    MMM-Image-On-Notification
    16 Posts 4 Posters 6.0k Views 5 Watching
    • ejay-ibmE Offline
      ejay-ibm Project Sponsor Module Developer
      I found
      src=“modules/MMM-HTMLBox/jarvis-standby2.gif”
      that works …
      thank you
        sdetweil @ejay-ibm
        @ejay-ibm actually looks like the base is
        /home/pi/MagicMirror/modules
        code in app/server.js
        var directories = ["/config", "/css", "/fonts", "/modules", "/vendor", "/translations", "/tests/configs"];
        sets up listening on those folders
        ejay-ibmE 1 Reply Last reply Reply Quote 0
        • ejay-ibmE Offline
          Thank you @Sean & @sdetweil
          This is the draft result. I still have to work on the talking image. that one is a quick test.
          https://drive.google.com/open?id=1G34tJ-1trMCK1yEJK0C6gIw3Nx3O8X8Q
          As you can see the animation is triggered a bit early.
          As I discussed with you Sean This is why I would need an additional notification between HOTWORD_PAUSE & ASSISTANT_ACTIVATE (I’ll use this notification as well to turn down the volume when user command is given in case any music is played on the mirror )
          thank you again
          Ejay
          • ejay-ibmE Offline
            ejay-ibm Project Sponsor Module Developer @sdetweil
            @sdetweil I didn’t know that . Thanks I learnt something
            I’ll use config folder then
            Ejay
              sdetweil @ejay-ibm
              @ejay-ibm i would try to stay away from MM folders… create another under modules for your own content
              ejay-ibmE 1 Reply Last reply Reply Quote 1
              • ejay-ibmE Offline
                @sdetweil Yes config/images or modules/images
                Both would be ok since not overwritten in case of an update.
                Good Idea.
