config folder.
                                  Then npm start
                                    bdream
                                    Seems not to be an easy task.
                                    And I totally lost what I have to do in case I want to setup it again on Pi0 :dizzy_face:
                                    Cheers, bdream
                                    cheers, bdream
                                      sdetweil @bdream
                                      @bdream hm… this hardware is not enough like pi0. My script works there.
                                      I will have to look at the YAPI0 doc and see what is different
                                        sdetweil @bdream
                                        change the filetype to .txt
                                          sdetweil @bdream
                                          @bdream ok, partial install is a mess… lets try this way
                                          rm -rf node_modules
                                          then
                                          npm start
                                            bdream
                                            npm install not yet. right?
                                            [0_1569360293647_2019-09-24T17_21_45_114Z-debug.txt](Uploading 100%)
                                            Not a working hint wit log -> txt. Only pics are allowed :(
                                            maybe as jpg even it is an log!
                                            [0_1569360379845_2019-09-24T17_21_45_114Z-debug.jpg](Uploading 100%)
                                            this is also not possible. what can I do?
                                            cheers, bdream
                                            cheers, bdream
                                            • 1 / 6
