    MMM-Image-On-Notification
    16 Posts 4 Posters 6.3k Views 5 Watching
      A Former User @ejay-ibm
      @ejay-ibm
      Where is your default.gif?(#MY_ANIMATION)?
      ejay-ibmE 1 Reply Last reply Reply Quote 0
      • ejay-ibmE Offline
        ejay-ibm Project Sponsor Module Developer @Guest
        @sean
        Right I was missing the first module .
        Now this is what I’m getting
        I feel stupid to not be able to debug such simple thing, but I’m sure you will figure out the error faster than me …
          sdetweil @ejay-ibm
          @ejay-ibm its ok, this is a tricky one… the forum has a problem with content that starts with the '< ’ symbol,
          so to make it show, we have to put a space after it… so… in your content:, take the space out after that < symbol
          • ejay-ibmE Offline
            Thank you @sdetweil That look better
            Now I think it’s my last issue . The path …
            I’m getting :
            jarvis-standby2.gif:1 GET http://localhost:8080/jarvis-standby2.gif 404 (Not Found)
            If the images is placed in /home/pi/MagicMirror/jarvis-standby2.gif
            not sure what’s wrong and what is the “expectation” with the path …
              sdetweil @ejay-ibm
              @ejay-ibm the default path for the localhost server is /home/pi/MagicMirror,
              if you do
              ls /home/pi/MagicMirror/jarvis-standby2.gif -laF
              do you get a proper display out?
              linux/pi is case sensitive..
              • ejay-ibmE Offline
                ejay-ibm Project Sponsor Module Developer @sdetweil
                @sdetweil said in MMM-Image-On-Notification:
                yup
                i@ejaypi:~/MagicMirror$ ls /home/pi/MagicMirror/jarvis-standby2.gif -laF
                -rw-r–r-- 1 pi pi 8735111 mars 1 19:58 /home/pi/MagicMirror/jarvis-standby2.gif
                • ejay-ibmE Offline
                  I found
                  src=“modules/MMM-HTMLBox/jarvis-standby2.gif”
                  that works …
                  thank you
                    sdetweil @ejay-ibm
                    @ejay-ibm actually looks like the base is
                    /home/pi/MagicMirror/modules
                    code in app/server.js
                    var directories = ["/config", "/css", "/fonts", "/modules", "/vendor", "/translations", "/tests/configs"];
                    sets up listening on those folders
                    • ejay-ibmE Offline
                      Thank you @Sean & @sdetweil
                      This is the draft result. I still have to work on the talking image. that one is a quick test.
                      https://drive.google.com/open?id=1G34tJ-1trMCK1yEJK0C6gIw3Nx3O8X8Q
                      As you can see the animation is triggered a bit early.
                      As I discussed with you Sean This is why I would need an additional notification between HOTWORD_PAUSE & ASSISTANT_ACTIVATE (I’ll use this notification as well to turn down the volume when user command is given in case any music is played on the mirror )
                      thank you again
                      Ejay
                      • ejay-ibmE Offline
                        @sdetweil I didn’t know that . Thanks I learnt something
                        I’ll use config folder then
                        Ejay
