    MMM-Image-On-Notification
    16 Posts 4 Posters 7.3k Views 5 Watching
    • ejay-ibmE
      ejay-ibm Project Sponsor Module Developer @Guest
      @sean
      Right I was missing the first module .
      Now this is what I’m getting
      I feel stupid to not be able to debug such simple thing, but I’m sure you will figure out the error faster than me …
        sdetweil @ejay-ibm
        @ejay-ibm its ok, this is a tricky one… the forum has a problem with content that starts with the '< ’ symbol,
        so to make it show, we have to put a space after it… so… in your content:, take the space out after that < symbol
        • ejay-ibmE
          Thank you @sdetweil That look better
          Now I think it’s my last issue . The path …
          I’m getting :
          jarvis-standby2.gif:1 GET http://localhost:8080/jarvis-standby2.gif 404 (Not Found)
          If the images is placed in /home/pi/MagicMirror/jarvis-standby2.gif
          not sure what’s wrong and what is the “expectation” with the path …
            sdetweil @ejay-ibm
            @ejay-ibm the default path for the localhost server is /home/pi/MagicMirror,
            if you do
            ls /home/pi/MagicMirror/jarvis-standby2.gif -laF
            do you get a proper display out?
            linux/pi is case sensitive..
            ejay-ibmE 1 Reply Last reply
            • ejay-ibmE
              ejay-ibm Project Sponsor Module Developer @sdetweil
              @sdetweil said in MMM-Image-On-Notification:
              yup
              i@ejaypi:~/MagicMirror$ ls /home/pi/MagicMirror/jarvis-standby2.gif -laF
              -rw-r–r-- 1 pi pi 8735111 mars 1 19:58 /home/pi/MagicMirror/jarvis-standby2.gif
              • ejay-ibmE
                I found
                src=“modules/MMM-HTMLBox/jarvis-standby2.gif”
                that works …
                thank you
                  sdetweil @ejay-ibm
                  @ejay-ibm actually looks like the base is
                  /home/pi/MagicMirror/modules
                  code in app/server.js
                  var directories = ["/config", "/css", "/fonts", "/modules", "/vendor", "/translations", "/tests/configs"];
                  sets up listening on those folders
                  • ejay-ibmE
                    Thank you @Sean & @sdetweil
                    This is the draft result. I still have to work on the talking image. that one is a quick test.
                    https://drive.google.com/open?id=1G34tJ-1trMCK1yEJK0C6gIw3Nx3O8X8Q
                    As you can see the animation is triggered a bit early.
                    As I discussed with you Sean This is why I would need an additional notification between HOTWORD_PAUSE & ASSISTANT_ACTIVATE (I’ll use this notification as well to turn down the volume when user command is given in case any music is played on the mirror )
                    thank you again
                    Ejay
                    • ejay-ibmE
                      @sdetweil I didn’t know that . Thanks I learnt something
                      I’ll use config folder then
                      Ejay
                        sdetweil @ejay-ibm
                        @ejay-ibm i would try to stay away from MM folders… create another under modules for your own content
                        • ejay-ibmE
                          @sdetweil Yes config/images or modules/images
                          Both would be ok since not overwritten in case of an update.
                          Good Idea.
