    • Search
    UNSOLVED Installed successfully, won't start, pi3 magicmirror@2.6.0 nodejs@6.16.0
    Troubleshooting
    • D
      dominigan last edited by
      I tried several times now installing using the automated script, trying the manual installs, and reading every guide I could find here. But when I run…
      DISPLAY=:0 npm start
      … from the MagicMirror directory, all I get is…
      > magicmirror@2.6.0 start /home/pi/MagicMirror
      > sh run-start.sh
      npm ERR! code ELIFECYCLE
      npm ERR! errno 1
      npm ERR! magicmirror@2.6.0 start: `sh run-start.sh`
      npm ERR! Exit status 1
      npm ERR!
      npm ERR! Failed at the magicmirror@2.6.0 start script.
      npm ERR!     /home/pi/.npm/_logs/2019-03-03T13_29_56_176Z-debug.log
      The log says…
      1 verbose cli [ '/usr/bin/node', '/usr/bin/npm', 'start' ]
      2 info using npm@6.8.0
      3 info using node@v6.16.0
      5 info lifecycle magicmirror@2.6.0~prestart: magicmirror@2.6.0
      6 info lifecycle magicmirror@2.6.0~start: magicmirror@2.6.0
      7 verbose lifecycle magicmirror@2.6.0~start: unsafe-perm in lifecycle true
      8 verbose lifecycle magicmirror@2.6.0~start: PATH: /usr/lib/node_modules/npm/node_modules/npm-lifecycle/node-gyp-bin:/home/pi/MagicMirror/node_modules/.bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/local/games:/usr/games
      9 verbose lifecycle magicmirror@2.6.0~start: CWD: /home/pi/MagicMirror
      10 silly lifecycle magicmirror@2.6.0~start: Args: [ '-c', 'sh run-start.sh' ]
      11 silly lifecycle magicmirror@2.6.0~start: Returned: code: 1  signal: null
      12 info lifecycle magicmirror@2.6.0~start: Failed to exec start script
      13 verbose stack Error: magicmirror@2.6.0 start: `sh run-start.sh`
      13 verbose stack Exit status 1
      13 verbose stack     at EventEmitter.<anonymous> (/usr/lib/node_modules/npm/node_modules/npm-lifecycle/index.js:301:16)
      13 verbose stack     at emitTwo (events.js:106:13)
      13 verbose stack     at EventEmitter.emit (events.js:191:7)
      13 verbose stack     at ChildProcess.<anonymous> (/usr/lib/node_modules/npm/node_modules/npm-lifecycle/lib/spawn.js:55:14)
      13 verbose stack     at ChildProcess.emit (events.js:191:7)
      13 verbose stack     at maybeClose (internal/child_process.js:920:16)
      13 verbose stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:230:5)
      14 verbose pkgid magicmirror@2.6.0
      15 verbose cwd /home/pi/MagicMirror
      16 verbose Linux 4.19.25-v7+
      17 verbose argv "/usr/bin/node" "/usr/bin/npm" "start"
      18 verbose node v6.16.0
      19 verbose npm  v6.8.0
      20 error code ELIFECYCLE
      21 error errno 1
      22 error magicmirror@2.6.0 start: `sh run-start.sh`
      22 error Exit status 1
      23 error Failed at the magicmirror@2.6.0 start script.
      23 error This is probably not a problem with npm. There is likely additional logging output above.
      24 verbose exit [ 1, true ]
      I’m a relative newbie and I’m struggling to figure out what is going on. Help?
      Thanks!
      • bhepler
        bhepler Project Sponsor last edited by bhepler
        Did you have any problems with the npm install command? Did that complete successfully?
        Just be sure, try this:
        cd ~/MagicMirror
        npm install
        npm start
        Let us know what you receive.
