    [MMM-Remote-Control] Cannot GET /api
    12 Posts 10 Posters 9.2k Views 8 Watching
    • C
      Carsten
      Hi there,
      actually the module is working fine. i can access remote.html and all functions are working.
      but as soon i try to access the api via command line i get “Cannot GET” error.
      curl -X GET http://192.168.0.114:8080/api/module
      <!DOCTYPE html>
      <html lang="en">
      <head>
      <meta charset="utf-8">
      <title>Error</title>
      </head>
      <body>
      <pre>Cannot GET /api/module</pre>
      </body>
      </html>
      any clue what is going on here?
      • A
        AxLed Module Developer
        @Carsten
        Are you sure your link example is complete?
        Is the following example $ curl -X GET http://magicmirrorip:8080/api/module/alert/showalert?message=Hello&timer=2000 working?
        Details see https://github.com/Jopyth/MMM-Remote-Control/blob/master/API/README.md
        AxLED
        • C
          Carsten
          Yes i,m sure. It is from the Documentation you,ve posted.
          But also your link Example don‘t work.
          Cannot GET /api/module/alert/showalert
          What i‘ve read till now it seems that the api folder isn‘t published.
          I‘ve did an update of MM but didn‘t helped.
          Further help is much appreciated.
          • T
            teemuoksanen
            I have exactly the same problem - all API calls result in error “Cannot GET /api/whatevermoduleitrytocall”. However, remote.html loads just fine.
            M 1 Reply Last reply
            • M
              mohace @teemuoksanen
              @teemuoksanen said in [MMM-Remote-Control] Cannot GET /api:
              As I have.
              Edited: It was a mistake, sorry. I have same problem.
              Reply Quote 1
              • M
                mlcampbe
                Same here too. I thought that perhaps we needed to have MMM-Api module installed but when I install that my MM won’t even start due to errors.
                  sdetweil
                  @AxLed said in [MMM-Remote-Control] Cannot GET /api:
                  it looks like the api was changed, but not documented…
                  looking thru node_helper.js you can see all the commands
                  ip:port/remote?action=xxxxx&parms=???&parms2=???
                  the code lists these actions
                              if (query.action === "SHUTDOWN") {
                              if (query.action === "REBOOT") {
                              if (query.action === "RESTART" || query.action === "STOP") {
                              if (query.action === "USER_PRESENCE") {
                              if (["MONITORON", "MONITOROFF", "MONITORTOGGLE", "MONITORSTATUS"].indexOf(query.action) !== -1) {
                                  this.monitorControl(query.action, opts, res);
                              if (query.action === "HIDE" || query.action === "SHOW" || query.action === "TOGGLE") {
                                  self.sendSocketNotification(query.action, query);
                              if (query.action === "BRIGHTNESS") {
                                  self.sendSocketNotification(query.action, query.value);
                              if (query.action === "SAVE") {
                              if (query.action === "MODULE_DATA") {
                              if (query.action === "INSTALL") {
                              if (query.action === "REFRESH") {
                                  self.sendSocketNotification(query.action);
                              if (query.action === "HIDE_ALERT") {
                              if (query.action === "SHOW_ALERT") {
                                  self.sendSocketNotification(query.action, {
                              if (query.action === "UPDATE") {
                              if (query.action === 'NOTIFICATION') {
                                      this.sendSocketNotification(query.action, { 'notification': query.notification, 'payload': payload });
                              if (["MINIMIZE", "TOGGLEFULLSCREEN", "DEVTOOLS"].indexOf(query.action) !== -1) {
                                      switch (query.action) {
                              if (query.action === "DELAYED") {
                  to send an alert thru the api
                  http://mirror_ip:mirror_port/remote?action=SHOW_ALERT&message=foo&title=help&timer=10&type=alert
                  the remote.html does NOT use the api, but uses the socketNotifications pipe under the covers.
                  which is why it works, but the older /api/modulename… approach doesn’t
                  J A 2 Replies Last reply
                  Reply Quote 3
                  • J
                    jvanoost @sdetweil
                    @sdetweil oh thank you so much !! I couldn’t find the way to use it :)
                    • P
                      PolaricBear
                      I think I solved the problem. At least it worked for me.
                      Just delete file ./modules/package-lock.json. And restart the system.
                      S S 2 Replies Last reply
                      Reply Quote 1
                        sdetweil @PolaricBear
                        @PolaricBear did u post this to the wrong topic?
                          Smolo @PolaricBear
                          @PolaricBear
                          Thx i had the same problem and your tip solved it :-)
                          • A
                            AmazingUpHotel @sdetweil
                            @sdetweil THANKS YOU! That’s the problem, we dont need to use API!
