    MMM-Image-On-Notification
    16 Posts 4 Posters 6.3k Views 5 Watching
    • ejay-ibmE Offline
      ejay-ibm Project Sponsor Module Developer @Guest
      @sean Thank ( Again Sean)
      I’m getting the following error :
      config.js:40 Uncaught TypeError: Cannot set property 'src' of null
          at Object.payload (config.js:40)
          at Class.notificationReceived (MMM-NotificationTrigger.js:62)
          at sendNotification (main.js:95)
          at Object.sendNotification (main.js:498)
          at Class.sendNotification (module.js:368)
          at Class.socketNotificationReceived (MMM-Hotword.js:85)
          at module.js:246
          at r.<anonymous> (socketclient.js:25)
          at r.emit (index.js:83)
          at r.onevent (index.js:83)
      config.js 40 is :
      38           payload: (payload) => {
      39            var img = document.getElementById("MY_ANIMATION")
      40              img.src = "/home/pi/MagicMirror/jarvis-standby2.gif"
      41              return payload
      Any Idea ? Let me know if you need me to report this directly in git issues.
        A Former User @ejay-ibm
        @ejay-ibm
        Where is your default.gif?(#MY_ANIMATION)?
        ejay-ibmE 1 Reply Last reply Reply Quote 0
        • ejay-ibmE Offline
          @sean
          Right I was missing the first module .
          Now this is what I’m getting
          I feel stupid to not be able to debug such simple thing, but I’m sure you will figure out the error faster than me …
            sdetweil @ejay-ibm
            @ejay-ibm its ok, this is a tricky one… the forum has a problem with content that starts with the '< ’ symbol,
            so to make it show, we have to put a space after it… so… in your content:, take the space out after that < symbol
            • ejay-ibmE Offline
              Thank you @sdetweil That look better
              Now I think it’s my last issue . The path …
              I’m getting :
              jarvis-standby2.gif:1 GET http://localhost:8080/jarvis-standby2.gif 404 (Not Found)
              If the images is placed in /home/pi/MagicMirror/jarvis-standby2.gif
              not sure what’s wrong and what is the “expectation” with the path …
                sdetweil @ejay-ibm
                @ejay-ibm the default path for the localhost server is /home/pi/MagicMirror,
                if you do
                ls /home/pi/MagicMirror/jarvis-standby2.gif -laF
                do you get a proper display out?
                linux/pi is case sensitive..
                • ejay-ibmE Offline
                  ejay-ibm Project Sponsor Module Developer @sdetweil
                  @sdetweil said in MMM-Image-On-Notification:
                  yup
                  i@ejaypi:~/MagicMirror$ ls /home/pi/MagicMirror/jarvis-standby2.gif -laF
                  -rw-r–r-- 1 pi pi 8735111 mars 1 19:58 /home/pi/MagicMirror/jarvis-standby2.gif
                  • ejay-ibmE Offline
                    I found
                    src=“modules/MMM-HTMLBox/jarvis-standby2.gif”
                    that works …
                    thank you
                      sdetweil @ejay-ibm
                      @ejay-ibm actually looks like the base is
                      /home/pi/MagicMirror/modules
                      code in app/server.js
                      var directories = ["/config", "/css", "/fonts", "/modules", "/vendor", "/translations", "/tests/configs"];
                      sets up listening on those folders
                      • ejay-ibmE Offline
                        Thank you @Sean & @sdetweil
                        This is the draft result. I still have to work on the talking image. that one is a quick test.
                        https://drive.google.com/open?id=1G34tJ-1trMCK1yEJK0C6gIw3Nx3O8X8Q
                        As you can see the animation is triggered a bit early.
                        As I discussed with you Sean This is why I would need an additional notification between HOTWORD_PAUSE & ASSISTANT_ACTIVATE (I’ll use this notification as well to turn down the volume when user command is given in case any music is played on the mirror )
                        thank you again
                        Ejay
