    How can I add more time periods for MMM-compliments?
    20 Posts 4 Posters 9.0k Views 4 Watching
    • DæmonEyesD Offline
      DæmonEyes
      So I know MMM-Compliments has 3 time periods by default (morning, afternoon and evening). I want to know, is it possible to add 1 or 2 more time periods like night and dusk?
      I really enjoy being able to customize the compliments that come up, and would love to have more time slots that I could customize.
      • lavolp3L Offline
        lavolp3 Module Developer @DæmonEyes
        @dæmoneyes That shouldn’t be too difficult.
        	complimentArray: function() {
        		var hour = moment().hour();
        		var compliments  = null;
        		if (hour >= 3 && hour < 12) {
        			compliments = this.config.compliments.morning;
        		} else if (hour >= 12 && hour < 17) {
        			compliments = this.config.compliments.afternoon;
        		} else {
        			compliments = this.config.compliments.evening;
        Here is the function calling the hour of the day in MMM-Compliments.js.
        You can easily give this a more precise sorting with more cases.
        However, you would need to change the logic to a switch function, because there can only be one “else if” in an “if” statement.
        Fork the module, try it out!
        How to troubleshoot modules
        MMM-soccer v2, MMM-AVStock
          sdetweil @lavolp3
          @lavolp3 said in How can I add more time periods for MMM-compliments?:
          not true, you can have as many as u want…
          switch sometimes makes things more clear, but not always
            DæmonEyes
            This is actually my first time programming ever, so I don’t actually know what are logic or switch functions.
            This is what I attempted, but it didn’t work, and instead the compliments module just didn’t load up when starting MM:
            ![I added two more time period: predawn and night](https://imgur.com/a/JJrJ01w)
            ![Updated the time intervals](https://imgur.com/a/lzAO0gJ)
            ![And tried modifying the compliments array as well](https://imgur.com/a/ZiNT8u5)
              sdetweil @DæmonEyes
              @dæmoneyes your changes didn’t show
              use the three back-tics before and after your code
              on keyboard, left of the number 1 key
              DæmonEyesD 1 Reply Last reply Reply Quote 1
                DæmonEyes @sdetweil
                @sdetweil Here are all the changes I tried: https://imgur.com/a/wbYQclq
                alt text
                  sdetweil @DæmonEyes
                  @dæmoneyes start the mirror with
                  npm start dev
                  and in the white developers window, select the console tab,
                  scroll up/down to find any errors (red text)…
                  I can’t see all your code, but its probably a missing quote, paren or brace
                    DæmonEyes @sdetweil
                    @sdetweil Did that, found some red related to compliments and also to openweather
                    Here is the full console tab: https://imgur.com/a/Lrn8kVH
                      sdetweil @DæmonEyes
                      @dæmoneyes compliments.js:48 syntax error
                      that means on line 48 of the complements.js file the compiler found an error…
                        DæmonEyes @sdetweil
                        @sdetweil Once again, I owe you my thanks sdetweil! It works now!
                        What should I do about the red related to the openweathermap?
