    How can I add more time periods for MMM-compliments?
    20 Posts 4 Posters 10.0k Views 4 Watching
    • DæmonEyesD Offline
      DæmonEyes
      So I know MMM-Compliments has 3 time periods by default (morning, afternoon and evening). I want to know, is it possible to add 1 or 2 more time periods like night and dusk?
      I really enjoy being able to customize the compliments that come up, and would love to have more time slots that I could customize.
      • lavolp3L Offline
        lavolp3 Module Developer @DæmonEyes
        @dæmoneyes That shouldn’t be too difficult.
        	complimentArray: function() {
        		var hour = moment().hour();
        		var compliments  = null;
        		if (hour >= 3 && hour < 12) {
        			compliments = this.config.compliments.morning;
        		} else if (hour >= 12 && hour < 17) {
        			compliments = this.config.compliments.afternoon;
        		} else {
        			compliments = this.config.compliments.evening;
        Here is the function calling the hour of the day in MMM-Compliments.js.
        You can easily give this a more precise sorting with more cases.
        However, you would need to change the logic to a switch function, because there can only be one “else if” in an “if” statement.
        Fork the module, try it out!
        How to troubleshoot modules
        MMM-soccer v2, MMM-AVStock
          sdetweil @lavolp3
          @lavolp3 said in How can I add more time periods for MMM-compliments?:
          not true, you can have as many as u want…
          switch sometimes makes things more clear, but not always
            DæmonEyes
            This is actually my first time programming ever, so I don’t actually know what are logic or switch functions.
            This is what I attempted, but it didn’t work, and instead the compliments module just didn’t load up when starting MM:
            ![I added two more time period: predawn and night](https://imgur.com/a/JJrJ01w)
            ![Updated the time intervals](https://imgur.com/a/lzAO0gJ)
            ![And tried modifying the compliments array as well](https://imgur.com/a/ZiNT8u5)
              sdetweil @DæmonEyes
              @dæmoneyes your changes didn’t show
              use the three back-tics before and after your code
              on keyboard, left of the number 1 key
              DæmonEyesD 1 Reply Last reply Reply Quote 1
                DæmonEyes @sdetweil
                @sdetweil Here are all the changes I tried: https://imgur.com/a/wbYQclq
                alt text
                  sdetweil @DæmonEyes
                  @dæmoneyes start the mirror with
                  npm start dev
                  and in the white developers window, select the console tab,
                  scroll up/down to find any errors (red text)…
                  I can’t see all your code, but its probably a missing quote, paren or brace
                    DæmonEyes @sdetweil
                    @sdetweil Did that, found some red related to compliments and also to openweather
                    Here is the full console tab: https://imgur.com/a/Lrn8kVH
                      sdetweil @DæmonEyes
                      @dæmoneyes compliments.js:48 syntax error
                      that means on line 48 of the complements.js file the compiler found an error…
                        DæmonEyes @sdetweil
                        @sdetweil Once again, I owe you my thanks sdetweil! It works now!
                        What should I do about the red related to the openweathermap?
                          sdetweil @DæmonEyes
                          @dæmoneyes openweathermap… I do not know… sorry…
                          DæmonEyesD 1 Reply Last reply Reply Quote 0
                            DæmonEyes @sdetweil
                            @sdetweil hey no problem, it seems to be working fine, so I guess I shouldn’t worry about it.
                            If I may ask one more question, should I do anything about the yellow warning ‘Electron Security Warning’?
                              sdetweil @DæmonEyes
                              @dæmoneyes if your mirror was open to the internet, then I would say yes
                              DæmonEyesD 1 Reply Last reply Reply Quote -1
                                DæmonEyes @sdetweil
                                @sdetweil Hmm ok, besides weather and quote of the day, I’m not really connecting to the net for anything so I guess that’s fine.
                                Thanks again for helping me solve this!
                                  SaschaSP
                                  @DæmonEyes you only make changes in
                                  MagicMirror/modules/default/compliments/MMM-Compliments.js
                                  and of corse in the
                                  MagicMirror/config/config.js?
                                  Can your Post your changes here in the Forum?
                                  Here is a nice “HowTo” post a code into the Forum for better reading https://forum.magicmirror.builders/topic/4247/how-to-post-code-on-the-forum-for-absolute-beginners
                                  Thank you
                                    DæmonEyes @SaschaSP
                                    @saschasp Actually I only had to make changes in the MMM-compliments.js and not the config.js
                                    I just had to make changes at those 3 places that I showed in the imgur link I had posted and it works great.
                                    sdetweil helped my find the missing comma that was causing the problem with the npm start dev prompt and now it works great.
                                    I now have 5 time periods and 3 compliments for each period. If I think of more compliments, I’ll probably add a 4th compliment for each period.
                                      DæmonEyes
                                      Is it normal for the default modules to reset to factory settings when updating MM?
                                      Just did the MM update to 2.7.1 and noticed my compliments module has reset to its original compliments and time periods.
                                        sdetweil
                                        yes, the default modules are part of the base… and will be reset… altho you should have been warned by git
                                        if u did a git stash, then u can get those changes back
                                          DæmonEyes @sdetweil
                                          @sdetweil Oh ok, I just did my first stash now.
                                          So let’s say I had done a stash before I had updated; how would I retrieve it after updating?
                                          (So I know what to do next time)
                                            sdetweil @DæmonEyes
                                            @DæmonEyes git stash pop
                                            i don’t know if you can pop one file at a time
                                            (ps… google is your friend!)
