    How can I add more time periods for MMM-compliments?
    20 Posts 4 Posters 9.4k Views 4 Watching
      sdetweil @DæmonEyes
      @dæmoneyes your changes didn’t show
      use the three back-tics before and after your code
      on keyboard, left of the number 1 key
      DæmonEyesD 1 Reply Last reply Reply Quote 1
      • DæmonEyesD Offline
        DæmonEyes @sdetweil
        @sdetweil Here are all the changes I tried: https://imgur.com/a/wbYQclq
        alt text
          sdetweil @DæmonEyes
          @dæmoneyes start the mirror with
          npm start dev
          and in the white developers window, select the console tab,
          scroll up/down to find any errors (red text)…
          I can’t see all your code, but its probably a missing quote, paren or brace
            DæmonEyes @sdetweil
            @sdetweil Did that, found some red related to compliments and also to openweather
            Here is the full console tab: https://imgur.com/a/Lrn8kVH
              sdetweil @DæmonEyes
              @dæmoneyes compliments.js:48 syntax error
              that means on line 48 of the complements.js file the compiler found an error…
                DæmonEyes @sdetweil
                @sdetweil Once again, I owe you my thanks sdetweil! It works now!
                What should I do about the red related to the openweathermap?
                  sdetweil @DæmonEyes
                  @dæmoneyes openweathermap… I do not know… sorry…
                  DæmonEyesD 1 Reply Last reply Reply Quote 0
                    DæmonEyes @sdetweil
                    @sdetweil hey no problem, it seems to be working fine, so I guess I shouldn’t worry about it.
                    If I may ask one more question, should I do anything about the yellow warning ‘Electron Security Warning’?
                      sdetweil @DæmonEyes
                      @dæmoneyes if your mirror was open to the internet, then I would say yes
                      DæmonEyesD 1 Reply Last reply Reply Quote -1
                        DæmonEyes @sdetweil
                        @sdetweil Hmm ok, besides weather and quote of the day, I’m not really connecting to the net for anything so I guess that’s fine.
                        Thanks again for helping me solve this!
