How can I add more time periods for MMM-compliments?
20 Posts 4 Posters 6.6k Views 4 Watching
    DæmonEyes
    So I know MMM-Compliments has 3 time periods by default (morning, afternoon and evening). I want to know, is it possible to add 1 or 2 more time periods like night and dusk?
    I really enjoy being able to customize the compliments that come up, and would love to have more time slots that I could customize.
    L 1 Reply Last reply Feb 19, 2019, 9:06 AM Reply Quote 0
    • L Offline
      lavolp3 Module Developer @DæmonEyes
      @dæmoneyes That shouldn’t be too difficult.
      	complimentArray: function() {
      		var hour = moment().hour();
      		var compliments  = null;
      		if (hour >= 3 && hour < 12) {
      			compliments = this.config.compliments.morning;
      		} else if (hour >= 12 && hour < 17) {
      			compliments = this.config.compliments.afternoon;
      		} else {
      			compliments = this.config.compliments.evening;
      Here is the function calling the hour of the day in MMM-Compliments.js.
      You can easily give this a more precise sorting with more cases.
      However, you would need to change the logic to a switch function, because there can only be one “else if” in an “if” statement.
      Fork the module, try it out!
      How to troubleshoot modules
      MMM-soccer v2, MMM-AVStock
      S 1 Reply Last reply Feb 19, 2019, 10:50 AM Reply Quote 0
        sdetweil @lavolp3
        @lavolp3 said in How can I add more time periods for MMM-compliments?:
        not true, you can have as many as u want…
        switch sometimes makes things more clear, but not always
          DæmonEyes
          This is actually my first time programming ever, so I don’t actually know what are logic or switch functions.
          This is what I attempted, but it didn’t work, and instead the compliments module just didn’t load up when starting MM:
          ![I added two more time period: predawn and night](https://imgur.com/a/JJrJ01w)
          ![Updated the time intervals](https://imgur.com/a/lzAO0gJ)
          ![And tried modifying the compliments array as well](https://imgur.com/a/ZiNT8u5)
          S 1 Reply Last reply Feb 19, 2019, 4:54 PM Reply Quote 0
            sdetweil @DæmonEyes
            @dæmoneyes your changes didn’t show
            use the three back-tics before and after your code
            on keyboard, left of the number 1 key
            D 1 Reply Last reply Feb 19, 2019, 6:08 PM Reply Quote 1
              DæmonEyes @sdetweil
              @sdetweil Here are all the changes I tried: https://imgur.com/a/wbYQclq
              alt text
              S 1 Reply Last reply Feb 19, 2019, 6:33 PM Reply Quote 0
                sdetweil @DæmonEyes
                @dæmoneyes start the mirror with
                npm start dev
                and in the white developers window, select the console tab,
                scroll up/down to find any errors (red text)…
                I can’t see all your code, but its probably a missing quote, paren or brace
                D 1 Reply Last reply Feb 19, 2019, 7:04 PM Reply Quote 1
                  DæmonEyes @sdetweil
                  @sdetweil Did that, found some red related to compliments and also to openweather
                  Here is the full console tab: https://imgur.com/a/Lrn8kVH
                  S 1 Reply Last reply Feb 19, 2019, 7:07 PM Reply Quote 0
                    sdetweil @DæmonEyes
                    @dæmoneyes compliments.js:48 syntax error
                    that means on line 48 of the complements.js file the compiler found an error…
                    D 1 Reply Last reply Feb 19, 2019, 7:12 PM Reply Quote 1
                      DæmonEyes @sdetweil
                      @sdetweil Once again, I owe you my thanks sdetweil! It works now!
                      What should I do about the red related to the openweathermap?
                      S 1 Reply Last reply Feb 19, 2019, 7:41 PM Reply Quote 0
