    MMM Modules not loading
    3 Posts 2 Posters 574 Views 2 Watching
      cwong79
      I am new to MagicMirror. I have downloaded 3 modules to utilize in my config.js. They are not loading and I cannot figure out why. I have attempted to fix it on my own but to no avail. What am I doing incorrectly for it not to load? All the prebuilt modules are working fine. Any clues to get me debugging this? Thank you.
      let config = {
      	address: "localhost", 	// Address to listen on, can be:
      	port: 8080,
      	basePath: "/", 	// The URL path where MagicMirror is hosted. If you are using a Reverse proxy
      	ipWhitelist: ["127.0.0.1", "::ffff:127.0.0.1", "::1"], 	// Set [] to allow all IP addresses
      	language: "en",
      	locale: "en-US",
      	timeFormat: 12,
      	units: "imperial",
      			module: "alert",
      			module: "updatenotification",
      			position: "top_bar"
      			module: "clock",
      				timeFormat: "12",
      				timezone: "America/New_York"
      			header: "US Holidays",
      						symbol: "calendar-check",
      						url: "webcal://www.calendarlabs.com/ical-calendar/ics/76/US_Holidays.ics"
      			module: "weather",
      			header: "Weather Forecast",
      				type: "forecast",
      				units: "imperial",
      				locationID: "4155966", //ID from http://bulk.openweathermap.org/sample/city.list.json.gz; unzip the gz file and find your city
      				apiKey: "xxxx"
      			module: "newsfeed",
      			position: "bottom_bar",
      				feeds: [
      						title: "CNN",
      						url: "http://rss.cnn.com/rss/cnn_latest.rss"
      				showSourceTitle: true,
      				showPublishDate: true
      			module: "newsfeed",
      				feeds: [
      						title: "New York Times",
      			module: "MMM-PNews",
      				key: "xxxx",
      				maxWidth: "100%",
      				//newsSource: "the-wall-street-journal",
      				//newsSource: "reuters",
      				newsSource: "techradar"
      			module: "MMM-RAIN-MAP",
      			position: "bottom_right",
      				animationSpeedMs: 400,
      				colorScheme: 2,
      				colorizeTime: true,
      				defaultZoomLevel: 8,
      				displayTime: true,
      				displayTimeline: true,
      				displayClockSymbol: true,
      				displayOnlyOnRain: false,
      				extraDelayLastFrameMs: 1000,
      				extraDelayCurrentFrameMs: 3000,
      				markers: [
      					{ lat: 26.143, lng: -80.128, color: "red" },
      					{ lat: 26.12, lng: -80.13, color: "green" },
      				mapPositions: [
      					{ lat: 26.143, lng: -80.128, zoom: 9, loops: 1 },
      					{ lat: 26.143, lng: -80.128, zoom: 6, loops: 2 },
      					{ lat: 26.12, lng: -80.13, zoom: 5, loops: 2 },
      					{ lat: 26.109, lng: -80.233, zoom: 3, loops: 2 },
      				mapUrl: "https://{s}.tile.openstreetmap.org/{z}/{x}/{y}.png",
      				mapHeight: "420px", // must be a pixel value (no percent)
      				mapWidth: "420px", // must be a pixel value (no percent)
      				maxHistoryFrames: -1,
      				maxForecastFrames: -1,
      				substitudeModules: [],
      				updateIntervalInSeconds: 300
      			module: "MMM-OpenWeatherForecast",
      			header: "Forecast",
      						apikey: "xxxx", //SUPER SECRET
      						latitude: 26.124161,
      						longitude: -80.143593,
      						units: "imperial",
      						iconset: "3c",
      						colored: true,
      						concise: true,
      						requestDelay: "2000",
      						showFeelsLikeTemp: true,
      						showCurrentConditions: true,
      						showSummary: true,
      						showExtraCurrentConditions: true,
      						extraCurrentConditions: {
      													highLowTemp: true,
      													precipitation: true,
      													sunrise: true,
      													sunset: true,
      													wind: true,
      													barometricPressure: false,
      													humidity: true,
      													dewPoint: false,
      													uvIndex: true,
      													visibility: false
      						forecastLayout: "table",
      						forecastHeaderText: "",
      						hourlyForecastTableHeaderText: "By the hour",
      						showHourlyForecast: true,
      						showHourlyTableHeaderRow: true,
      						hourlyForecastInterval: 1,
      						maxHourliesToShow: 10,
      						hourlyExtras: {
      											wind: true,
      											humidity: false,
      											dewPoint: false,
      											uvIndex: false,
      											visibility: false
      						dailyForecastTableHeaderText: "Throughout the week",
      						showDailyForecast: true,
      						showDailyTableHeaderRow: true,
      						maxDailiesToShow: 5,
      						dailyExtras: {
      										sunrise: false,
      										sunset: false,
      										wind: true,
      										humidity: false,
      										dewPoint: false,
      										uvIndex: false
        sdetweil @cwong79
        @cwong79 where did u install them?
        see the topics in my signature below
        also, see theessages where u start mm
        either with
        npm start
        or
        pm2 logs
        of using pm 2
          cwong79 @sdetweil
          @sdetweil Thank for the links. It really helped. My issue was not installing the modules within the modules folder. I reinstalled MagicMirror entirely as the program was acting buggy when I manually deleted the folders. Thank you!
